#41 (permalink) |
Cruising In Fourth Gear
Thanks for the feedback Billy. I am currently focused on getting my seat mounted comfortably and wondering about mounting the battery where the right cover is and hiding the electronic's in the hole the battery left behind. just Thinkin Out Loud. anyone hear?
![]() like this bike Last edited by goddarddr : 05-03-2009 at 09:27 AM. |
#42 (permalink) |
here's pic's of my seat bracket that I made from 2 pieces of 1.5" angle steel bolted together and to the frame. it raised the rear of the seat and made a more comfortable ride. it might just work.
![]() ![]() ![]() I have been thinking about mounting the battery on the right side. I did a mock-up and found that there is plenty of room. ![]() Last edited by goddarddr : 05-06-2009 at 09:34 PM. |
#43 (permalink) |
Finally Got Into First Gear
The battery move looks great. Are you going to have to get longer battery cables? Did you have to cut any of the plastic? How are you going to secure the battery in place? It seems like it would be an easier mod than moving the ignitor and fuse box like some knuckle-draggers have done.
#44 (permalink) |
Now that I know there is room, I will be finding the answeres to these questions. I do have a simple idea on the mount, drill and tap 4 holes and 2 pieces of flat stock and a strap. at a glance I don't think I will need longer cables. (? might) I did removed the plastic tool box. I figure I will put the ignitor and fuse box in the battery box. I like the look of the side mount battery. I wonder which ones of the wires could be eliminated? like a bowl of spegetti under there. : ) There is some ugly welds that could be grounded smooth. I think I will cut off the passenger peg mounts too.Sounds like you have some idea's about your fender mounting. It will be worth the wait.
#47 (permalink) |
No, I have read that lowering I would, but it works fine. I used the scootworks low rider kit it is adjustable 1"-3", mine is on the 3". I am short but I have feet flat on the road now. I had to mod the shock with the spacer kit.
#48 (permalink) |
Bobber Builder
The kickstand only needs to be replaced when you lower the front as well. I have mine lowered 2" in the front and 2" in the back and had to get a vulcan 900 kickstand or the bike would be straight up and ready to tip.
Steve 99 Vulcan 800A Bobber 06 Harley Street Glide |
#50 (permalink) |
My bike is lowered 1" in the front & is ok with stock stand. here is a pic with improved seat position
![]() In this pic, I have the bike leaning to the right on a block for leveling picture. don't mind the kick stand , it is off the ground Last edited by goddarddr : 05-11-2009 at 10:47 PM. |
#51 (permalink) |
Turtle Wax Taster
Looking good, I got mine back together in a rush to take it and get it pinstripped however I don't think I'm going to do it. I'm going to go down and watch though and maybe I'll change my mind. I'll post pics of the painted lowers when I get back
#52 (permalink) |
Thanks for posting. Pin stipe? I never thought of that. stay in touch and lets see your pic of painted lowers. what is that black thing between your front forks? The majic paint they carry at the tennessee farmers co-op. but the one I checked didn't have flat black. less than $4 a can.
Later, Dave |
#53 (permalink) |
mean green machine
I have 2 1600 meanstreaks 04 and 05. I am trying to raise the handlebars up and back a little to save the back a bit on those 500 mile days. Dealer tells me I have to switch the bars out completely since they are welded. I know I once saw a meanstreak in Bend Or dealer ( no longer there!!) that had risers. Any help would be greatly appreciated. leaving in a trip through Alberta/BC in August and would like to be a bit more comfortable but not too radical!! Thanks
#54 (permalink) | |
Turtle Wax Taster
That thing between my forks is a bandana. I didn't care much for the black lowers until I put the bandana back on, I like it now though. The paint is Matte black and runs about 3.50 for a spray can or is available by the quart or gallon. If for some reason you cant find anything that will hold up I could ship you some for whatever it costs for the paint and shipping. I used about 4 cans to do everything. So with sandpaper tack cloths, primer and everything my paint job cost about 25 bucks. The pictures I took didn't turn out good but you get the point. I can never get pictures to upload right so if it doesn't work here's the link Picasa Web Albums - billy - 5/9/09 vn800 |
#55 (permalink) | |
Turtle Wax Taster
#57 (permalink) |
Billy, the bandana does that keep the water off your face? The other day I was ridin went through a wet spot got water in my face, Im glad a had my full faced helmet on. Oh well part of the fun, I normally avoid the rain. also my half rear fender didn't keep my back dry either. : ), I like your black lowers, I appreciate the paint offer, I will check around town first. Do you use a paint primer?
#58 (permalink) | |
Turtle Wax Taster
Yes I use primer, same brand as the paint. I usually give the primer 2 coats then use a scuff pad on it, then paint 2 coats and scuff pad it then paint 1 or 2 more coats and let it sit for a few days then use the rubbing compound and then the polishing compound and it comes out as smooth as flat paint can be. |
| VN800 Bobber project | CustomVN | Projects and "How To" Write Ups | 256 | 08-22-2009 10:56 AM |
| Just bought my first bobber project. | tatman1315 | Kawasaki Cruisers | 4 | 02-28-2009 07:29 PM |
| Best Bike for a Bobber Project | SA_Greeni | Kawasaki Cruisers | 16 | 08-28-2008 11:05 AM |
| Removing Bobber project pictures | El Skitzo | Kawasaki Cruisers | 3 | 12-11-2007 03:55 PM |
| Yay, Norm! | jukief | Main Lobby | 93 | 01-26-2006 12:02 PM |
