Old 09-12-2007   #201 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
hey next time you do a rear fender job, steel brake line works really well for running the wires through. but you have to weld it so if you dont have a welder this is the best way. i'm ready to see it all put back together. have you remounted the seat?
Live a little...upset the balance
http://fivepointfabrication.blogspot.com/
Alley Rat is online now   Reply With Quote
Old 09-12-2007   #202 (permalink)
El Skitzo
Wants better weather!
El Skitzo's Avatar
Yeah I knew welding something would be the best solution but I'm not good with a welder and seeing how much my seat pan warped (which I hammered back out) when I welded on the mounting bracket and studs, I definitely did not want to warp the fender. But yes, your suggestion sounds perfect and I'd look to trying it next time, and there will be a next time
No I have not remounted the seat yet, as I've back flipped again and will not bother with it for now. It looks good enough as it is and I just want to see it all back together and ride it. I can always remount the seat later if it really bothers me.
El Skitzo is offline   Reply With Quote
Old 09-13-2007   #203 (permalink)
Alley Rat
Moto Mez
Alley Rat's Avatar
i might be getting another bike. my uncle just bought another 800 from a friend of ours and he started talkin about selling another one of his bikes. this was his fourth bike. he has three 800 and a sportster. i want to build a gorilla bike. rusted rear fender a cool little gas tank i made out of a stock 800 tank. rigid frame. if i get it i will start right away and there will definetely be pics.
Old 09-13-2007   #204 (permalink)
El Skitzo
El Skitzo's Avatar
I like that sound of that Alley Rat!!
Old 09-13-2007   #205 (permalink)
El Skitzo
El Skitzo's Avatar
I pretty much wrapped up the most involved part of the assembly last night, being the fitting up of the new rear fender.
I put the bike back up on the lift with the wifes help, pulled the back wheel, cleaned it up and finally removed the protective coating off the white wall tire.
Then it was time to bolt up the rear fender and struts, and run the wiring through to the taillight. That was were I struck my only hiccup, the wiring connectors wouldn't all fit through the hole I had in the fender for them as the 20+ coats of paint had reduced it's diameter significantly. So I simply pulled one of the connectors off one of the wires, fed the whole lot through and then recrimped a connector back on the offending wire once it was on the other side.
I have yet to tighten up all the bolts on the struts as I need to align the rear of the fender perfectly centred over the tyre using some washers as shims, which I'll do tonight. I also still need to hook up the speedo cable, brakes and other little knick knacks to the back wheel, and torque down the axle bolt but again that's a 10 minute job tonight.
Tonight I'll throw the side covers back on, the exhaust back on with new flange gaskets this time, and probably put the fuel petcock back in the tank and put the tank back on for the final time, so come Saturday morning all I'll need to do is put fuel in it, check for fuel leaks and then test ride it.
I think the wing nuts on the fender struts worked out a treat and were definitely the way to go. It makes a little feature out of something that people usually try and hide.
Old 09-13-2007   #206 (permalink)
ispeed77
RIP Deron Harden :-(
ispeed77's Avatar
Send a message via AIM to ispeed77 Send a message via Yahoo to ispeed77
looking good !!!
David - Moderator
2002 Suzuki DRZ400
2003 1500 Meanie, scraping pipes and frame :-)
In loving memory of Deron Harden, forever in our thoughts :-(
ispeed77 is offline   Reply With Quote
Old 09-13-2007   #207 (permalink)
A2rider
Banned
This has been great to watch. Congrats.
A2rider is offline   Reply With Quote
Old 09-15-2007   #208 (permalink)
Dudester
Does fuzzy logic tickle ?
Dudester's Avatar
Send a message via MSN to Dudester
Well it's Saturday morning and I've become addicted to this thread lol.
Where's the pic of the finished product ?? Don't keep me hangin' here Skitzo !!! LOL
I want to be able to go to bed tonight knowing I've seen one of the nicest boppers ever made. This has been a very educational and inspiring thread. Great job.
03 Vulcan Classic 1500
Christmas, What other time of the year do you sit in front of a dead tree
Dudester is offline   Reply With Quote
Old 09-15-2007   #209 (permalink)
likearock4x4
Thanks to all Veterans!!!
likearock4x4's Avatar
Location: PGR Member #7955 O'Fallon, Illinois (Near St. Louis)
Dude, he's teasing you... I mean us.
Looking hard for Satisfaction.
I think I'll find it in July. (Update, I DID FIND IT!!!)
likearock4x4 is offline   Reply With Quote
Old 09-16-2007   #210 (permalink)
El Skitzo
El Skitzo's Avatar
Time to wrap this project up, had a busy night on Friday night setting the rear fender in it's final position and torquing down all the bolts for it.
The post I made many pages back about the chrome on one of the struts not being perfect worsened during assembly. When I torqued down the bolt at the base of the right strut it cracked the chrome, at that spot that look ordinary. Disappointing, but no big deal I'll just pull it off and have it redone some where else at a later stage. On Friday night I also put the pipes back on with new flange gaskets, put the side covers back on, and cleaned the whole bike up real nice.
After getting all the regular house hold chores done on Saturday morning I finally got back to the bike. I put the fuel petcock pack in the thank, poured fuel in and waited to see if there were any leaks. No leaks appeared so I threw the tank on and hooked it all up, wheeled the bike outside and started it. It ran like a pig which I was expecting but at least it was running.
So I wheeled it back inside and put the seat on, and getting those bolts on under the rear of the seat was one of the trickest things to do on the bike and cost me a bit of skin. There, bike done ready to roll and in came the rain!!
Later in the afternoon it cleared up just enough for me to ride the bike down to the local gas station to fill it up and bring it straight back home. Travelled no further than 1/2 a mile but you couldn't get the smile off my face!!
Old 09-16-2007   #211 (permalink)
El Skitzo
El Skitzo's Avatar
Sunday was a much better affair, I woke up to rain again, but it started fining up soon after and by mid morning was perfectly sunny and dry. At this point I had to go to a 2 years old's birthday party for a couple of hours, which seemed like a torture!! But the fairy cake and lolly bag at the end made it worth while...
Anyway, as soon as we got home I jumped straight on the bike and took off to spend the afternoon riding along the coast.
Man what a cool ride, it looks cool, sounds awesome and was everything I'd been hoping for. The seat takes a little getting used too as you feel like you want to slip off the back when you take off real quick, but as long as you hang on tight you're fine. I will remount the seat and fix that at a later stage.
Although it was sunny it was quite cool and I was only wearing a t-shirt so after about 60 miles I came home and took these pictures in the late afternoon sun. Apparently it's supposed to be fine and warm next weekend so hopefully I can really ramp up the miles!!
Thankyou everyone for your support and kind comments during this build up, it has really kept me going and enthused and it has all been appreciated. I hope these pictures do it some justice and act as some kind of thankyou to you all. I can add some links to some hi-res wallpaper sized version if anyone is interested?
Old 09-16-2007   #212 (permalink)
ispeed77
ispeed77's Avatar
looking good man, very nicely done !
David - Moderator
2002 Suzuki DRZ400
Old 09-16-2007   #213 (permalink)
El Skitzo
El Skitzo's Avatar
Cheers mate!
For my first time laying spanners on a bike I'm pretty happy with it.
Old 09-16-2007   #214 (permalink)
A2rider
Banned
Hooray! She's done! Glad you got to ride it. I'm proud of you.
Old 09-16-2007   #215 (permalink)
El Skitzo
El Skitzo's Avatar
Originally Posted by A2rider View Post
I'm proud of you.
Thankyou, that means a lot to me
Old 09-17-2007   #216 (permalink)
Metal_God50
Wheels of fire ride!
Metal_God50's Avatar
Sweet bike man, all that hard work certainly paid off! Cheers.
01' Kawasaki Ke100 Custom
07' Yamaha Virago 250
Metal_God50 is offline   Reply With Quote
Old 09-17-2007   #217 (permalink)
benide
benide's Avatar
Many thanks for documenting the progress. I have enjoyed the updates along the way. Any chance of you starting another one now
benide is offline   Reply With Quote
Old 09-17-2007   #218 (permalink)
Batman
cruisin for a bruisin
Batman's Avatar
i bet your glad its done and you can finally get out and enjoy it. i hope she rides as well as she looks. very nicely done sir!
2003 suzuki vz 800
LETS GO SEAHAWKS!!!!
Batman is offline   Reply With Quote
Old 09-17-2007   #219 (permalink)
Dudester
Dudester's Avatar
Definitely a collection bike someday. Fantastic job and thank you so much for such an interesting thread. Enjoy it....you truly deserve it Sir.
Old 09-17-2007   #220 (permalink)
ispeed77
ispeed77's Avatar
Originally Posted by El Skitzo View Post
Cheers mate!
rightfully so !
David - Moderator
2002 Suzuki DRZ400
New Bike Project... k_902 Off Topic 3 02-28-2008 09:20 PM
First pics - my new VN800 CustomVN Kawasaki Cruisers 27 01-02-2008 04:22 AM
The Vn800 Chopper Project has begun jeffwomack Kawasaki Cruisers 9 04-20-2007 01:14 PM
Vulcan Bobber Project PresidentBigJon Kawasaki Cruisers 2 05-19-2005 08:57 AM
