Old 04-01-2007   #1 (permalink)
metalyguitarded
metalyguitarded's Avatar
Default Marbled My 900 - Pics
I noticed the inevitable popping on decel that came with the installation of aftermarket pipes so I decided to marble my 900. I read up on it here and at Gadget's site and decided I'd do it today and document the steps because I saw a number of threads from people looking for clarification or instructions. I took the bike out for a test ride afterwards and although I still noticed some popping, it was significantly reduced. Anyway, here's what I did, spelled out simply so some one like me can follow. I hope you find it helpful.
First, you'll be working on the right side of your motorcycle in the area indicated by the red circle.
The only tools I used were standard pliers, a small bladed screwdriver, and an large allen wrench. No need to open up the air cleaner cover.
On the 900, there's only one hose that runs to the front, right side of the air box. That's the hose you're going to marble.
Take your pliers, squeeze the metal clamp and work it up the hose. Then use the small bladed screwdriver to help break the seal around the inlet tube and push the hose off. Here's where you'll shove that marble.
I used a standard glass 1/2" marble I found at the bottom of my kid's toy box. It's a tight fit, so don't even bother trying anything bigger.
You have to get that marble pushed up the hose about half an inch so the hose will fit back over the inlet tube (blue circle). Because it's so tight, I used a large allen wrench (red arrow) to push the marble up the hose. I suggest putting a shop towel over your front cylinder head cover to prevent any scratches from an wayward allen wrench or whatever you choose to use to push that marble up the hose.
Finally, reattach your hose, secure the clamp and go riding!
I've read that some popping, even after marbling, is to be expected. However, loud backfiring or popping on decel that has not been decreased by this mod is likely an indication of an exhaust leak. Make sure you replaced your exhaust gaskets when you put on your new pipes and recheck the exhaust header connections (retighten) after about 100 miles.
I'm certainly no expert when it comes to bikes but I've borrowed liberally from the knowledge of much more experienced people on this thread and online (thanks Constrictor and Gadget and others) and decided to share my experience with this particular modification. If in doubt, don't do it or hire a professional. In other words, I'm not recommending that you do anything to your bike and any consequences for modifications or attempted modifications are on you.
Happy, safe riding!
METALLYGUITARDED
07' Ninja 650R
07' Ninja ZX6R
metalyguitarded is offline   Reply With Quote
Old 04-01-2007   #2 (permalink)
Gnamsu
Gnamsu's Avatar
Thanks for the very clear instructions... & good job on the pictures!
2006 'customized' Kawasaki Vulcan 1500 Classic FI
http://www.cruisercustomizing.com/gnamsu
Gnamsu is offline   Reply With Quote
Old 04-01-2007   #3 (permalink)
greenize
greenize's Avatar
Great job!!!! Sometimes pics and instructions make
a job alot easier.
Be Safe,
Sue
Sue
07 Honda Shadow VLX
Black
My husbands 900LT(my next bike)
greenize is offline   Reply With Quote
Old 04-01-2007   #4 (permalink)
jimbo-vn900
Ill kill you with my mind
jimbo-vn900's Avatar
Thanks for this.
This is very nicely done "how-to" with great pictures. I think you should post it in the "how-to" section of the forum as well.
Jimbo
VROC 5892
jimbo-vn900 is offline   Reply With Quote
Old 04-01-2007   #5 (permalink)
G
Ride Naked ..
Thumbs up
thanks for sharing the info , very clear instructions & the pics help heaps . i'm sure you have made the marble fitting procedure , a easier task with this post ..
G is offline   Reply With Quote
Old 04-01-2007   #6 (permalink)
rabbit
rabbit's Avatar
Beautiful Job! Aa+
rabbit is offline   Reply With Quote
Old 04-01-2007   #7 (permalink)
AtlantaDave
AtlantaDave's Avatar
Awesome job and I, for one, will be using this when I do my aftermarket pipes.
Thanks!!!!!!
BTW....cool@ss pipes.
2006 Vulcan 900 Classic
Peace...through SUPERIOR firepower
AtlantaDave is offline   Reply With Quote
Old 04-01-2007   #8 (permalink)
powday
Vulcan 900 Owner
powday's Avatar
Send a message via ICQ to powday Send a message via AIM to powday
Thanks man... you're always a great contributer!
powday is offline   Reply With Quote
Old 04-01-2007   #9 (permalink)
sweetlilred2002
2007 VN900 Custom
sweetlilred2002's Avatar
Send a message via MSN to sweetlilred2002 Send a message via Yahoo to sweetlilred2002
ok sorry folks...dumb question...Why are you putting the marble there in the first place? I missed something I think?!?
If you can't behave ...Atleast be careful!'02 Vulcan 800 Classic (RED)
'07 Vulcan 900 Custom (Blue)
sweetlilred2002 is offline   Reply With Quote
Old 04-01-2007   #10 (permalink)
Tattoomarc
T,J&R 4ever
Tattoomarc's Avatar
wow can't get any clearer than that.. thanks
It does not matter the name on the bike... Its the wind in your face that is important!!!!
Tattoomarc is offline   Reply With Quote
Old 04-01-2007   #11 (permalink)
Tattoomarc
T,J&R 4ever
Tattoomarc's Avatar
It gets rid of the popping on decel by disabeling the reed valves
Old 04-01-2007   #12 (permalink)
sweetlilred2002
2007 VN900 Custom
And it won't make it overheat or anything? Sorry, I don't understand the entire mechanics of the bike just the general stuff. I can always rely on you guys for good info though! My friend who is a Mechanic even gets on here sometimes to figure stuff out!
Old 04-01-2007   #13 (permalink)
Tattoomarc
T,J&R 4ever
Tattoomarc's Avatar
no over heating...this prevents air from being released into the exhaust under decel causing the popping.. It is part of the emmision control it won't hurt the bike and is not needed without aftermarket pipes
Old 04-01-2007   #14 (permalink)
sweetlilred2002
2007 VN900 Custom
Sweet, thanks! That really helps me out! Just got my Cobra Slashdowns put on last week! They sound good, but have noticed a little popping! I'll have to get out the kids' marbles!lol
Old 04-01-2007   #15 (permalink)
Tattoomarc
T,J&R 4ever
Tattoomarc's Avatar
glad I could help
Old 04-01-2007   #16 (permalink)
anamosity
secret agent
anamosity's Avatar
nicely done, simple easy to follow procedure.
08 ZX14
anamosity is offline   Reply With Quote
Old 04-01-2007   #17 (permalink)
CheriAnn
October MOM 07
CheriAnn's Avatar
BRAVO!!!!
We really appreciate the time you took for the pictures and VERY clear instructions!!!! Thank you!!!
CheriAnn is offline   Reply With Quote
Old 04-01-2007   #18 (permalink)
metalyguitarded
Thanks for all the comments. It feels good to give back. I've certainly gotten more from this forum than I've contributed. I'm glad you all appreciated the post.
METALLYGUITARDED
07' Ninja 650R
07' Ninja ZX6R
Old 04-01-2007   #19 (permalink)
dizzyphil
Turtle Wax Taster
dizzyphil's Avatar
Metal,..
Thanks for the info, I just got finished putting the marble in and have absolutely no backfires now. I debaffled about two weeks ago and have been having the backfires constantly, very annoying. I thought I was going to have to take off the intake cover but after seeing your 'illustrated' instructions, I easily stopped the annoyance. You are the shiznit for posting the pics along with the instructions! Thanks bro.
Dizzy
"You miss 100% of the shots you don't take"
Wayne Gretzky
2006 900 LT
dizzyphil is offline   Reply With Quote
Old 04-01-2007   #20 (permalink)
REFUGIO
REFUGIO's Avatar
Excellant instructions....Exactly the info that will come in handy for a lot of riders who don't know what we mean by marbling.
great job and great pictures
2008 VULCAN 1600 NOMAD
REFUGIO is offline   Reply With Quote
Some questions about Vulcan 900 (vs. Yamaha 1100) Somerset Kawasaki Cruisers 42 10-16-2008 11:30 AM
New to Forum - almost ready for new bike? Help to decide - 900? BackNBlack Kawasaki Cruisers 52 08-10-2007 11:57 AM
900 Classic vs VTX1300 - Riding Comparison Johnny5 Kawasaki Cruisers 14 09-24-2006 07:34 AM
