#141 (permalink) |
Moto Mez
That's why I only do one circuit at a time and when I finish it hit the starter button. A lot less stress. My cousin did the whole wiring for his buddy and didn't check each circuit and had to go back through it. But at least you didn't have to go through that.
#143 (permalink) |
Cruising In Fourth Gear
I got home, turned the key the only thing I got was the Tail-brake light,
I guess I opened a circiut. I had removed the kick stand switch,fan switch, is one of these the problem? Help : ( |
#144 (permalink) |
Project Bobber
Normally the bike will cut out or not start if its in gear and you don't have the side stand switch. But it shouldn't make a difference if you are defo in neutral. But I have had these go faulty so just link it out.
Thats all I know that might help?
If it ain't broke....... you didn't let me have a go!! Successfully taking the p*ss since 1978 |
#147 (permalink) |
Thanks Guys for your responses, bike is in neutral, fuses are good. I got juice but not to the place makes it crank? I did take out some wires after folowing from the connector. I'm lookin for the "simple thang"
#149 (permalink) |
Bobber Builder
I just cut it back to under the seat I didnt actually take any wires out of the fuse box. I didn't want to get to deep. But not sure how that matters because when the kick stand is up it is an open wire anyways?
Steve 99 Vulcan 800A Bobber 06 Harley Street Glide |
#150 (permalink) | |
Project Bobber
So the stand when it is down will push a switch in and break the circuit..( I know its prob not this but hey while were are on I'm interested to know these things while I'm pulling mine apart!!)
#151 (permalink) |
I'm tryin to figure out this wad of spagetti.......
I got no crank- makin me Kranky I know it's just a problem to be solved a lesson to be learned for me and for all Thinkin out loud Last edited by goddarddr : 4 Weeks Ago at 03:30 PM. |
#152 (permalink) |
Moto Mez
Do you have a repair manual for it? If you do you need to go one circuit at a time and check your work. Make sure that if you cut something out it wasn't supposed to be tied into something else. I am guessing it is your stand switch since you said it didn't crank after you got rid of it.
#153 (permalink) |
I been lookin at the manual diagrams, so when a wire from one switch leads to and connects to another switch, i opened the curciut when I rid a wire from one of those switches? is the negative wire is black/red?
#154 (permalink) |
I ain't kranky no more cause my bike is Crankin
The problem was the engine stop switch,which I had removed 3 weeks ago. My mistake was: last weekend I removed the 2 stop switch wires from the female side of the connector back to the fuse box, which opened the ignition circuit, creating the no-crank problem like Alley said," Make sure that if you cut something out it wasn't supposed to be tied into something else." the yellow/ green stripe wire leads to the ignition fuse and the black/red stripe wire leads to the negative battery ground. removing the stand, fan, switches had no effect. Now I can get on with my project. I have moved the fuse box and igniter to right side cover and have thinned out my wiring harness, I need to mount the f.box & ignitor, wrap all the wires up, and cut the back part of the plastic box off were the fuse & igniter were mounted. See what it looks like with the exposed swing arm, and then? then? then? then?then? : ) Thanks Guys, Last edited by goddarddr : 4 Weeks Ago at 10:58 PM. |
| VN800 Bobber project | CustomVN | Projects and "How To" Write Ups | 256 | 08-22-2009 10:56 AM |
| Just bought my first bobber project. | tatman1315 | Kawasaki Cruisers | 4 | 02-28-2009 07:29 PM |
| Best Bike for a Bobber Project | SA_Greeni | Kawasaki Cruisers | 16 | 08-28-2008 11:05 AM |
| Removing Bobber project pictures | El Skitzo | Kawasaki Cruisers | 3 | 12-11-2007 03:55 PM |
| Yay, Norm! | jukief | Main Lobby | 93 | 01-26-2006 12:02 PM |
