LinkBack | Thread Tools |
ufodriver
Lower your VN 900 1” or 2” or 3” using the stock link arm.
Note and disclaimer: You will use your existing OEM link arm from your bike and modify it using a machine shops expertise. The machine shop will have to fill in the exiting holes of the link arm, add ½” of metal to extend the arm (Mine was TIG welded) then re-drill new holes at the proper distances per your desired lowering height. My cost was $45. Your cost may vary based on your negotiating skill and the machine shop. {Please call around to make sure a qualified machine shop that can perform this work first prior to disassembling your bike}. Perform at your own risk....This is what I did to my bike and it works perfect. |
#4 (permalink) |
ufodriver
Thanks
Sorry no real before and after pics....the pipes are Bubb Jug's and are loud. If you want loud I found these are loudest I've seen so far. BTW - Scootworks has a how to lower using their lowering kit on thier web page too. It also mentions how to lower the front as well. Might want to check that out too. |
#5 (permalink) |
Vulcanologist
so you need to lengthen the arm to lower the bike? i wondered if drilling a relocating hole next to the stock location to shorten it would lower the bike i guess i have it backwards.
| OEM AIR & Oil filters for 2006 VN900 classic LT | WhiteFox | Beartooth Kawasaki | 5 | 10-14-2008 09:49 PM |
| Need OEM seat for VN900 Classic or LT Cheap!!~ | Casper1951 | Kawasaki Cruisers | 12 | 06-30-2008 08:50 AM |
| VN900 OEM shield | GenT | Kawasaki Cruisers | 0 | 04-24-2008 10:02 AM |
