Go Back   Kawasaki Motorcycle Forums > Kawasaki Motorcycle Forums > Riding Gear
Old 05-11-2008   #1 (permalink)
Deion
Default need help on my 2008 kawasaki 250 turn signal
I replace the front turn signal but it only turn the light on without the flashing part, what should I do?
Deion is offline   Reply With Quote
Old 05-11-2008   #2 (permalink)
aftermath4788
zx-11/250r
aftermath4788's Avatar
put the old ones back on and see if they do the same thing. If they work find then maybe it is how you hooked up the new ones or maybe the new ones arent working properly.
aftermath4788 is offline   Reply With Quote
Old 05-12-2008   #3 (permalink)
Uthor
Can't find time to ride
Uthor's Avatar
Send a message via AIM to Uthor
Did you replace them with LEDs? You might not have enough resistance to activate the flasher circuit. Try the sportbike section where you'll most likely get a better response.
Uthor is offline   Reply With Quote
Old 05-12-2008   #4 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
If thats the problem, and the new lights do not draw enough power to trigger the flasher....you can buy new, more sensitive flasher to.
try a good auto parts place, they should have them.
Saleenguy is offline   Reply With Quote
Old 05-12-2008   #5 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
ps. be sure the ground is hooked up, clean, and secure as well.
I see more lighting problems due to bad grounds than all other reasons combined...........well except blown bulbs...........
Kawasaki can make you sick. Uncle Bob Off Topic 20 08-12-2008 10:47 PM
250 Kawasaki ZX-2R Main Lobby 2 06-05-2007 07:45 PM
2004 Ninja 250 - looking for a front right turn signal jwalsh84 Accessory Swap Meet 2 04-02-2006 01:17 AM
Turn signal problems zx9 2001 jiggajaff The Mechanics Corner 2 03-29-2006 09:50 AM
EX500 turn signal switch Daekar The Mechanics Corner 1 07-16-2004 09:50 PM
