LinkBack | Thread Tools |
#61 (permalink) |
In Search of Perfect Tune
![]() Join Date: Jun 2005
No need to respond-- I found the answer to my question at http://www.gadgetjq.com/thunder+stock_acmod.htm.
2006 Black Nomad w/ TFI O2 Sensor Roadhouse 2/1 If you can't dance it's too late to plow. |
#62 (permalink) |
recovering workaholic
![]() Join Date: Feb 2006
I pulled my plugs today after a coupla hundred miles with the mod,using the 680 ohm resistor,and they were right on the money,light brown,no glaze.
Today I also emptied my spare goat`s belly,gonna have a friend weld it back together for me so I can replace my stock one.That way I`ll be running it with my stock hollowed out mufflers,hoping it`ll sound a bit more aggressive.It should also give me another hosspower or two.... John
`03 MS "Leah" time you don`t use,you lose,grab every moment you can or it`s gone -38 special |
#63 (permalink) |
VN1500N
I got my setup all together, but when I put it together, I noticed that there is a small gap at the top part. The plastic is raised out a little around the intake holes and the filter is sitting on that. I don't want to file them down. Is this because I went with the 7 1/2" inside diameter, or has anyone else noticed this? What did you do? Any suggestions? I did try shaving the rubber down a little on the filter, but that didn't seem to work. I might try some weather stripping.
PS: When my K&N filter arrived from the mfr, I noticed quite a bit of small rubber shavings and even a couple of peices of screen material inside the filter. That would be pretty bad if it got sucked into the engine. It would be good to thoroughly inspect the filter before installing. |
#64 (permalink) |
That`s what you get for buying `spensive stuff...lol I went with the Mr Gasket 9 inch and it fit like socks on a rooster.No gaps,filings,shavings,you shoulda gone with the cheap ones.
Seriously,I didn`t run into that problem,I dunno what to tell you.Maybe someone else can contribute a meaningful solution and help you out. John
#65 (permalink) | |
VN1500N
The bike is going on the dyno this week. I'm dropping it off tomorrow. I'll post the results! == Why aren't my images showing? |
#66 (permalink) |
Aspiring slowpoke
![]() Join Date: Apr 2005
I am having trouble finding filter elements! Went to three stores in my area -- nothing on the shelf. They can order K&N elements -- no thanks. I wanted to find the Spectre 48059 -- that's the slightly more expensive cotton fiber white element. Called two stores -- they can't find the part number. Looked for stuff online -- nothin'. I did find 4805 online (the 7.99 plain). I guess that means living in the boonies.
Where do I buy this stuff? |
#68 (permalink) | |
Living on the dark side
![]() Join Date: Aug 2005
'03 1200 Sporty |
#70 (permalink) | |
Power Hungry V2K Rider
'00 Nomad '06 V2K LT Because RED is the fastest color... |
#71 (permalink) | |
#72 (permalink) | |
Let's Ride!
![]() Join Date: Oct 2004
#73 (permalink) | |
#75 (permalink) |
Way Too Much Free Time
Trust me, if you had a leak around your filter, you would know it. Any vacuum leak would result in an abornmally high idle. If your bike is idling fine, then you dont have any leaks.
2005 Magma Red Kawasaki Mean Streak 1600 1998 Bright Red Pontiac Trans Am 405.5 RWHP 385.1 RWTQ 2004 Nighthawk Black Honda Accord EX 6-speed |
#76 (permalink) |
I'm leaning towards the Raybro mod from Gadget's web site (http://www.knfilters.com/search/prod...x?Prod=60-1070) with K&N 9" filter. Has anyone else done this to an 05/06 Nomad and, if so, does the K&N filter fit snugly against the stock intake plate? Or does the Mr Gasket or Spectre filter have a better seal? I looked at BigJohnYeti's Caddman today (using Mr Gasket 9" filter) on his MS and the fit was great.
#77 (permalink) |
The base plate has a completely flat lip around its perimeter. You need to bend the solenoid mounting tabs in just a tad so the filter element will keep it's shape. the center depression on the filter lines up perfectly with the baseplate. I run the spectre paper filters with a K&N pre filter cover. After mounting it up and letting it set overnight, remove it and you can see the groove in the filter rubber where it is completely sealed. Hope this helps.
'03 1200 Sporty |
#78 (permalink) |
After reading everything I could on the subject, I've finally made a decision (trumpeting sounds in the background): I ordered the K&N (http://www.knfilters.com/search/prod...x?Prod=60-1070) with a pre-filter and will keep the ICSs intact. With the present setup, I've already increased my TFI #2 pot to 4:00 position, and will have to richen it up some more after the new filter install.
I'll give George a call at TFI, since he's been very courteous and helpful in the past, then post the results here. If anything like the Thunder kit I installed on the 2000 Nad, this should be quite an improvement (though my gas mileage is not great, getting about 140 miles before filling up). I did call K&N to see if they sold separately a round rubber seal (with adhesive on one side) to make contact with the stock intake plate better, but NO (John Beluchi sneer) they don’t!
#79 (permalink) | |
#80 (permalink) |
I just did this mod. to my vz1600. Runs great. I seem to have a rough spot between 2-3000 RPM. Cruising speed. I have v&h big shots with a powercommander. Manny from dynojet suggested the map I should use. He said that most intake map the same. Used same map as the Thunder Man. tornado. I just want to make sure I am not running to lean. Has anyone had their bike dyno tested & mapped for a powercommander. Thanks!
PS- I was also told checking my spark plugs was no longer an accurate way to check if I am running lean. I was told the reason was because of all the fuel additives today. Most bikes run a lighter spark plug to begin with. Anyone else heard this before? Thanks! Mods that I did - Marblized, unhooked solenoids (green wire), removed snorkle from left side. Pretty easy. Hope I didn't miss anything. Thanks! JoeJoe |
