Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > New Rider Forum
Old 2 Weeks Ago   #1 (permalink)
Nathan Pruitt
Default First two stroke please help
Hey yall i recently bought a kx 125 its a super clean bike very nice well the first day i rode it I blew up my top head the piston looked like i was runnin straight gas but i mixed my fuel 31:2 like the previous owner told me. Well i'm sending my cylinder off to get it re sleeved and bored what are some tips to keep from having to rebuild this top end so often?
Nathan Pruitt is offline   Reply With Quote
Old 2 Weeks Ago   #2 (permalink)
bross
Let's Ride!
Avoid steady throttle on a 2-stroke, they're designed to be revved, let off the gas, revved etc. Think of a bike going around a motocross track, they're constantly on and off the throttle. You can do the same thing riding along a gravel road, just let off the gas every once in awhile.
good reading on the subject...
Dan's Motorcycle
Originally Posted by team ftb
I believe we let the research get in the way of good times far too often.
bross is online now   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
Nathan Pruitt
Thank you any other tips would be GREATLY appreciated
Old 2 Weeks Ago   #4 (permalink)
bross
Let's Ride!
Lot's of good technical info on ThumperTalk... the link is to the Kawasaki 2-stroke forum
http://www.thumpertalk.com/forum/forumdisplay.php?f=195
Just keep up on the maintenance, and ride it!
link to the service manual
Free service manuals: Kawasaki KX 125, KX 250 service manual
Old 2 Weeks Ago   #5 (permalink)
650hardtail
TRIPLE NUT
make sure you mix it well in the can...not try to mix it in the tank...
and double check your ratio of oil to gas
TRIPLES/PARTS ALWAYS WANTED
650hardtail is online now   Reply With Quote
Old 2 Weeks Ago   #6 (permalink)
bross
Let's Ride!
We always used a ratio measuring bottle we bought at our local bike shop. It had marks on the side for the amount of gas you had in your jerry can for the different ratios, just fill the bottle with that much oil, add to your gas and you have the right ratio. This is the one we used...
"The Maxima Quick 2 Mix™ bottle has been calibrated to give you the ability to accurately mix in ratios of 24:1 to 100:1. Simply choose the ratio of oil you wish to use and the amount of gas you are going to mix. Fill oil to the mark corresponding to the amount of gas you will use. For example: To mix 4 gallons of gas at 32:1, fill oil to the 4.0 gallon mark under 32:1 ratio. To mix 6 gallons of gas at 50:1, fill oil to 6.0 gallon mark under 50:1 ratio. etc... The Maxima Quick 2 Mix™ also features ounce and CC calibrations--located on the right side. Use these for you own custom ratios, filling transmission oil, fork oil, etc. Accurate Measurement, Mixes Ounces/CC’s, Mixes Gallons/Liters, Convenient Cap keeps inside clean. Durable Polypropylene, Easy to measure, 20oz/592ml plastic bottle, Compact Size"
Old 2 Weeks Ago   #7 (permalink)
kawpaul
itching to ride
kawpaul's Avatar
Usually if you do not add oil the engine will seize up not blow up. The oil only lubricates the rings so without it you get stuck piston.
1983 gpz 750 .....the wait is over
kawpaul is online now   Reply With Quote
2 stroke vs 4 stroke race bikes Justin- Kawasaki Motocross and Offroad 13 07-17-2008 09:57 PM
2 stroke vs 4 stroke kevo2 Kawasaki Motocross and Offroad 1 06-04-2007 11:49 AM
Early/Easy Stroke Identification 1400pilot Off Topic 16 10-09-2006 07:58 PM
Recognizing a Stroke *Serious* 2WheelFun Off Topic 17 11-22-2005 12:22 AM
2 or 4 Stroke??? '80 KZ 440 Wolffman Kawasaki Streetbikes/Sportbikes 2 04-07-2004 06:40 AM
