Old 02-22-2007   #1 (permalink)
cbr74
Chromaholic
cbr74's Avatar
Send a message via Yahoo to cbr74
Default cbr74's no cost VN900 license plate mod
Now that I'm fully obsessed with tricking out my bike... I've started looking at all the things that could be just a bit better than stock. Kawasaki did a beautiful job on the rear fender styling of the VN900, then butchered it with all the gobbldegook that is the plate and turn signals.
Originally I envisioned fabricating a custom bracket to relocate the plate a bit higher but once I took it apart I realized Kawasaki had done most of the work for me already.
Before:
After:
Leftovers:
Kawasaki was nice enough to put two holes with the correct spacing right into the bracket for the reflector. All I had to do was make them a bit bigger. Out came the Coleman 18V cordless drill and a #9 speed bit and 2 minutes later I had a new license plate mounting spot.
I couldn't use the old bolts to remount the license plate bracket due to the washers on them so I went to my trusty nuts and bolts bin and found two without washers.
Tools used:
4mm allen wrench
8mm and 10mm sockets and wrenches
cordless drill
#9 speedbit
Materials:
2 washerless 6mm bolts
microfiber cloth
Procedure:
Remove chrome cover from tail assembly (4mm allen)
Remove license plate (8mm)
Remove license plate bracket(10mm)
Remove lower mounting bolt from inside fender (10mm)and two side mounting bolts (8mm)
tilt assembly up and remove reflector nut from backside (8mm)
re-install side mounting bolts loosely to hold assembly for drilling
drill two holes:
remove side mounting bolts again
tilt assembly forward and invert and mount the license plate bracket using washerless bolts
re-install side and bottom mounting bolts
re-install plate
re-install chrome cover
wipe finger prints off chrome cover
stand back and admire your handiwork
cbr74 is offline   Reply With Quote
Old 02-22-2007   #2 (permalink)
trikebubble
The Hibernation Nation
trikebubble's Avatar
Well their you go then. You've done a bang up job with that. Looks way better than stovk.
Pretty much every bike i've ever owned has had the license plate relocated.
2005 V2K Ltd
"I'll ride the wave where it takes me, I'll hold the pain release me"
trikebubble is online now   Reply With Quote
Old 02-22-2007   #3 (permalink)
cbr74
Chromaholic
cbr74's Avatar
The difference is subtle, the plate only moved two inches but that's two inches more fender showing and one less bicycle reflector. And of course the biggest benefit was it was free.
Here's a shot from a bit farther back:
The overall effect will be even more improved when I get my hands on a pair of front signals to put in place of the back ones. It will be a much less obtrusive assembly yet remain all Kawasaki.
Old 02-22-2007   #4 (permalink)
CheriAnn
October MOM
CheriAnn's Avatar
WOW! That's nice and FREE!!!!!!!!
Boy, I have been watching for your threads lately
You are coming up with some awesome ideas for the 900, thanks!!!!
2006 Vulcan 900LT (Mine)
2007 Vulcan Nomad (Hubby's until I decide to take it!)
CheriAnn is offline   Reply With Quote
Old 02-22-2007   #5 (permalink)
pat0021
VNOG#067
pat0021's Avatar
Send a message via Yahoo to pat0021
Very nice. Just might have to do that myself!
If you like your freedom thank a Vet!
U.S. Navy Vet
2006 VN900LT
pat0021 is offline   Reply With Quote
Old 02-22-2007   #6 (permalink)
trikebubble
Say, what do the signals look like on your bike anyways? Rebekah (SLSChic)just took her stock front signals off her Mean Streak. They may work for you.
If they are the same, you should give her or Gene (anamosity) a PM.
2005 V2K Ltd
Old 02-22-2007   #7 (permalink)
cbr74
Chromaholic
cbr74's Avatar
The front ones look just like the rear but shorter. The front signals on a Meanie use adifferent style mount but the rear ones are very similar.
Old 02-22-2007   #8 (permalink)
Teamlopez1
06 Nomad and 06 900LT
Teamlopez1's Avatar
Nice job. Yeah i hate reflectors too. I have all of them off both the 900 and the nomad. I think it makes the bikes look much better without them.
"Better to be an Open Sinner then a False Saint"
Teamlopez1 is offline   Reply With Quote
Old 02-22-2007   #9 (permalink)
2WheelFun
the "fun old" guy
2WheelFun's Avatar
Reflecting on your work...nice job!
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 02-22-2007   #10 (permalink)
Redbeard
Redbeard's Avatar
Hahaha I get it that was a play on words wasn't it. thats darn good. woot woot.
Redbeard
2006 1600 classic
Patriot Guard Rider #5776
Life ain't easy when your Fat and Greasy
Redbeard is offline   Reply With Quote
Old 02-22-2007   #11 (permalink)
cbr74
Chromaholic
cbr74's Avatar
That is high praise indeed. Stay tuned, the coming weeks will have more mods, more chrome, and oh yeah.. more chrome.
Old 02-22-2007   #12 (permalink)
Tattoomarc
T,J&R 4ever
Tattoomarc's Avatar
looks good I think i will have to try that
It does not matter the name on the bike... Its the wind in your face that is important!!!!
Tattoomarc is offline   Reply With Quote
Old 02-22-2007   #13 (permalink)
streak07
Sit speling cheker
streak07's Avatar
This works on Mean Streaks as well.
streak07 is offline   Reply With Quote
Old 02-23-2007   #14 (permalink)
colbycurtis
Wants better weather!
colbycurtis's Avatar
I love that mod unfortunately us here in Texas also have a inspection plate that hangs just below the tag so you can't even see the bottom of the rear fender. So if I do this mod it will maybe just allow the tip of the rear fender to show unless anyone has any cool ideas for what I can do with that dang inspection sticker plate that hangs just below the licence plate?
2007 Vulcan 900 LT Ebony and Galaxy Silver
colbycurtis is offline   Reply With Quote
Old 02-23-2007   #15 (permalink)
Easyrider32
Can't find time to ride
Easyrider32's Avatar
Since we are on topic on License plates. I ordered a Kuryakyn 4 x 7 chrome licene plate frame. I didn't realize that Canada has no standard size for Motorcycle license plates and it varies in different Provinces. I found out that the British Columbia plate is 5 x 8. Any suggestions on how I can somehow trim each size of the licence plate? Hack saw? Grinder. What is the easiest way?
Easyrider32 is offline   Reply With Quote
Old 02-23-2007   #16 (permalink)
texrider
texrider's Avatar
Neat mod! Unfortunately, we're required to have some red reflector area facing rear. Usually it is made as part of the tail light lens, but not on the 900.
'04 VN2000 & '05 VTX1800
"Never under the weather"
texrider is offline   Reply With Quote
Old 02-23-2007   #17 (permalink)
stevebtx12
I ride a Vulcan :)~
stevebtx12's Avatar
Very cool idea, cbr, but being in TX, I have the same inspection plate problem as mentioned here already .
Steve
2006 VN1600 Classic
VROC #22372
http://s158.photobucket.com/albums/t105/stevebtx12/
stevebtx12 is offline   Reply With Quote
Old 02-23-2007   #18 (permalink)
colbycurtis
The two screws holding my plate on have reflectice tips about the size of a nickel I wonder if that would suffice for the law.
P.S. Added thought...I bought this cool reflective tape it is satin gloss black but when light hits it it is retroreflective bright white. You can put it on any part of your bike that is black and it's barely visable (it comes in 6 inch thin strips) but good luck trying to explain to a cop you have reflectice items on the back if you get pulled over I have it on my helmet and you never even notice it's there during the day. I put it on the black ring at the bottom
Old 02-23-2007   #19 (permalink)
DirtyWater
Made It To Second Gear
Good job. Looks great. Now I got another thing to do.
DirtyWater is offline   Reply With Quote
Old 02-23-2007   #20 (permalink)
ervins
MOM Sept 2006
ervins's Avatar
Send a message via Yahoo to ervins
Good job!
ervins is online now   Reply With Quote
