Go Back   Kawasaki Motorcycle Forums > Kawasaki Motorcycle Forums > TERYX RUV Forum
Old 03-16-2009   #1 (permalink)
trikebubble
Slow Guy on a Fast Bike
trikebubble's Avatar
Exclamation Need some Terxy 750 pictures
I'm working on a project to install some hand controls in a customers Teryx 750.
Would it possible for anyone who owns one to snap a few pictures of the steering column, brake and gas pedals and different angles of the general c0ckpit area?
Thanks a bunch,
Carlo
08 Midnite Sapphire Blue ZX-14
trikebubble is offline   Reply With Quote
Old 03-16-2009   #2 (permalink)
trikebubble
Update.
What I need to see (or get an idea of) specifically is what exaclty is behind the dash/shroud under the steering column. I need to know what the actual physical steering column (that the steering shaft runs through) looks like.
I have a number of methods of clamping my hand controls to steering columns or frame attachement points on automobiels, and I'm trying to see if I can adapt one to this Teryx.
In a perfect world, if I could get some pictures of a Teryx without the dash / shroud on, I would be set.
Thanks again,
Carlo.
Old 03-16-2009   #3 (permalink)
Lobocop
Last 007 MOM
Lobocop's Avatar
Send a message via AIM to Lobocop
Hey Buddy, In order to get shots from inside the dash would require pulling the front group and roll cage off. I may be able to get some shots for you from another forum, Ill try for you.
Here are some shots to get you started.
Build it if you can - Buy it if you must
VROC #11416
07 Red Lodge Survivor - DR# 009
Lobocop is offline   Reply With Quote
Need parts interchange info... Peacerita68 Beartooth Kawasaki 5 02-12-2009 01:09 PM
'81 750 Ltd apbling Vintage Motorcyle Info 5 02-01-2009 02:47 PM
Interchangeable Parts EthanKZ750 Vintage Motorcyle Info 4 01-10-2009 10:10 PM
Vulcan 750 Touring Bike???? stan Kawasaki Cruisers 20 09-07-2008 02:34 PM
Kawasaki 750 2 Stroker jondar Main Lobby 7 09-07-2008 12:07 AM
