Go Back   Kawasaki Motorcycle Forums > Welcome to Kawasaki Motorcycle Forums! > Off Topic
Old 04-10-2008   #1 (permalink)
vulcancowboy
Love my 1500!
vulcancowboy's Avatar
Talking Tool Definitions
DRILL PRESS: A tall upright machine useful for suddenly ******ing flat metal bar stock out of your hands so that it smacks you in the chest and flings your soda across the room, splattering it against that freshly-stained heirloom piece you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, 'Yeouw....'
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age, or for perforating something behind and beyond the original intended target object.
SKIL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. Caution: Avoid using for manicures.
HACKSAW: One of a family of cutting tools built for frustration enhancement. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 45 minutes.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use.
RADIAL ARM SAW: A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to move out of its way.
CRAFTS MAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, 'the sunshine vitamin,' which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40- watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. The accessory socket within the base, has been permanently rendered useless, unless requiring a source of 117vac power to shock the mechanic senseless.
PHILLIPS SCREWDRIVER: Normally used to stab and remove oil filters, opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact gun that grips rusty bolts which were last over tightened 40 years ago by someone at VW, and instantly rounds off their heads. Also used to quickly snap off lug nuts.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit.
BOX CUTTER KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. It is also useful for removing large chunks of human flesh from the user's hands.
DAMMIT TOOL: (I have lots of these) Any handy tool that you grab and throw across the garage while yelling 'DAMMIT' at the top of your lungs. It is also, most often, the next tool that you will need after using a really big hammer.
Jim/1500 Classic
"Be still and know that I am God" Psalm 46:10
vulcancowboy is offline   Reply With Quote
Old 04-10-2008   #2 (permalink)
Michael600r
Ninja tomato farmer
Michael600r's Avatar
I have most of those tools!
Ninja 600R
Ninja500R, sold
Michael600r is offline   Reply With Quote
Old 04-10-2008   #3 (permalink)
KwakaKZ1000
Back in traffic
KwakaKZ1000's Avatar
How true, the voice of experience. Those are funny only when it happens to someone else. LOL
01 1100 V Star Classic
1980 Kawasaki KZ1000
Colin
KwakaKZ1000 is offline   Reply With Quote
Old 04-10-2008   #4 (permalink)
antiq
Vintage bike addict
antiq's Avatar
I have all those tools!
Patience and persistance- pays
82 KZ750LTD
78 KZ750 twin
Vince
antiq is offline   Reply With Quote
Old 04-10-2008   #5 (permalink)
anrfknm
humble pie consumer
anrfknm's Avatar
whoever wrote that, knows his tools.
vroc #13815 - rolling blunder #182 AMA member
http://www.cruisercustomizing.com/anrfknm
anrfknm is offline   Reply With Quote
Old 04-10-2008   #6 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
I'm laughing so hard I have tears in my eyes.
Whoever wrote that forgot to mention the crescent-hammer and screw-chisels that are in my toolbox.
Shawn Lattimer
'06 Silver V2K Classic VROC #22980 ROG #464
http://www.shawnlattimer.com
Lattimer is online now   Reply With Quote
Old 04-10-2008   #7 (permalink)
botz723
botz723's Avatar
me too!
2009 HD FLSTF FAT BOY
VROC # 25324
AMA Member
Mike
botz723 is online now   Reply With Quote
Old 04-11-2008   #8 (permalink)
metalesp
August 2008 M.O.M.
metalesp's Avatar
I have most of those tools too.
Eddie ~1982 KZ305CSR~
Something Wicked This Way Comes
metalesp is offline   Reply With Quote
Old 04-11-2008   #9 (permalink)
V2K_CCTX
RIDING LIKE I STOLE IT
V2K_CCTX's Avatar
too funny
07 ZX-14 BLACK
07 CBR600RR LTD ED
07 GV-650 BLUE
07 VULCAN 2000 LT
07 Ninja 250 Silver
V2K_CCTX is offline   Reply With Quote
Old 04-11-2008   #10 (permalink)
fretbuzz
Non Omnis Moriar
fretbuzz's Avatar
That's hilarious.
OXYACETYLENE TORCH (alternate use): Used to fry up pork sausage on an I-beam in shop class -the same pork sausage you were supposed to sell as a fund-raiser. (the result of too many football players in the same shop class)
I'd rather you offend me with the truth than appease me with a lie.
fretbuzz is offline   Reply With Quote
Motorcycle Tool Kits Drifter Main Lobby 26 11-08-2007 08:43 PM
Key Registration special tool poison The Mechanics Corner 17 10-25-2007 02:50 PM
Tool Wranglin' Matt7even Kawasaki Cruisers 0 05-26-2007 09:45 AM
Mechanics tool uses 1400pilot Off Topic 19 12-25-2005 03:14 PM
shock tool archer Kawasaki Streetbikes/Sportbikes 0 10-09-2004 12:52 AM
