Old 06-27-2009   #81 (permalink)
goddarddr
Cruising In Fourth Gear
goddarddr's Avatar
Thanks Chad, I appreciate your kind words and your work also.
I filled the holes today in my handle bar clamp,I don't need to spend 150$ on a new clamp. I will sand then get the spray can. thinkin about spraying the head light too. what about those front signals/ forks look better without them-but safety? I noticed IMB4U took his off and looks great.
Here in Nashville it's too hot and humid for me to ride, so I will Mod-I-fy : )
goddarddr is offline   Reply With Quote
Old 07-01-2009   #82 (permalink)
goddarddr
goddarddr's Avatar
Default workin the front
painted upper clamp, replaced the scootworks 4" phat risers with 2" stock risers
I left the chrome turn signal clamps off, the black rubber ones look better.
Old 07-01-2009   #83 (permalink)
goddarddr
goddarddr's Avatar
Old 07-04-2009   #84 (permalink)
goddarddr
goddarddr's Avatar
I am thinking the front turn signals and mirror seem out of place. i feel i need them for safety, so I would like to make them smaller and less noticed.
Old 07-10-2009   #85 (permalink)
goddarddr
goddarddr's Avatar
first time: I had a problem with the idle. bike wouild not keep a consistent idle speed. it ran fine but at low speed it was rough and at stop it would be high then next it would be low. I replaced the plugs solved the problem its fast and fun agian.
Old 08-10-2009   #86 (permalink)
goddarddr
goddarddr's Avatar
making some progress on the front of my bobber.
painted the head light, mirror, lower tree
replaced the front turn signals with the small black cat eye like the ones on the rear and relocated them on the horn mount. cleaned up the front.
plan to paint the lower legs. thinkin about 10" apes flat black but I might try to rattle can the bars I have just to see what happens. then the control housings, the rear brake light, and then, and then, and then...................
I'll post pic's soon. Dave
Old 08-13-2009   #87 (permalink)
Chadsquats
Finally Got Into First Gear
Chadsquats's Avatar
Looking forward to the pics. Make sure there's no black in the background, or we may not be able to see your bike. It sounds likes it's getting pretty Stealth.
Chadsquats is offline   Reply With Quote
Old 08-13-2009   #88 (permalink)
goddarddr
goddarddr's Avatar
Old 08-16-2009   #89 (permalink)
goddarddr
goddarddr's Avatar
here is pic with newest mod's
Old 08-17-2009   #90 (permalink)
Chadsquats
Chadsquats's Avatar
Did you move your horn or remove your horn? You probably wrote about that earlier in this post, I'm just too lazy to go back and look.
Old 08-18-2009   #91 (permalink)
rsktkr
No Expert/No Novice
rsktkr's Avatar
I like the air cleaner cover. Did you paint the center black?
2008 Kawasaki Vulcan 500
Makin' my way the only way I know how.
rsktkr is offline   Reply With Quote
Old 08-18-2009   #92 (permalink)
goddarddr
goddarddr's Avatar
air breather is a Dragtron II rattled can flat black
Old 08-25-2009   #93 (permalink)
Danase
Way Too Much Free Time
Where did you get your license plate frame and brake light? Also is the light bright? LED or regular bulb?
Thanks!
Danase is offline   Reply With Quote
Old 08-25-2009   #94 (permalink)
goddarddr
goddarddr's Avatar
here is the link to the side mount. I had to modify it a little I mounted it to the small bolt that holds the chain guard on. you can spend alot of $$$ on one but i didn't and I am : ). check it out at eBay Store - seat pan: harley, gussetts, Jesse James Rival
let me know if i can answer any ? you have to decide what style of light you will use and buy a bracket that fits the light. good luck
Dave
Old 08-25-2009   #95 (permalink)
goddarddr
goddarddr's Avatar
Front Work--Black Legs, trees,head light and relocated / replaced indicators
blacked out foot pegs
Old 08-25-2009   #96 (permalink)
goddarddr
goddarddr's Avatar
coming soon -bars & grips
Old 08-26-2009   #97 (permalink)
Danase
Dave
Thanks! Is the light pretty bright?
Old 08-26-2009   #98 (permalink)
Danase
What size rear tire are you running? Stock 140/90?
Old 08-26-2009   #99 (permalink)
goddarddr
goddarddr's Avatar
seems bright enough regular bulb. yes it is a stock tire, looks fat cause of the half fender. Dave
Old 08-26-2009   #100 (permalink)
Danase
Did you buy the light from that guy too? Can any brake light mount to it?
thanks!
VN800 Bobber project CustomVN Projects and "How To" Write Ups 256 08-22-2009 10:56 AM
Just bought my first bobber project. tatman1315 Kawasaki Cruisers 4 02-28-2009 07:29 PM
Best Bike for a Bobber Project SA_Greeni Kawasaki Cruisers 16 08-28-2008 11:05 AM
Removing Bobber project pictures El Skitzo Kawasaki Cruisers 3 12-11-2007 03:55 PM
Yay, Norm! jukief Main Lobby 93 01-26-2006 12:02 PM
