I would definetely check the carb for trash. I don't know much about new tanks, but I bet there could have been some microscopic trash in there maybe? Then, I would check the spark plug wires in the plug boots. Pull out the wire and make sure it isn't corroded. If you see corrosion, cut a little of the plug wire off. Get you some electric contact grease and put a little on there when you push the wire back in the boot.
Hope this helps and good luck! I know how frustrating this can be. I got caught out in the rain one day last fall. Water got into my front spark plug boot. This was virtually impossible before with the fatty tank. I didn't know what was the problem and I was convinced it was the carb. I removed the carb and cleaned it at least 10 times before my dad convinced me to check the plug wires..... The symptoms were very similar to yours......
1Likes
LinkBack URL
About LinkBacks
