Old 11-04-2007   #1 (permalink)
2wheeledmaniac
2wheeledmaniac
Question Front fork spring replacement
Hi, Do you have to take forks off bike and teardown to replace springs? Wanting to install Progressive springs in my 2001 Vulcan 1500 FI.
2wheeledmaniac is offline   Reply With Quote
Old 11-05-2007   #2 (permalink)
Thullan
Yet another 800 Bobber...
Thullan's Avatar
Hi!
Everything is described in detail here. Good luck!
VN800A -95 Bobber Project, work in progress
Thullan is offline   Reply With Quote
Old 11-05-2007   #3 (permalink)
2wheeledmaniac
2wheeledmaniac
Smile
Thank You !!!
Old 11-05-2007   #4 (permalink)
Spok
RIP Deron - 1400Pilot
Spok's Avatar
go take a look at gadgets page, he has a writeup on replacing the fork springs, and instead of taking the fork tubes off to drain the oil, he uses a big hypodermic and a pice of tubing.
Spok is online now   Reply With Quote
Old 11-05-2007   #5 (permalink)
elr658
Motorcycling's Dr. House
elr658's Avatar
And leaves the sludge in the bottom of the fork tubes.
1982 Kawasaki KZ1000R1 #658
1980 Kawasaki KZ750H1 LTD
www.myspace.com/79cb750f
Old 11-06-2007   #6 (permalink)
GREENISBEST
Honest it wern't me !!
GREENISBEST's Avatar
Yep you can't believe how much of that Dirty Smelly stuff ends up in there..
Remove, Strip, Clean all parts and replace Worn Components..
Funny thing here in the UK we went through a Faze of fitting Progressive springs but that Mod has faded away with Fitting new OEM or good aftermarket Springs and a grade up on the oil Viscosity if desired or a Tad less air gap...
Well that's my £ worth...!
END OF MESSAGE !
GREENISBEST is offline   Reply With Quote
Front fork oil capacity 05kx250 Kawasaki Motocross and Offroad 5 09-14-2007 03:49 PM
Leaking Front Fork on a Vulcan 500 bassfisher Kawasaki Cruisers 5 06-10-2006 08:57 AM
Front fork seal cwelty The Mechanics Corner 0 06-20-2005 09:35 AM
in search of front fork tubes vn750 tr0ll2 Accessory Swap Meet 1 02-01-2004 12:33 AM
MY 2003 KX250 BAD SHAKE FRONT FORK, CHAPMANBATMAN Main Lobby 3 11-20-2003 08:07 AM
