Old 12-15-2008   #141 (permalink)
vulcaneer
Foil Inspector
vulcaneer's Avatar
The whole thing was easy enough. Pretty straight forward and the sound is pretty good. I'm still going to upgrade to cobra longs by the summer.
vulcaneer is offline   Reply With Quote
Old 12-20-2008   #142 (permalink)
jontur
jontur's Avatar
Predfan, Did you say your Exhaust whistled after Stage 1
Thank J
jontur is offline   Reply With Quote
Old 12-20-2008   #143 (permalink)
predfan2001
Waiting for happy hour
predfan2001's Avatar
Never heard any whistles. But then again, stage 1 and drilling holes in the baffle caps did very little as far as sounds goes....so I went on to the de-baffle.
2007 Vulcan 900 Classic'ish Custom LT ???
(Yeah it's all mixed up!)
predfan2001 is offline   Reply With Quote
Old 12-20-2008   #144 (permalink)
TejasDevil
Drill here, drill now!
TejasDevil's Avatar
If you end up upgrading to Cobra longs, let me know if you would like to sell your de-baffled stockers. Would save me doing the work, and I'd have my un-baffled stockers for backup.
TD
2007 Vulcan 900LT
TejasDevil is offline   Reply With Quote
Old 12-20-2008   #145 (permalink)
predfan2001
TD
You won't need back up....once you debaffle you'll never look back.
Old 12-20-2008   #146 (permalink)
bobkat
Rockabilly biker
bobkat's Avatar
Predfan speaks the truth! It's not debaffled until it's totally debaffled!!!
"My yard is my flag" Hank Hill
bobkat is offline   Reply With Quote
Old 12-20-2008   #147 (permalink)
TejasDevil
TejasDevil's Avatar
Just worried about it being too loud. A couple of posters noted this and even went to the trouble to re-baffle. But I must say the sound clips I heard sound fine, but are they mis-leading?
TD
2007 Vulcan 900LT
Old 12-20-2008   #148 (permalink)
TejasDevil
TejasDevil's Avatar
Besides, I don't have the hole saws or reciprocal saw, and don't want to mess up the pipes, so might as well just buy the already-baffled pipes from Vulcaneer since he's already done the work.
2007 Vulcan 900LT
Old 12-20-2008   #149 (permalink)
vulcaneer
Foil Inspector
vulcaneer's Avatar
TD
Will definitely do that. I will be getting cobras by summer for sure.
Old 12-20-2008   #150 (permalink)
TejasDevil
TejasDevil's Avatar
Great. Send me a message when you're ready.
TD
2007 Vulcan 900LT
Old 12-21-2008   #151 (permalink)
vulcan_dude
vulcan_dude's Avatar
Tejas, the hole saws will run you about $20 for both the sizes you need (that's for both, not each).
You can buy an inexpensive reciprocating saw for about $60 at Lowe's, and 4$ for two metal cutting blades. If you can swing it, I would do it, I think it's definitely worth it. I'm very happy with the sound and volume
- Albert
2009 Vulcan 900 Classic - VROC# 29006
www.berto.zenfolio.com
vulcan_dude is offline   Reply With Quote
Old 12-21-2008   #152 (permalink)
Kawi
Proud Owner Of This Forum
Kawi's Avatar
A customer came in a couple weeks ago that had de-baffled his 900 and I thought it sounded great, had a pretty deep and sweet tone to it .
Kawi is offline   Reply With Quote
Old 12-21-2008   #153 (permalink)
bobkat
Rockabilly biker
bobkat's Avatar
It's all about the tone!
Old 12-21-2008   #154 (permalink)
Seadog1967
Wannabe Poser
Seadog1967's Avatar
Making me tempted to do this as a winter project. I've held back only because I was worried it wouldn't pass our yearly inspection. Anyone in Ma. debaffle then have it inspected?????
Who Needs A Gel Seat When Yer Wearing Depends.
Tonkin Gulf Yacht Club 1968
USS America CVA-66
Seadog1967 is offline   Reply With Quote
Old 12-21-2008   #155 (permalink)
predfan2001
I got my saw at Harbor Freight for $18.00. It did the job.
Old 12-21-2008   #156 (permalink)
vulcaneer
Foil Inspector
vulcaneer's Avatar
TD
you got it.
Old 12-22-2008   #157 (permalink)
Hacker
Forensic Bug Splatter Analyst
Hacker's Avatar
If you don't have the reciprocal saw, why not rent one for an hour instead of running out and buying one. You'll use it all of about 60 seconds total so unless you need one for other projects it's pointless to waste bucks buying one.
Bagel - another name for a Jewish rabbit dog....
Hacker is offline   Reply With Quote
Old 12-23-2008   #158 (permalink)
vulcan_dude
Wow, can't hardly go wrong for $18! Even if it just works for this project, it's well worth it, though I'm sure it will last much longer. Harbor Freight often does have some sweet deals going on.
Yes, the tone is what is awesome about a complete debaffle, it's deep and sounds like it means business
- Albert
Old 12-23-2008   #159 (permalink)
Hacker
Hacker's Avatar
TD
I have to vote no on that question. The videos of debaffled pipes I've seen are pretty much quite on the mark. I've been running back and forth between getting new pipes or leaving the debaffled ones right where they are. My own opinion is that the back pressure you lose by debaffling is probably not a good idea, but I could be wrong there. I think what I'm going to end up doing is adding an intake and leaving the pipes alone for the time being. I have a new Cobra processor setting in the closet waiting for an excuse to install it, and the intake, along with the debaffled setup would be just such an excuse. Eventually I will probably add pipes, but not for another year or so.
Old 12-29-2008   #160 (permalink)
pirate71
Finally Got Into First Gear
pirate71's Avatar
Well.......I did a partial debaffling this afternoon. Took it as far as putting the 4 holes in the back wall of the baffle. so far I am happy with the sound at this point. I think I may put 4 more holes in it and see how it sounds. I can definately hear a difference now. I did get a little bit of popping but not enough to get my attention too much yet. Will do the marbling job if it gets worse or begins to bother me. Will probably up grade pipes next year sometime but this was definately an improvement. Wouldn't have had the confidence to do the job with out this post and of course delphi. Thanks for the great post again!!!
'08 VN900 Classic - Black
Luv my HK ResTech 3" pipes!!!
pirate71 is offline   Reply With Quote
Quiet Pipes Zukdriver Kawasaki Cruisers 15 04-03-2009 04:29 PM
Why I'm Keeping My 900 fastball Kawasaki Cruisers 54 03-03-2009 09:33 PM
08 900 Custom exhaust....... eli98 Kawasaki Cruisers 14 11-22-2008 10:56 AM
Ok, tomorrow is the day for my 900 exhaust mod... predfan2001 Kawasaki Cruisers 10 05-24-2008 01:19 PM
Exhaust mod Vulcan 900 Custom "PICS" kc6wfs Kawasaki Cruisers 10 10-03-2007 02:49 AM
