Old 3 Weeks Ago   #161 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
I was meaning use the stock pipes and build a set that would fit the bike more. Like some shotgun pipes or bird shooters. They are really simple to build.
Live a little...upset the balance
http://fivepointfabrication.blogspot.com/
Alley Rat is offline   Reply With Quote
Old 3 Weeks Ago   #162 (permalink)
goddarddr
Cruising In Fourth Gear
goddarddr's Avatar
shotguns and bird shooters. hmm? could you post some examples of that
artillery? thanks, Dave
goddarddr is offline   Reply With Quote
Old 3 Weeks Ago   #163 (permalink)
ramashkaus
Can you please post a closeup pic of the fusebox plastic area behind the seat. How and where did you cut it?
ramashkaus is offline   Reply With Quote
Old 3 Weeks Ago   #164 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
I'll get some up today when I get home.
Old 3 Weeks Ago   #165 (permalink)
goddarddr
goddarddr's Avatar
Alley Rat, lookin forward to it.
Ram chadsquats has good pic of cutting the plastic that hides the swing arm check out at http://www.kawasakimotorcycle.org/fo...ll-over-4.html
Old 3 Weeks Ago   #166 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
My friend Phil's bike. Bird Shooters
http://i266.photobucket.com/albums/i...p/100_2295.jpg
Couple of different variations of shotgun pipes.
Brother's Bike
Previous set of mine.
Current set.
Old 3 Weeks Ago   #167 (permalink)
goddarddr
goddarddr's Avatar
real kool Bobber's. like the 1st pic, brothers bike with straight black extensions. are they too loud with no muff? thats a unique seat bracket looks like the cross brace that most seats are mounted to is gone?
Old 3 Weeks Ago   #168 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
The only set that was too loud was the fish tails. That fish tail did something to resonate the exhaust and they were super loud. All the others have a great tone that isn't too loud and still perform good.
Old 3 Weeks Ago   #169 (permalink)
goddarddr
goddarddr's Avatar
how you do that? might have to practice on that old OEM pair
what kind of paint did you use that can hold on to the hot pipes?
Old 3 Weeks Ago   #170 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
I came up with a design in my head and got some bent pipe from the local muffler shop. I cut the flange off with about and inch of pipe on it to start from. The paint is VHT. It is a lot better than dupli-color high heat paint. It can withstand heat from 1300-2000 degrees. It doesn't fade like dupli-color either.
Old 3 Weeks Ago   #171 (permalink)
Danase
Way Too Much Free Time
Dave,
Look at my bobber project. I just made a set of pipes by cutting up my existing Hard Krome's. It was really easy. I got them back from the sand blaster this week and already have them primered and painted in high temp semi-gloss. They look great. Saturday I'm wrapping them in heat wrap and hope to have them on Sunday. I'll take video of the sound when I'm done. I also have a set of 4" long removable baffles for them that should add a little back pressure.
Danase is offline   Reply With Quote
Old 3 Weeks Ago   #172 (permalink)
goddarddr
goddarddr's Avatar
Originally Posted by Alley Rat View Post
I came up with a design in my head and got some bent pipe from the local muffler shop. I cut the flange off with about and inch of pipe on it to start from. .
so ?,,,,,,,,,,,,, you cut with a hack saw? and only leave 1" of the oem pipe coming out of motor? then wield new pipe? do you have to make and wield a mounting bracket? with no baffle performance is still good?
Old 3 Weeks Ago   #173 (permalink)
goddarddr
goddarddr's Avatar
where I have been
where I am today
Old 3 Weeks Ago   #174 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
I cut it off with an angle grinder. I like using the stock flanges because they won't bend like aftermarket ones and it has that inner pipe that serves as a little power cone at the head. I just build from there and you do have to make new mounting brackets. I just weld bolts to the back and make brackets to go to them. I have never dyno tested my bikes with these pipes on it but I have never noticed a loss of power except with the shotgun fishtails. They were just too short. I don't care about a dyno test. The only thing that matters to me is if there is a noticeable change. But just design a set that you can put some baffles in so you know you got some back pressure.
Old 2 Weeks Ago   #175 (permalink)
goddarddr
goddarddr's Avatar
does heat wrap help performance? does it keep the heat of your leg better than the heat shield? does it stay on very long?
Old 2 Weeks Ago   #176 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
Originally Posted by Danase View Post
Dave,
Danase have you ridden with that exhaust yet? That is a big difference in length. Does it effect your performance any?
I wouldn't say the wrap really does anything for you except not burn you if you touch the pipe. I do it just for the looks. When it's on there you are gonna have it for awhile unless you take it off. Make sure you want it because if you don't like it when you take it off the pattern of the wrap is burn on the pipes.
Old 2 Weeks Ago   #177 (permalink)
Shadders
Project Bobber
Shadders's Avatar
Just a tip, when you heat wrap your pipes, give it a good 50 miles before you pull on to a gas station!!! I did after 1/4 mile from my house.
When I turned the engine off and looked around all I could see was screaming people running from the pumps, this was mildly amusing until the man behind the glass was refusing to turn the pump on for me!!
Whilst looking at the man flapping his arms, I noticed the level of smoke pouring from under my bike!! And I was the only one laughing!
If it ain't broke....... you didn't let me have a go!!
Successfully taking the p*ss since 1978
Shadders is offline   Reply With Quote
Old 2 Weeks Ago   #178 (permalink)
goddarddr
goddarddr's Avatar
interesting. thanks for posting the hot pipes. im taking this in, think the wrap looks kool, I might just start with painting my cruzers with black VHT.
here is a new pic. I took my homemade seat bracket off and mounted the seat right on the cross bar like i did at the beginning of my project and lowered the front 3" = low ridin
Old 2 Weeks Ago   #179 (permalink)
goddarddr
goddarddr's Avatar
I got to do something about that mirror, maybe i can heat it up and bend it to lay down?
Old 2 Weeks Ago   #180 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
Mechanics mirror will definitely clean it up a bit.
http://i266.photobucket.com/albums/i...9/100_4573.jpg
VN800 Bobber project CustomVN Projects and "How To" Write Ups 256 08-22-2009 10:56 AM
Just bought my first bobber project. tatman1315 Kawasaki Cruisers 4 02-28-2009 07:29 PM
Best Bike for a Bobber Project SA_Greeni Kawasaki Cruisers 16 08-28-2008 11:05 AM
Removing Bobber project pictures El Skitzo Kawasaki Cruisers 3 12-11-2007 03:55 PM
Yay, Norm! jukief Main Lobby 93 01-26-2006 12:02 PM
