Old 06-20-2008   #61 (permalink)
guitardadrocks
Foil Inspector
Awesome! Just relocated mine using this instruction. 30 minutes top.
guitardadrocks is offline   Reply With Quote
Old 06-23-2008   #62 (permalink)
ACDCfn
Default HELP!! Engine cover doesn't go back!
God Damn! Can't believe how easy it was for everyone else and what a problem it is for me! I need someone's help asap please! Relocated mine to the front, that part was easy. However, can't put the engine cover back on@! Refuses to go back into place, bolts don't line up. Had 2 other people try it for me, couldn't do it. Thought it was the wires, so tried without them all togethere still can't do it. HELP!!
ACDCfn is offline   Reply With Quote
Old 07-21-2008   #63 (permalink)
tpetty
Made It To Second Gear
tpetty's Avatar
Another awesome write up.
Doctor is in.
tpetty is offline   Reply With Quote
Old 08-24-2008   #64 (permalink)
drumster40
Live to Ride
drumster40's Avatar
Send a message via MSN to drumster40 Send a message via Skype™ to drumster40
OK you lied, it wasn't 62 cents it was 78, talk about misleading someone!!!!! LOL (ooops I forgot about the exchange rate?!?!?)
Constrictor, I did the mod yesterday at lunch, I didn't even have time to finish one beer and it was done! So I stood there and admired my work with a second one!!! LOL Awesome instructions, thanks for posting this! Any other mods your doing you feel like giving us a hand with
Thanks again!
Drumster
2005 Mean Streak
http://www.cruisercustomizing.com/drumster40
drumster40 is offline   Reply With Quote
Old 08-24-2008   #65 (permalink)
drumster40
Live to Ride
drumster40's Avatar
I too had about 5 minutes of "this doesn't line up" Even though you say its all ok it, sounds like you have a wire or connector in the way. Make sure you push the 2 big plugs down and in. Also, I found that you have to double check the wire heading from the starter to the back of the bike (under the seat) isn't in the way (that was my problem). Once I set that (it moves a lot by itself when you trying to line up the back of the cover.) all went smoothly.
Good luck!
Drumster
2005 Mean Streak
Old 08-24-2008   #66 (permalink)
ispeed77
RIP Deron Harden :-(
ispeed77's Avatar
Send a message via AIM to ispeed77 Send a message via Yahoo to ispeed77
Thanks again!
cost of raw metals is up, that might account for some of the increase
David - Moderator
2002 Suzuki DRZ400
2003 1500 Meanie, scraping pipes and frame :-)
In loving memory of Deron Harden, forever in our thoughts :-(
ispeed77 is offline   Reply With Quote
Old 09-30-2008   #67 (permalink)
griffin
Default Relocating Regulator
Nice clean job. I just moved mine from my 900 (was located under the radiator from the factory) because the front wheel throws crap all over it, especially in the winter. Plus, on the 900, you have to remove the unit in order to change the oil filter (real pain in the butt and knees). Moved mine up to the front left side (still gets enough air to bleed off the heat) using a $2 bracket and about 20 minutes. Always a way to improve on the bike so it fits our needs.
griffin is offline   Reply With Quote
Old 10-28-2008   #68 (permalink)
rocknskot
the waterproof one...
rocknskot's Avatar
is there any other likely place to put the thing? maybe to mount it flat under the frame? is that plausible? it would be right near its present location, but not hanging down like a limp phallus.
Scotty
'03 MS1500"Ghosty"
rocknskot is offline   Reply With Quote
Old 10-29-2008   #69 (permalink)
Constrictor
Way Too Much Free Time
Constrictor's Avatar
Send a message via AIM to Constrictor
So everyone benefits from the message I sent you through PM, I have had my rectifier in the same location since I originally did this mod back in '05 and havent had a single problem. I havent had any short circuits or any road debris damage the rectifier. I would assume that barring any extreme offroad riding, it will remain safe where I have it.
And to answer the question about mounting it flat under the frame, I do not recommend that as the rectifier gets very hot. The reason Kawasaki put it so exposed in its stock location is so that it comes in contact with air to cool it down. Under the radiator, it gets even more air (although thats not the reason to put it there), but flat, under the bike might cause it to overheat.
2005 Magma Red Kawasaki Mean Streak 1600
1998 Bright Red Pontiac Trans Am 405.5 RWHP 385.1 RWTQ
2004 Nighthawk Black Honda Accord EX 6-speed
Constrictor is offline   Reply With Quote
Old 10-29-2008   #70 (permalink)
ispeed77
ispeed77's Avatar
thanks for the info ! i have been meaning to do this mod since i bought my Meanie over a year and a half ago now. one of these days.....
David - Moderator
2002 Suzuki DRZ400
Old 02-22-2009   #71 (permalink)
TheWrights2004
Finally Got Into First Gear
TheWrights2004's Avatar
Default finally did it...
Well I have viewed this post 100 times at least and it has been saved on my computer for future reference for at least a year. Finally after receiving my chrome inner engine cover I decided to go ahead and do it. Man, what a great write up. My cost was under $2 BUT that was due to materials used. I mounted mine fins facing forward. So, I needed a poly spacer to fill the gap between the fins and the nut hole. Also, I installed a flat washer in the front and a lock washer on the rear under the nut. A few extra coins to cover parts BUT worth it IMHO. I like having the flat surface facing the rear of the bike as an added protection measure. Also, by doing this there is no binding issue with the harness coming out of the box and the bottom of the radiator.
Thanks for the info and saving me the $$ on buying one of the relocation brackets. Here are some pics (please excuse the dirt on the underside of the bike).
Check out the pic of the side of the bike pre-relocation and compare it to the after. MAN IS THAT FRIGGIN SWEET
constrictors-62-cent-rectifier-relocation-mod-dsc06018.jpg  constrictors-62-cent-rectifier-relocation-mod-dsc06020.jpg  constrictors-62-cent-rectifier-relocation-mod-dsc06021.jpg  constrictors-62-cent-rectifier-relocation-mod-sidecoverbefore1.jpg  constrictors-62-cent-rectifier-relocation-mod-sidecoverafter1.jpg
TheWrights2004 is offline   Reply With Quote
Old 08-28-2009   #72 (permalink)
tpetty
tpetty's Avatar
Found some hardware in a drawer that worked -- free mod that should have been factory standard -- GREAT pics!
Doctor is in.
