LinkBack | Thread Tools |
Green Envy
Hey everyone. Today I got up early on a Sunday morning, earlier than anyone every should on a Sunday morning, and decided to install the H.I.D. Kit i've had lying around for a few weeks, The kit is a H4 bulb specific kit, its made to be plug and play. Anywho, I thought some may be interested in knowing how its done, so I created a how to write up... Here goes....
Well the kit I bought was made for a motorcycle obviously, but more so for a sport bike. There is no way the balast, wiring, transformer, and connections would fit in the headlamp bucket, so i start off by cutting the connectors in order to extend them... ![]() I cut about 4 feet of bulk wire, 14 gauge, and laid it out, ready to solder it all together and extend the whole harness... ![]() After soldering all the connections together, i shrink wrapped it in clear wrap to prevent any water entry. This step is optional i would say because the chances of water getting to the connections after the install is completed will be very unlikely... ![]() After that step, wrapped all the connections in electrical tape to secure all the connections nice and tight... ![]() And after all the connections are done, wrapped and taped, this was the end wiring product... And that cylinder at the end is the bulb. That was its protective casing ![]() Next, pulled the two philips screws from the headlamp housing, and remove the headlamp, unplug the bulb, and remove it. Then plug in the H.I.D. H4 connector into the factory connector in the headlamp, and route the whole harness out the hole in the back of the housing..... ![]() Next wrap the wires coming out of the headlamp in wiring harness tubing to make it nice and clean looking and route it towards the back.... (I know you guys love my killer key chain...) ![]() Following the previous step, remove the seat, tool cover and tools, and remove the upper battery covers two philips screws. Move the bikes harness slightly out of the way and pull the upper battery cover all the way out. That big empty space behind the battery is where i decided to mount the ballast and wiring..... The ballast is mounted to the frame in front of the rear fender and the wiring was tucked in there as well... ![]() ![]() After the wiring and ballast was mounted, the tray and tools were reinstalled, and the outcome was very clean. The wiring is hardly visible... ![]()
2008 Candy Lime Green Vulcan 900 Custom - The Sexy Color 2005 Kawasaki ZX6R 2005 kawasaki KX250F Last edited by MXDesa : 06-29-2008 at 01:57 PM. |
Green Envy
(sorry guys i had to continue with a new reply post, it would only allow 10 images.)
The wiring from the headlamp to the rear was tucked underneath the tank... ![]() And finally, after about an hour and a half of working time I was done. And that was while taking pictures and everthing. So im sure it can be accomplished in about an hour. And the end result is awesome. The bulb fits great and so did all the wiring and this was the great outcome.... ![]() ![]() ![]() So what does everyone think? I think its a great little mod that takes little time and the outcome is awesome. Greater visibility, nice front end change, and now Ill be more noticable to traffic. So thanks everyone for reading through and hope this helps someone. If anyone has any questions what so ever, email me or PM and ill help the best I can... Oh and another thing, I also debaffled my stock pipes this weekend with the help of another write up on here and they sound great. I wanted to thank Trashman900c for supplying a spare set of factory pipes and for coming over and lending a hand to get it done!! Thanks Robb!
2008 Candy Lime Green Vulcan 900 Custom - The Sexy Color 2005 Kawasaki ZX6R 2005 kawasaki KX250F Last edited by MXDesa : 06-29-2008 at 01:53 PM. |
#5 (permalink) |
Green Envy
You could get one H.I.D. kit and use those "blue" looking bulbs. Im sure it will look close enough to where it looks good!
2008 Candy Lime Green Vulcan 900 Custom - The Sexy Color 2005 Kawasaki ZX6R 2005 kawasaki KX250F |
#7 (permalink) |
The Incredible Vulc'
nice.......from the looks of it, i think im gonna need a hand with it.......mine just came today..........maybe you could give me a hand if you're around Sunday morning..........
Robb |
#8 (permalink) | |
Green Envy
Yeah we can install your kit sunday. Give me a call. Ill bring extra materials from work
#9 (permalink) | |
If you need me to bring anything let me know, unless you want to do it over at my place, its up to you...........pick the time also, im usually up real early........ Robb |
#12 (permalink) |
QUOTE form website:
The H4/9003 Bi-Xenon bulbs in the bi-xenon kit stay fixed and there is a shield that covers and uncovers the capsule of the xenon bulb as you switch from low to high beam, thus changing the beam pattern. The high beam gives an upward projection and the low beam gives a forward projection. You will maintain the same beam pattern with dramatic increase in intensity and distance. XenonLink.com HID Conversion Kit. |
#19 (permalink) | |
Green Envy
Thanks it is pretty straight forward. And to the post asking why I would run wires to the battery; i didn't run wires to the battery, its just that the ballast doesn't fit in the headlamp bucket, so i extended the BALLAST wiring to under the seat to hide it
