Epoxy coating in yer garage
+ Reply to Thread
Results 1 to 17 of 17
Thread: Epoxy coating in yer garage
  1. #1
    Top Gear Full Throttle BTK Expert ratvespa's Avatar
    Join Date
    Feb 2007
    Location
    Las Vegas NV
    Posts
    303
    Default Epoxy coating in yer garage
    has anyone done it? what kind of product did you use? how did it turn out?
    I finally pulled up all the green carpet in the garage, only to find half the garage still has the dookie brown tiles from the 70's stuck on it. so Im guessing I need to rent a tile scrapper and get those up. Other problem might be the tile glue thats stuck to the floor. It's old and dried up, but might not make the epoxy stick. I think most epoxy flooring recommends acid etching the floor, so I might have to also rent a sander and sand the floor down. It's going to be tricky getting all my garage stuff relocated elsewhere while I do this, wonder how many motorcycles I can fit in the dining room? haha
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Patriot Guardian Extreme Forum Supporter RichLockyer's Avatar
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    It looks great, but be careful. The shop floor in the warehouse at my old office was epoxy coated, and brake cleaner attacked it.
    - Rich
    2006 1600 Ultra-Classic
    Patriot Guard Rider
  4. #3
    Husker Rider. Go Bo! Forum Supporter greg58's Avatar
    Join Date
    Oct 2008
    Location
    Nebraska
    Posts
    399
    Quote Originally Posted by ratvespa View Post
    Be careful and wear a mask while sanding/scraping up old linolium tiles. Much of that stuff was made with asbestos.
    Greg58
    1995 KZ1000p Police bike
    1982 KZ750 GPZ
  5. #4
    Daddyo BTK Expert Daddyo Vulcan's Avatar
    Join Date
    Jul 2008
    Location
    Lancaster California
    Posts
    628
    My Father Epoxy coated his garage floor it looked great but the Acid he used to etch the floor about did him in! you will need a good mask with the right cartridges or really good ventilation.
    Loving My Wifey and my '07 VN2000 Classic LT
    Daddyo
  6. #5
    Power Hungry V2K Rider Forum Supporter BigJohn's Avatar
    Join Date
    Apr 2005
    Location
    Lenoir City, TN
    Posts
    6,395
    Couple of points:
    1. Us at least a 1/2 face respirater with HEPA filters while doing the removal. Also, get a tyvek disposable suit to wear. Wet down the tiles and keep them wet, you don't want the asbestos getting airborne. It will get into the house. Keep the garage door open for ventilation. Double bag the tile, put your tyvek suit AND the filters in the bag. Take it to a haz mat drop off point. DO NOT, I repeat DO NOT toss it into the garbage.
    2. For the epoxy - get a couple of organic filters for your respirator. Wear the respirator! Keep the door open while you are preping and painting the door.
    Use caution with all the chemicals.
    '06 V2K LT
    Because RED is the fastest color...
  7. #6
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    Quote Originally Posted by greg58 View Post
    Greg58
    Yup, and they were made until 1980
    Asbestos Tile - Asbestos Resource Center
    $20 and a sample the size of a nickel mailed to Asbestos Fiber Analysis (TEM Test Method) will tell you.
    - Rich
    Patriot Guard Rider
  8. #7
    Need Time To Ride Forum Supporter Baitis's Avatar
    Join Date
    Mar 2008
    Location
    Essex, MD
    Posts
    3,094
    My neighbor epoxied his garage and it's patchy - but he's known to take short cuts. I thought about doing mine until I looked at all the stuff I'd have to relocate, I can live with dirty concrete.
  9. #8
    Cruising In Fourth Gear BTK Intermediate Lazarus's Avatar
    Join Date
    Dec 2008
    Location
    Indianapolis
    Posts
    241
    I have been successful at epoxing concrete, here's what I learned.
    Use 100% epoxies, you'll find them on line at cheapest prices. What you buy at the local home improvement store is likely 70% or so, diluted with a solvent to get better penetration into concrete but proper surface prep make that point moot.
    The 2 most important things are prep and mixing. Wimp out on either and your not happy with the result.
    Prep
    Don't count on acid etching to do the trick. Acid etching is just more convenient but not near as good. Rent a diamond grinder. I rented a stand behind machine for $140 bucks. It is made to get all the way to the edges but won't get that tiny bit at the corners. I used plenty of water with it to keep the dust down and spent several hours running that noisy beast. I'd mask up and probably use that to get the tile up, with water.
    Mixing
    Use the two pot method. Actually measure the components as you use them. Pour parts A and B into one pot and mix well, really well. Now, pour the contents of that pot into a second pot and mix well again. The first pot will have a bunch of unmixed polymer on the edges and that stuff will never harden. Leave it in pot one and accept some loss of material. Buy lots of those dispo buckets.
    Holes and cracks in floor
    If there are pock marks in your concrete deal with them as follows. Soap and water to as clean as possible. Then acid etch the hollows of the pock mark followed by good rinse. Take your epoxy and paint the holes for good adhesion then add fine sand to more epoxy to make a paste and fill the pock marks. Do multiple small batches if you have a lot to do. I used clean butter tubs for this. You can even over fill them and let harden for 24 hr. Now, diamond grind your floor and the epoxy you just added gets shaved to exact height of floor and will be invisible in the end.
    Make some spikes
    I just used liquid nails, a 1 x 4, and drywall screws. To some board roughly the size of my shoe and screwed short drywall screws through the board and then glued them to some discardable tennis shoes. This allows you to walk around on the wet epoxy and do things like throw those colorful sprinkles around and get thin spots etc.
    2 coats
    I used a color base, then sprinkles, and then a clear epoxy over that. I then used a UV resistant polyeurathane over the top as epoxy will yellow under UV. Some prefer to use a colored 2nd coat and mix a bit of sand into to make it non slip as straight up epoxy is slippery when wet.
    Feel free to ask if you have any questions.
    Rick
  10. #9
    Extreme Gizmologist Extreme Forum Supporter mkelley's Avatar
    Join Date
    Oct 2006
    Location
    Berwyn Heights, Maryland
    Posts
    2,339
    Epoxy finishes look good. For a more industrial finish, consider commercial urethane concrete floor sealers, either clear or colored or clear over stained concrete.
    We use colored urethane sealer on our town's outdoor hockey rink. Let me tell you, that stuff is tough!
    -Mike
    my bikes
  11. #10
    Stoopit Moderator ULTIMATE Forum Supporter rbentnail's Avatar
    Join Date
    Jan 2005
    Location
    Asheboro, NC
    Posts
    8,425
    I pulled some carpeting up in my basement and found mid-70s, multi-colored sheet linoleum. The design looked like you chopped up 7 different colors into 1/8" chips then pressed them all together. I would have killed to have dookie brown tiles!! Man, you are so lucky...
    Words aren't children and there's nothing wrong with killing them to clarify a point or keep the peace.
  12. #11
    Join Date
    Feb 2007
    Location
    Las Vegas NV
    Posts
    303
    Quote Originally Posted by rbentnail View Post
    haha, I hear ya man, when I did my bathroom I pulled up 5 generations of vinyl tile and linoleum. when scrapping it you could scrape right through the 90's 80' 70's and 60's. everything I do with this old house is a surprise, I wish I could do my house sportbike style, rhinocoat it or cover it in fur.
  13. #12
    Join Date
    Jan 2005
    Location
    Asheboro, NC
    Posts
    8,425
    LMAO!! That's too funny. Our house was built in '72 so the surprises abound for us too. When we took out a divider wall we found the installers had written on the studs. Those time capsules were about Hank Aaron hitting #715, a kid's school, etc.
    edit: I've long since deleted the pics but here's the post http://www.kawasakimotorcycle.org/fo...ouse-pics.html
  14. #13
    Join Date
    May 2006
    Location
    Chino, CA
    Posts
    28,016
    Had a new furnace installed a few weeks ago. There was an old Dr. Pepper can in the plenum under the furnace between the 1st and 2nd floors. I knew it was there, just never felt like reaching in for it.
    The guy installing the furnace got really excited when I asked him if he wanted it.
    Old style "pop top", but the can was steel... not aluminum... so it was from those transitional years between the old cans that needed an opener and aluminum cans. He said it polished up really nice.
    - Rich
    Patriot Guard Rider
  15. #14
    Tod
    Tod is offline
    Spinach Eating Moderator Extreme Forum Supporter Tod's Avatar
    Join Date
    Aug 2005
    Location
    Round Rock, TX
    Posts
    22,962
    Quote Originally Posted by mkelley View Post
    +1 that's the stuff we had in the Print Shop I worked at as my last Job, that stuff resisted all the inks and solvents we could throw at it, and looks great.
    “Saying what we think gives us a wider conversational range than saying what we know.” - Cullen Hightower
  16. #15
    the "fun" guy Extreme Forum Supporter 2WheelFun's Avatar
    Join Date
    Nov 2004
    Location
    Albion, Washington "Pacific Northwest"
    Posts
    32,859
    I was a painter for over 28 years and I remember a saying from another co-worker. He said one thing you don't see too many of are...old painters.
    Using all the protective gear you can is important while doing an inside job...even a garage. Ventilation is paramount while you spread those volatile vapors. What you put into the prep work will determine how good the job will be and how long the finish product will last. Don't skimp on the prep work and use a quality finish product and it should turn out well for you.
    ***KING KAHUNA***
    ***2007 V2K LT***
    2007 Brute Force 650i
    *I love the smell of SeaFoam in the morning*
  17. #16
    Join Date
    Feb 2007
    Location
    Las Vegas NV
    Posts
    303
    haha, thats cool, I had something similar happened when I was redoing my bathroom. I toor out the vanity and went to smash the mirror to remove it. when I broke it, these pics and a weird love buisness card fell out the back.
    whats even stranger is, a few months later some guy was hanging out in front of my house, so I went to see whats up. he exsplained he used to live here, and was just bored driving around. I looked at him and he looked kinda familiar. so I ran it and showed him the pic, turns out it was his parents. he kinda gave me the run down on the house "that patched section above the door is when my dad was cleaning his gun and it went off". he also explained a bunch of other stuff about my old house that made no sense.
  18. #17
    Evil Doer BTK Expert MauiAl's Avatar
    Join Date
    May 2007
    Location
    Butt Crack Oregon
    Posts
    2,231
    I spent 34 years painting things. Honestly I never recommend painting a floor but if you do the preparation is the most important part, if you want the stuff to stick.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Space heater for the garage.
    By ALStensby in forum Off Topic
    Last Post: 11-10-2008, 11:50 AM
  2. G is for Garage door
    By Obsidian16825 in forum Off Topic
    Last Post: 09-01-2008, 11:31 PM
  3. Automatic High Beam Garage Door Opener Thingie
    By BigJohn in forum Kawasaki Cruisers
    Last Post: 12-14-2007, 06:24 PM
  4. Ordered the new garage door today.
    By trikebubble in forum Off Topic
    Last Post: 04-08-2006, 09:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
