#24 (permalink) |
Cruising In Fourth Gear
Thanks Chad, There is 1" clearance. I thought about taking it a little lower since the wheel, fender and swing arm all travel as one unit with no threat of tire scrubing the fender as before when the fender was mounted to the frame. but 1" looks good.
#26 (permalink) |
Yet another 800 Bobber...
Nice bike but I think of it more of a chopper, not a bobber. I don't think you should paint the forks black but rather get them polished, that would fit the bike better. Something says me you are thinking of getting apes? The handlebars you allready have blends in very well, keep them! Good luck!
VN800A -95, work in progress |
#27 (permalink) |
The mini cat eye turn signals came with a threaded mounting stud 10M x 1.50 thread. I need a 10M x 1.25 thread to screw into the the hole in the frame where the stock strut bolts were. Currently i have them mounted but they are bearly screwed in. I haven't been able to locate any yet. I guess they could be made with a pipe & tap & die or drill out a hole in a bolt? any suggestions?
#28 (permalink) | |
Finally Got Into First Gear
#29 (permalink) |
I haven't decided what to do with the other hole yet. How's yor project going? I like the forks and tree's painted like the pic below of scoot works,"Old Skool" and IMB4U's Bobber
![]() ![]() Last edited by goddarddr : 04-13-2009 at 06:03 PM. |
#31 (permalink) | ||
#33 (permalink) |
Bobber Builder
The best way to paint the triple trees and the fork lowers is to take the wheel off and slide the forks out of the triple trees. May seem like more time then just taping but it is very clean afterwards. Also Is your bike still lowered 3", looks like your fender must hit the seat a lot? you have that problem?
Steve 99 Vulcan 800A Bobber 06 Harley Street Glide |
#34 (permalink) |
Steve,thanks for the paint tip. Yes 3" lowered in the rear. No I have not had any problem fender / seat scrub. there is more clearance than it looks, see in the earlier pic above with the train car in the background. Maybe? because its low, the swing arm doesn't have as far to travel?? when I had the frame mounted stock fender, the tire would sometimes scrub the fender when it hit a big bump or dip.
#35 (permalink) | |
#36 (permalink) |
Waiting for happy hour
I want to do an 800 bobber some day.....and it will be flat black. Some old school pinstriping would look cool on yours.
2007 Vulcan 900 Classic'ish Custom LT ??? (Yeah it's all mixed up!) |
#37 (permalink) |
Currently, I 'm trying to figure out to raise the back of my seat a couple of inches for leveling and comfort. I tried to mount 3" springs yesrterday, but wasn't satisfied. Now I 'm thinking of new mounting idea's and open to suggestions. That is part I like, trying, thinking, asking, searching, creating, learning, growing = LIVING LIFE : )
#38 (permalink) |
I remember El Skitzo writing about adjusting his seat for the same reasons. I did a quick search and found the thread "Bobber makeover - El Skitzo Flako will ride again!" It has the text, but all the pictures have been removed. If I remember it right, he bent some flat bar in an "s" shape and bolted it to the rear seat support. I'll be working on my seat this week and will try to get some pics up by the end of the week. I've got a hinged bracket in front bolted up with the gas tank. For the back, I took some 1/4" flat bar, heated it up and bent it around a large diameter pipe that was laying nearby. My next step will be to cut the rounded bar to length and get it bolted up. Hopefully, it will go together and look close to what what I have pictured in my head.
#40 (permalink) |
Turtle Wax Taster
Looking good. I'd take the chaingaurd back off. I haven't had one on in a long time and it's fine with out it( so far anyway) I haven't painted fork lowers but with the black fork gaiters it looks ok. If you change your bars and risers to something different i think it'll look nice,(the best part of a bobber is the expensive shiney stuff doesn't look good on it so everything can be on the cheap and used side) I painted my headlight, and front blinkers flat black and it looks a lot better than it did chrome and It's holding up well as is my paint on everything else. Good luck and have fun.
| VN800 Bobber project | CustomVN | Projects and "How To" Write Ups | 256 | 08-22-2009 10:56 AM |
| Just bought my first bobber project. | tatman1315 | Kawasaki Cruisers | 4 | 02-28-2009 07:29 PM |
| Best Bike for a Bobber Project | SA_Greeni | Kawasaki Cruisers | 16 | 08-28-2008 11:05 AM |
| Removing Bobber project pictures | El Skitzo | Kawasaki Cruisers | 3 | 12-11-2007 03:55 PM |
| Yay, Norm! | jukief | Main Lobby | 93 | 01-26-2006 12:02 PM |
