zx-11/250r
I have a 2001 pontiac grand am se v-6. It is giving me problems and I dont know what else to do at this point. Any ways, I replaced both the intake gaskets because they were leaking. In the process I had to let it sit for about 6 months. I changed the oil and it has fresh gas. During that time about 3 of the coils got some rust on them. I cleaned them the best I could get them, still a little rust but about 85% rust free now. I cleaned them and I started it up, all is well except for a sputtering noise coming from the exhaust and the engine vibrates. I think its only 1 cylinder not firing, maybe 2 but I cant figure out which on it it, I have put water on all the headers and all are hot. Ocasionally I will get a misfire code (check engine light flashes). I turn it off and restart, the check engine stays on, I disconnect the battery for about 10 seconds to reset the code and I start it up, no codes this time but still not firing one cylinder. I pulled the wires off the coils again and recleaned them, fired it up, misfire code again, reset and it went away but still dead on one cylinder. I am lost at this point. Car ran great prior to intake gaskets. What else do I need to do?
#4 (permalink) |
Forensic Bug Splatter Analyst
Get it running.
Pull one ign. lead at a time to disconnect from coil, if idle/smoothness changes you know it's not that cylinder that has a bad plug/lead/coil. You will pull one off and no change in sound/rpm/shakiness will occur...found it.
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
#8 (permalink) |
zx-11/250r
Ok, I went over everything again, It seems that all cylinders in front and one in back are dead, funny thing is that the manifold is getting hot with each cylinder though, I pull the coils and it doesnt change the way it runs. According to that, I have only 2 cylinders fireing but yet they all get hot? I dont understand.
#10 (permalink) |
Can't find time to ride
Don't know about Pontiac coils, but I do know Ford had a bunch of junk on their assembly line. Replacing all them may be your only option if they are beginning to break down internally.
I don't own any GM products, and I haven't worked on one in over 20 years, so my experience and advice might not be worth the time it took you to read this. Might be an air leak somewhere besides the intake gaskets, though.
Later, Charlie ----------------------------------------- I like women plain, not battered. |
#11 (permalink) |
where's reverse?
It is a wasted spark ignition system, fires on both tdc's. #1 & #4 share the same coil, #2 & #5, #3 & #6. The thing I have seen get alot of people doing the job at home is the fact that the pushrods are different lengths, intake 5 & 3/4 inches and may have a yellow mark, exhaust 6 inches and may have a green mark. Coil corrosion on these is very common, we normaly replace all and plug wires.
#13 (permalink) |
zx-11/250r
Ok, Thanks for the advice guys, I think I found the problem, after messing around wtih everything on the coils, they check out just fine, turns out I have a few bad o-rings on the injectors causing them to allow too much air in the chamber which is why the manifolds get hot. Tomorrow, Ill take it apart and replace them and all should be good from there, hopefully. Thanks guys
#14 (permalink) |
where's reverse?
Yes they have pushrods, the 3.4L in the 90's was a DOHC. Go to the dealer and get an injector o-ring kit, they will be blue in color and it has 12 o-rings and the 6 plastic collars that go on the lowers. Just put a light coat of oil on them before you install.
#16 (permalink) |
zx-11/250r
There was a loud hissing noise coming from it and for the long time I couldnt find out where it was coming from until I put a screw driver on the injector and it started to change tunes so I knew it was coming from there.
| X-rated nude car wash gets police all-clear | anamosity | Off Topic | 41 | 08-20-2008 09:30 PM |
| Deer VS Company Car | SLSChic | Off Topic | 33 | 05-06-2007 08:01 AM |
| 2 mistakes cost me my car | Pistobah | Off Topic | 48 | 04-27-2007 10:01 AM |
| My bike, car and my bros car | o0speedy0o | Kawasaki Streetbikes/Sportbikes | 4 | 09-26-2006 05:10 PM |
| Wtt: 11 Sec Car For Bike | 93redgsx | Streetbikes Buy/Sell/Trade | 2 | 07-09-2006 06:05 PM |
