#101 (permalink) |
Cruising In Fourth Gear
Now it's time for the second part of the job, making the struts to hold the rear of the fender.
12. First step was to cut two lengths approximately as long as I think I needed, drilled 12mm holes in one end and bolted them in place. The flat bar I've used here is 6mm thick and 25mm across, so very sturdy! ![]() 13. You can see here that we've got a bit of bending to do to grab the fender. I'll concentrate on the left side first as clearing the chain guard is the biggest obstacle. ![]() 14. I've now got them bent to shape and clearing everything nicely. I paid close attention to make sure they were both bent at the same point so it looked even from behind. ![]() 15. Now they're both bolted in place. ![]() 16. And here you can see the struts completed, cut to size and the ends have been rounded off, although I still need to hand file the edges and sand them down to clean them up before chroming. I was thinking about drilling a series of holes down them for looks, but once chrome I think they'll look great as they are. By using a series of washers between all the joining surfaces I can adjust the alignment of the fender too. ![]() |
#102 (permalink) |
And here's the bike outside after finishing up the rear fender at 5:00pm on Sunday afternoon just in time to catch the last of the afternoon light.
I think this is pretty much the completed mock up. The rest is out of my hands now, paint, trim and chrome. ![]() ![]() ![]() |
#103 (permalink) |
Growing old disgracefully
Was going to suggest placing the struts on the inside of the swingarm and under the rear fender. Would look tidier IMO
Apart from that, looking good so far. Well done Last edited by Wharfy : 07-16-2007 at 01:14 AM. |
#104 (permalink) |
^^^ That was my plan originally Wharfy, but the sides of the fender aren't actually flat which makes it a little painful, and given the thickness of the struts I just don't have the clearance to get them in there. If the fender was 1/2 inch wider I would have tried it.
It will look better once the struts are chromed. I might even use some big wing-nuts on the bolts holding the struts to the fender just to make it look more interesting. |
#106 (permalink) |
Well I rode it off the driveway and back, that was about as far as I was willing to go with the bolts holding the fender together just finger tight and the back brake not connected. I've yet to connect up the wiring for the tail light too.
#107 (permalink) | |
btob
![]() Join Date: Jan 2007
#108 (permalink) | |
At least now I can decorate the top of the fender with scalloping and pin striping in the paint work which is something I've always wanted to do. |
#109 (permalink) | |
btob
#110 (permalink) | |
btob
#112 (permalink) | |
It's a little touch and go... |
#113 (permalink) | |
btob
#114 (permalink) |
Way Too Much Free Time
Well I can't give any mechanical advice because I'm not in the same league as some of you here. But I will say this....................WOW !!!! (Big time drool and jaw wide open here ) Absolutely fantastic job. Hope you post a pic of the beast completely finished.
03-Vulcan Classic 1500 If love is blind, why is lingerie so popular ?? |
#115 (permalink) | |
Btob, I'm currently hearing stories on the Chopper Forums of guys successfully running Metzelers with 5/16 of tire clearance and less! |
#116 (permalink) | |
btob
#117 (permalink) |
Well I've just pulled the front of the fender off and can see that if I make a mounting plate that bolts to where I have the fender now, and then bolt the fender to that (albiet in a higher position) I can achieve a consistent clearance of just over 1/2 an inch around the tire and the fender would look to follow the curve of the tire a little better too.
I'll play with this on the weekend and see how I feel about it. If it works out then great, I never have to worry about the clearance no matter how far and hard I ride the bike. If not I'll take btob's word for it (and many others) that it will be fine regardless. |
#118 (permalink) |
Well I decided to see if I could put some more clearance between this rear fender and the tire for better peace of mind, and thankfully I was successful. All it involved was to push the front of the fender a little higher as it had obviously been too low compared to the back.
So I made up a spacer plate from the left over 3mm steel plate from making the seat pans. ![]() Bolted that to the front of the rear fender, and also put a little bend in it at that point, as I was trying to push the front of the fender upwards, not extend the fender further around the tire. Sure I could have welded this on, but I don't want to twist the fender, it's taking no load and I like the fact it gives me adjustment later if I need it. Oh and it's worth pointing out that all the bolts I'm using are high tensile. ![]() Here you can see the spacer plate is now mounted to the swing arm, and the fender bolts to it, so I'm still using my original mounting idea, I just needed to tweak it a little. Oh well it was my first attempt so I guess you can't always expect to nail everything first time every time. ![]() And here it is all bolted in place, with a nice consistent radius off the tire as opposed to getting closer towards the front like it did previously. I've now increased my spacing from a little under 3/8", to a little over 5/8" so I now have more than enough clearance, given that 1/2" is the generally accepted minimum. ![]() Oh and I also picked up my new license plate on Friday so I had to throw that on. I still can't believe no one already had this... ![]() Last edited by CustomVN : 07-22-2007 at 09:04 PM. |
