First time owner here and I am rebuilding a 94 Vulcan 1500. I bought this "project" since the building it was in caught fire. I have the whole thing torn apart and want to know if I should rebuild the front forks. They do not seem to leak any oil and other than soot marks and melted windshield pieces they are in good condition. Any ideas?
What would rebuilding these involve? Changing oil and seals? if that is the case if would seem to be not that expensive but oil amount and info like that is what I am missing. Also basically how to disassemble and reassemble. any special tools needed? So that is where I am any help would be great. |
Cruising In Fourth Gear
I'm no expert but...if there's melted plastic on the front forks then you might want to check/test the forks for stability...heat can weaken or even change the molecular structure of the metal, possibly making it brittle.
also one other area that may worry me is the springs themselves...if they took too much heat than it could have messed with the sring rate of the springs themselves...you may want to look at replacing the front springs...the front end of your bike is your livelyhood...take every procaution...other than that taking the forks apart is not all too difficult if you have a manual of some kind, but you may need a friend to help release the tension on the springs in order to get the circlips out to get the springs out...I don't really know what else to say...others will chime in soon too
'87 EX500 ~Jay |
Former foxhole digger
fire, oil, plastic don't tend to mix too well. Personally, I would take the time to rebuild them. Why take the chance? You life is not worth the time it would have taken to rebuild them and it's not too difficult to do your self.
Larry US Army 1989-2005 Desert Shield/Storm/Provide Comfort Vet PGR Member |
#4 (permalink) | |
As long as there is no outer structure damage to the fork, you maybe ok at this point to clean them real well, new outer seal, fresh oil and all done. Springs, maybe maybe not, depending on miles on the bike and damage it might be worth the cost.
| 01 vulcan 1500 classic fork and spring removal | NCDave | The Mechanics Corner | 4 | 03-17-2008 03:44 PM |
| 1982 kz750 front fork top plug removal.. | darc helmit | The Mechanics Corner | 2 | 05-23-2007 11:17 AM |
| Front fork seal | cwelty | The Mechanics Corner | 0 | 06-20-2005 08:35 AM |
| in search of front fork tubes vn750 | tr0ll2 | Accessory Swap Meet | 1 | 01-31-2004 11:33 PM |
| MY 2003 KX250 BAD SHAKE FRONT FORK, | CHAPMANBATMAN | Main Lobby | 3 | 11-20-2003 07:07 AM |
