Go Back   Kawasaki Motorcycle Forums > Kawasaki Motorcycle Forums > Riding Gear
Old 10-02-2008   #1 (permalink)
KraZ440
Yet another newbie.
KraZ440's Avatar
Default Mink Oil
I've been using mink oil on my boots, but I'm disappointed with how well it is working for waterproofing. When I went to a boot shop, looking at alternatives, I was told that once I use mink oil on my leather boots, that I must continue to use mink oil, or the leather will crack.
So, my questions are:
1) Do you think that I will have a problem if I switch from mink oil to a different waterproofing agent?
2) What waterproofing agents would you recommend for leather boots?
Thanks.
-Brian
'82 KZ440 LTD
KraZ440 is offline   Reply With Quote
Old 10-04-2008   #2 (permalink)
48Rob
Cruising In Fourth Gear
48Rob's Avatar
Found on the Web under general search for;
Will mink oil ruin leather hiking boots?
Nikwax Aqueous
(courtesy, REI)
I recently purchased a new pair of leather hiking boots and, after a ten-mile break-in hike, cleaned them and treated them with mink oil (I couldn't find Sno-Seal anywhere locally). Despite all my years of backpacking, I didn't realize this oil can over-soften the leather and affect the support. Have I ruined my boots for good or is there something I can do to save them?
— Mark
Indianapolis, Indiana
Well, I wouldn't describe the don't-mink-oil-boots advice as common knowledge, but the outdoor boot world has known for a while that it's not the wisest thing to do. (Quite apart from what might happen if you run into a PETA activist as you're slathering up with this stuff.) As you've since discovered, it does over-soften the leather, particularly the "chromium-tanned" leather that has been the norm in hiking boots for a number of years. That alone does a pretty good job of keeping the leather wearably soft.
So, what can you do? Nothing, at this point. I wouldn't agonize too much over it. For everyday backpacking you might even find that an extra-soft boot is just fine. Beyond that, while mink oil is greasy and so tends to stay on, and in, the leather, maybe it won't sink in too far with just the one application. You could even wash the boots with warm, soapy water, rinse thoroughly, and let them dry. Then treat them with a modern boot-waterproofing agent such as Nikwax Aqueous Wax ($8 a bottle; www.nikwax-usa.com). It's specifically designed so it doesn't sink too deeply into the leather, which means it does wear off in time but is easily re-applied.
Generally, the drill today is to do nothing to a new pair of boots for some time, except clean them off if they get very muddy. Once you begin to notice that the leather "wets out" more easily when exposed to rain or other water, then start treating with Nikwax or a similar product (silicon treatments, such as REI's Ultra Seal—$4.50 for two ounces—are fine). And, keep your boots clean by washing with water and a soft brush, even rinsing them out occasionally to remove sweat, an acidic residue that can damage boot linings and leather.
So, Mark, no mink oil necessary. Besides, I don't even want to think about how they get that stuff.
Rob
Central Illinois
2006 Nomad
48Rob is offline   Reply With Quote
Old 10-04-2008   #3 (permalink)
RichLockyer
RichLockyer's Avatar
I use a blend of mink oil and pine pitch recommended by Fox Creek.
I've used it on my boots maybe twice in the last year, never had any issues with cracking or other problems with the leather even though I'm not "regular" with it's application.
I think I've treated my jacket twice in 2 years.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
Old 10-04-2008   #4 (permalink)
mkelley
Extreme Gizmologist
mkelley's Avatar
You should try some Montana Pitch Blend.
Montana Pitch-Blend Products
-Mike
Chapter President, Maryland VRA
my bikes my Meetup Group
mkelley is offline   Reply With Quote
First Serrvice? MB08 Kawasaki Cruisers 11 08-12-2008 12:00 AM
Ever done anything dumb? greencrum Kawasaki Cruisers 34 06-19-2008 05:39 PM
Oil Change Instructions BigJohn Off Topic 20 03-24-2008 12:56 PM
Blinking Oil Pressure Light MTNFSH Kawasaki Cruisers 23 12-04-2007 05:46 PM
