#21 (permalink) |
Bridal Boutique Manager
I've been wearing a mesh jacket without the liner during the summer here in California, and have ridden in 100+ temperatures.
I find that its cooler with the jacket on when moving than in just a t-shirt. The hot air hitting you constantly as you're moving is no fun. I couldn't imagine wearing a half or a 3/4 helmet. When its really hot out, it feels like the heat blast from an oven when I open my visor while moving. |
#22 (permalink) |
Sun Baked Commuter
In AZ, riding in 110+ F weather is not uncommon from July - September. Even in mesh riding gear, it is still pretty darn hot.
The holes in the mesh actually pushed the hot air against me, making me dehydrate faster. It felt hotter in stopped traffic, on hot asphalt, surrounded by running engines, in dark riding gear (black helmet gets REAL WARM). I usually wore a soaking wet t-shirt under my mesh jacket and it kinda helped. Next year, I'm probably buying one of those cooling vests that you soak in water for 15 mins prior to riding. |
#23 (permalink) |
Top Gear Full Throttle
mesh jacket and mesh pants. T shirt short pants underneath. perforated leather gloves. ankle high boots. Helmet depends I have a half a 3\4 with sheild and a modular. Seems I have been wearing the modular most of the time these days. The heat and humidity here in the summer can be compared to many places in Florida. It can get quite hot while sitting in the traffic. I have not had any sunburn to contend with since I wear the gear.
#24 (permalink) | |
RUN AWAY!
"The superior rider uses their superior judgment to avoid needing their superior skills" -myself |
#25 (permalink) |
RUN AWAY!
I usually wear mesh gear with running gear underneath, like a spandex/polyester mix from underarmor or champion. They are very light, pull moisture away from the body, and allow moisture to evaporate quickly. Outside of that the only issue is drinking plenty of water.
#26 (permalink) | |
I too live in S.W. Florida. Across the river from you in Fort Myers. I wear gear all the time. A perf leather jacket in the summer. A regular leather in winter. If it's too hot to wear gear, it's too hot to ride.
Kevyz Toyz '01 ZRX 1200R '05 ZRX 1200R My name is Kevin and I'm a bikaholic. |
#29 (permalink) |
Scraping the Floorboards
Another vote for cooling vests. However, there are 2 kinds out there. The evaporative cooling vest is OK when you are moving but useless when you are stopped. If you are riding stop and go it will drive you crazy and soak your clothes underneath. The other type uses inserts made out of a material that maintains 40 degrees F for up to 10 hours depending upon the brand. This is the type I would recommend. You can then stay cool no matter what the temperature is and no matter if you are moving or stopped. Recharge in a freezer us usually only 20-30 minutes. In ice water half that time. Its amazing how much better you will ride when your body is at a comfortable temperature.
2009 Vulcan 900 Classic |
#31 (permalink) | |
Good luck! Personal Cooling & Heating Vests, Phase Change Cooling Vests Personal Cooling Head & Neck Wear, Phase Change Cooling Neck Wrap
2009 Vulcan 900 Classic Last edited by 1holegrouper : 04-14-2009 at 04:06 PM. |
| 636 6th Gear Whine? | Glaxtx | Kawasaki Streetbikes/Sportbikes | 17 | 03-07-2006 12:44 PM |
| Sythetic Gear Oil ? | Plato | The Mechanics Corner | 4 | 03-06-2006 09:21 PM |
| 94 vulcan 750 no second gear | larrycavan | The Mechanics Corner | 6 | 02-05-2006 09:21 AM |
| 2001 ZX-6R J2 gear lever/clutch problem? | MJ | The Mechanics Corner | 2 | 11-19-2004 01:05 PM |
