Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > New Rider Forum
Old 08-08-2008   #1 (permalink)
mr_pickle
Default Fuel Efficiency, RPMs, Noobish Hurdles
I've been trying to gauge fuel efficiency and stuff on my bike, so i've been riding to and from work whenever the weather is reasonable for the last 2 weeks. I'm sort of new to riding, not to mention the bike, so my "riding style" is still settling in i think.
I've had to overcome some of the usual noobish hurdles like "how to properly fill the gas-tank," which seems like a no brainer but isn't, and "how to start a fully stopped non-FI engine on reserve." (I definitely pushed the bike for ages thinking something was wrong before i figured that one out)
So, with regards to RPMs and driving styles and MPG.... i don't really know what RPM band i should be in.
What driving styles do you guys tend towards and what type of MPG do you guys get?
mr_pickle is offline   Reply With Quote
Old 08-08-2008   #2 (permalink)
Ronin47
Sun Baked Commuter
Ronin47's Avatar
Paranoid, defensive rider, staying within 10mph of the speed limit both for safety and because there are literally cops parked all over my route to work, on an EX650R, and I'm getting about 52 mpg.
My tach doesn't go above 7k rpms if I can help it. Yes, I'm a wuss...
2008 Ninja EX650R
1996 Ninja EX500 (RIP)
Go Green on 2 Wheels!
Ronin47 is offline   Reply With Quote
Old 08-08-2008   #3 (permalink)
serlant
Who am i?
Send a message via MSN to serlant
for best petrol mileage i would say as high a gear as possible without making the engine struggle, ei, not wringing the gears out just because you can.
serlant is offline   Reply With Quote
Old 08-09-2008   #4 (permalink)
soc_monki
Wants better weather!
soc_monki's Avatar
i usually keep mine around 5 or 6K, which gives me plenty of power if i need it, but im not overly revving the engine. i have wound it out in 1st and 2nd a bit though, and im not too worried about mileage. i get around 40 MPG, maybe high 30's if i give it a little beating, but still rather good i think.
plus, gas is going down (87 is 3.50 now, around 3.70 for 93 now i believe). 40 some odd cents is a decent drop, which means ill be using more gas now!
however, i filled up a week and a half ago, and havent put any in since. havent filled my car in about 3 weeks! i drove yesterday because it rained pretty good...and man did i feel weird!
2008 Lime Green ZX-6R DIY Fender Eliminator, Jumper Mod, Yoshi RS-5
My Musical Stuff
Lucian Scott
soc_monki is offline   Reply With Quote
Old 08-09-2008   #5 (permalink)
Slo'Poke
Own The Day
Slo'Poke's Avatar
When I owned a 650R, 5K was adequate for my purposes. As it's been said, you don't want to 'lug' the engine (ie - run it in a gear where it sounds like it's struggling), and my normal cruising speeds was in and around 70 mph. High 40's was a typical mpg at the time.
Nowadays, on my VN900C (no tach), my strategy for maximizing fuel efficiency is to use 20/30/40/50 as shift points, and still use 70 mph as normal cruise speed. I average mid-40s street / low-50s hwy.
Slo'Poke
Alex
'06 Vulcan 900 Classic
Past - '06 Ninja 650R, '03 Vulcan 500 LTD, '91 Shadow VLX
Slo'Poke is offline   Reply With Quote
Old 08-10-2008   #6 (permalink)
kbroderick
Foil Inspector
It depends on how I ride, but I'm generally getting around 60-65 MPG on my Ninjette. If I'm in in-town traffic, I try to keep the RPMs in the 6-8k range (so I can hit 8-9k quickly if need be but still not be obnoxious-sounding) and generally try to make sure I stay above 5k unless I"m on a downslope and don't plan to accelerate at all. If I'm riding in a more spirited manner, it's more likely that my RPMs will be at 8-12k (which is roughly the "power" band on the Ninjette)...and then I'll expect high fifties or around 60 MPG, depending on speed (slab speeds kill my gas mileage).
kbroderick is offline   Reply With Quote
Weird fuel problem with 87 ninja 600RX ninjaVA Kawasaki Streetbikes/Sportbikes 4 05-06-2006 05:52 PM
Fuel & Vacuum Lines jonm61 The Mechanics Corner 2 01-30-2006 02:49 PM
A great disseration on fuel ratings Spok Main Lobby 4 01-02-2006 05:06 PM
Very little fuel coming out the main jets..., why? makenzie71 Kawasaki Streetbikes/Sportbikes 17 02-14-2005 07:39 AM
Restoration ?'s, specifically fuel line connections heffjay9000 The Mechanics Corner 1 02-25-2004 11:09 AM
