Old 09-30-2007   #1 (permalink)
Matt7even
Matt
Matt7even's Avatar
Default 900 Valve Adjustment Walk-Thru
Ok as promised from my previous post "900 Valve Adjustment Woo's" here is a very abbreviated run down of my experience doing a valve clearance inspection and adjustment on my 900. Now keep in mind I am not the most mechanically inclined person and have never opened an engine before in my life. In fact I am sure the more knowledgeable members on this forum can probably point out mistakes I have made or better ways to do it, (witch I welcome). But the reason I decided to do it myself (all 3 times =) was to learn how witch has made me more confident in taking on other maintenance tasks and customization projects in the future. I hope this helps anyone else like me who is doing there adjustment or thinking of doing it themselves. I must note though that despite the title this is just a visual guide not a step-by-step walk through so you WILL need a service manual if your doing this for the first time. Also some other specialty tools you will need and I highly recommend:
* Hot Cams 9.48mm (2.10 - 2.35mm) Refill Shim Package Hot Cams
* Guage Feeler tool (.05 - .25mm range or higher) angled blades prefered.
* Small Telescopic Magnet
(enjoy =)
I can only post 10 images per post so I will post the rest below
Matt7even is offline   Reply With Quote
Old 09-30-2007   #2 (permalink)
Matt7even
Matt
Matt7even's Avatar
Old 10-01-2007   #3 (permalink)
texrider
Way Too Much Free Time
texrider's Avatar
Great job! I can see from your photos it is best to have the correct replacement shims, as they are in a vulnerable position. Enjoy your ride, and the satisfaction of having done that yourself
2009 Versys
texrider is offline   Reply With Quote
Old 10-01-2007   #4 (permalink)
Dare
Uncle Bob's Love Child
Dare's Avatar
Wait a minute! I was told by the dealership that the valves on my 900 were non adjustable! That *******! So....how often should they be adjusted?
Dare is offline   Reply With Quote
Old 10-01-2007   #5 (permalink)
LVCigarz
LVCigarz's Avatar
Thanks Matt, I don't need to make any adjustments yet, but I will be taking off the gas tank soon to install my Fuel Pak. Your photos (first three or four) are going to be very helpful to me.
Pete
"Do The Right Thing."
2006 Candy Fire Red VN900 Classic
LVCigarz is offline   Reply With Quote
Old 10-01-2007   #6 (permalink)
Matt7even
Matt
Matt7even's Avatar
Yea it's a shame sometimes how little some stealerships actually know (or care) about the products they sell, especially with a newer model like the 900. That's what makes these forums so great! Your owners manual states they should at least be inspected every 15,000 miles.
Old 10-01-2007   #7 (permalink)
Matt7even
Matt
Matt7even's Avatar
Yes thats why I would suggest buying a kit or the refill pack of shims listed above. Even if you have a dealership generous enough to give or sell you individual ones you could find yourself taking many trips back and forth trying to find the ones that fit properly.
Old 10-01-2007   #8 (permalink)
Matt7even
Matt
Matt7even's Avatar
Cool Cigarz, Unforchunatly I don't have an image of the fuel hose and how I disconnected/plugged it so just make sure you consult your service manuel.
Old 10-01-2007   #9 (permalink)
MrClean
Needs A Real Job
MrClean's Avatar
You screwed up big time AND right off. You Pumped fuel out of the tank? You should have removed that by twisting your right hand a little longer. 40 miles after that little yellow light comes on you should drive home and you'll be fine. Use a pump? Heretic!!
Otherwise pretty good rundown.
F5
It's Refreshing!
From Somewhere near Parkville, Mo.
William Crane
aka MrClean
IBA #34301
MrClean is offline   Reply With Quote
Old 10-01-2007   #10 (permalink)
Matt7even
Matt
Matt7even's Avatar
*writes all of that down* =)
Old 10-01-2007   #11 (permalink)
REFUGIO
REFUGIO's Avatar
Most excellant walk thru.....Great Job
You might find this hard to believe..but I was actually able to...very patiently..do my clearance adjustment/inspection...with the fuel tank still in place....It can be done and yes ...space is tight.
2008 VULCAN 1600 NOMAD
REFUGIO is offline   Reply With Quote
Old 10-01-2007   #12 (permalink)
kc6wfs
Plasma Blue
kc6wfs's Avatar
Should get this STICKIED on the write up how to section!!!!
Good job!!!!
2007 Vulcan 900 Custom Plasma Blue --
www.myspace.com/nitrophotos
kc6wfs is offline   Reply With Quote
Old 10-01-2007   #13 (permalink)
Matt7even
Matt
Matt7even's Avatar
No kidding Refugio, I think I would rather just attempt to build a ship in a bottle wearing boxing gloves! You get points in my book for difficulty though =).
Old 10-01-2007   #14 (permalink)
Matt7even
Matt
Matt7even's Avatar
Thanks, How do you go about doing something like that?
Old 10-01-2007   #15 (permalink)
LVCigarz
LVCigarz's Avatar
Yup, I have the SM and printed the section on tank removal, but your pics show a different angle. It will help.
Thanks again.
Pete
Old 10-01-2007   #16 (permalink)
Propdoc
Finally Got Into First Gear
Thanks so much for the run down, you did an excellent job. I've got to get ready to do this project myself very soon. How much did the shim kit cost?
Pick your direction, then move.
Propdoc is offline   Reply With Quote
Old 10-01-2007   #17 (permalink)
jesse web
900 Custom Rider
jesse web's Avatar
Very nice!!! But it looks like an all day thing...
Here is my question to all of you. How do you know when you need a valve adjustment?
What are the symptoms?
I only have 2500 miles on my 900 and i get a sewing machine kinda noise when it warms up and becomes louder with acceleration.
Any ideas? Tks
jesse web is offline   Reply With Quote
Old 10-01-2007   #18 (permalink)
Matt7even
Matt
Matt7even's Avatar
Thanks, It's about $35 average if you get them off the net. Here is a link Hot Cams
good luck.
Old 10-01-2007   #19 (permalink)
Matt7even
Matt
Matt7even's Avatar
Any ideas? Tks
Yea the first time was kinda involved but once you have it down it takes about 2-3 hours to repeat the process. Kawasaki says that you need to at least inspect your valve clearance or get them inspected every 15,000 miles to see if they need adjustment. The sewing machine sound is probably your valves. If so that is a normal sound and will get quieter in time. But as you rack up miles they can tighten up to the point you can barley hear them at all, that's a sign that they may need to be adjusted.
Old 10-01-2007   #20 (permalink)
LVCigarz
LVCigarz's Avatar
That's funny, its kinda like the male and female mosquito. The males don't drink blood and their wings buzz and you can hear them coming. The female, however, drinks blood and their wings don't buzz. So, when you don't hear anything is when you start worrying.
Pete
Reed Valve Block off on 900 TX 900 Custom Kawasaki Cruisers 5 06-25-2007 09:19 AM
Valve Adjustment. fastback Vintage Motorcyle Info 17 08-25-2006 11:41 PM
valve adjustment iroc The Mechanics Corner 2 05-05-2006 09:49 AM
Is dealer valve adjustment bs? unclemarcus Kawasaki Streetbikes/Sportbikes 8 03-02-2004 11:00 PM
Valve Adjustment ZX7R yogiaz The Mechanics Corner 4 12-19-2003 10:21 PM
