Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Off Topic
Old 03-27-2007   #1 (permalink)
JTpaintball70
has a surgically implanted keyboard
JTpaintball70's Avatar
Send a message via AIM to JTpaintball70 Send a message via MSN to JTpaintball70 Send a message via Yahoo to JTpaintball70
Default For anyone who does any kind of wrenching
I know this might be a repost but I can't remember which forum I've seen it on, so here ya go. Hope ya get a laugh out of it
Tools and their REAL uses:
DRILL PRESS: A tall upright machine useful for suddenly ******ing flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "Yeouw s--t...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. The most often the tool used by all women.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or ½ socket you've been searching for, over the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. The accessory socket within the base, has been permanently rendered useless, unless requiring a source of 117vac power to shock the mechanic senseless.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids, opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. Women excel at using this tool.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 30 years ago by someone at Ford, and instantly rounds off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. Women primarily use it to make gaping holes in walls when hanging pictures.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. It is also useful for removing large chunks of human flesh from the user's hands.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also, most often, the next tool that you will need.
Nathan
My Photobucket
2007 ZX-6R
2007 Ninja 650R aka Shion - STOLEN 2-4-08
2001 Jeep TJ
NM EMT-Basic
JTpaintball70 is offline   Reply With Quote
Old 03-27-2007   #2 (permalink)
james t. kirk
two can play at this game
james t. kirk's Avatar
My Father is a grumpy, cantankerous, women chasing , p*ssy hound. He did didn't teach me much, but he did teach me two useful things. How to swear, and to shine the light where he is looking not were I am looking.
james t. kirk is offline   Reply With Quote
Old 03-27-2007   #3 (permalink)
Jake '53
TROUBLE LIGHT: Also used to put small oval 1st degree burns on the backs of arms and foreheads.
"Certainty of death. Small chance of success. What are we waiting for?" - Gimli
Jake '53 is offline   Reply With Quote
Old 03-27-2007   #4 (permalink)
ispeed77
RIP Deron Harden :-(
ispeed77's Avatar
Send a message via AIM to ispeed77 Send a message via Yahoo to ispeed77
someone emailed that to me not too long ago and i still haven't stopped laughing
David - Moderator
2002 Suzuki DRZ400
2003 1500 Meanie, scraping pipes and frame :-)
In loving memory of Deron Harden, forever in our thoughts :-(
ispeed77 is offline   Reply With Quote
Old 03-27-2007   #5 (permalink)
runnerb0y
runnerb0y's Avatar
JTpaintball70,
Very funny, thanks for sharing.
My personal favorites....
and
Both of them are so true at my house.
'06 Meanstreak with some personal touches
Historic Balch Hotel
runnerb0y is offline   Reply With Quote
Old 03-27-2007   #6 (permalink)
metalesp
August 2008 M.O.M.
metalesp's Avatar
Now that's a very usefull tool list... And I happen to have a few of those...
Especially the Dammit Tool. Actually I have several of these
Eddie ~1982 KZ305CSR~
Something Wicked This Way Comes
metalesp is offline   Reply With Quote
Old 03-27-2007   #7 (permalink)
Alf
Alf not Elf
Alf's Avatar
Man does that bring back memories not the p*ssy hound part because we didn't have any cats. . Now swearing and shining the light properly not in his eyes but where he was looking was verrrrry important. failure to do it properly gots lots of threats but no results.....
When arguing with a idiot make sure he isn't...
My bike 900 LT Red/Black.
Alf is offline   Reply With Quote
Old 03-27-2007   #8 (permalink)
Nate
KZ Kool!
Nate's Avatar
Pliers and Vise-Grips are the most oft abused tools around a farm.
BTW, the origin of Vise-Grips and the main factory for years is located not far from here in Dewitt, Nebraska.
"Riding is the reward for time spent wrenching."
"Wrenching is the result of time spent riding!"
KZ650 SR
Nate is offline   Reply With Quote
Old 03-28-2007   #9 (permalink)
RichLockyer
RichLockyer's Avatar
Broken clutch cable on a RoadStar? Not a problem!!!
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
Old 03-28-2007   #10 (permalink)
Billy D.
Loves Burning Rice!
Billy D.'s Avatar
It would not be so funny if it were not soooooo TRUE! Thanks for sharing that with us!
Billy D. is offline   Reply With Quote
Old 03-28-2007   #11 (permalink)
2WheelFun
2WheelFun's Avatar
Ohhh yeah....I've enjoyed almost losing my hand once with one of these babies!!!
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 03-28-2007   #12 (permalink)
pitchinguy
I miss Deron.
pitchinguy's Avatar
Zactly!! Good stuff!
LIGHT ENGINEER Todd's Body Paint Team
Black 1600w/apes
aka Scooter
pitchinguy is offline   Reply With Quote
What kind of increased performance out of a VN900 CootoronScooter Kawasaki Cruisers 9 03-11-2007 09:56 PM
What kind of tires do you use? kunoichii Kawasaki Streetbikes/Sportbikes 24 09-30-2006 09:30 PM
Kind of an off-color question (ladies be warned!) DrX512 Off Topic 35 07-24-2006 09:58 PM
What kind of fuel for a LTD 454 Synthy Kawasaki Cruisers 1 02-05-2006 08:19 AM
what kind of muscle car are you zedx11 Off Topic 32 01-28-2006 02:34 AM
