Old 08-17-2009   #141 (permalink)
zeiss150
Top Gear Full Throttle
Default Video, Video, Video!!!!!
I finally got my video done. I had it done a few days ago but apparently you can't use copy written music in homemade videos. Anyway, I hope you guys like the video. It was fun to make it. Let me know if you have any questions.
And yes, I will polish the stator cover and I will put the ace of spade on the side cover.
Enjoy the video!
Matt-
zeiss150 is offline   Reply With Quote
Old 08-17-2009   #142 (permalink)
kawpaul
itching to ride
kawpaul's Avatar
Where is the link to the video?
1983 gpz 750 .....the wait is over
kawpaul is offline   Reply With Quote
Old 08-17-2009   #143 (permalink)
zeiss150
Default lets try this again!
Sorry guys! I tried to embed the youtube video into this thread and that didn't work so I'll try this...
YouTube - Cafe' Ace2,1978 kz650
Does anyone know how to embed the video into this thread?
thanks, Matt-
Old 08-17-2009   #144 (permalink)
Torques
Wants better weather!
Torques's Avatar
Not to be picky but can you remove the music? It's difficult for me to hear the motor. Thanks for your effort.
2006 1600 Classic Ebony
Cobra Slashdowns
Power Commander III
Scorpion
Torques is offline   Reply With Quote
Old 08-17-2009   #145 (permalink)
zeiss150
Default Fixed it!
Ok I changed the audio. so now you can hear the engine very clearly. Alright, I hope you guys like it.
Matt-
Old 08-18-2009   #146 (permalink)
Torques
Torques's Avatar
Wow, you did a great job in the reedit. IMHO, artistically, it was perfect with the fade out to engine start. That bike sounds so meaty and healthy!
Cobra Slashdowns
Power Commander III
Scorpion
Old 08-18-2009   #147 (permalink)
zeiss150
Thanks torques! I love the way the headers make the bike sound. its a blast to ride and it sounds awesome.
Does anyone know how to embed the youtube video into this thread?
Thanks, Matt-
Old 08-18-2009   #148 (permalink)
StarGate
StarGate's Avatar
Sounds good but one thing I noticed, where are your tags?
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 08-18-2009   #149 (permalink)
zeiss150
Hey stargate, I didn't have the license plate on when I videoed that. Its on now. I have it mounted below the tail light. So you're not crazy, they just aren't in the video.
Matt-
Old 08-21-2009   #150 (permalink)
anakinkenobe
Made It To Second Gear
Send a message via AIM to anakinkenobe Send a message via Yahoo to anakinkenobe
Matt im getting ready to put my 750 motor in, what tips do you have for putting it in since youve had your bike pretty much completely disassembled lol..
anakinkenobe is offline   Reply With Quote
Old 08-21-2009   #151 (permalink)
zeiss150
getting the engine in the frame is a pain in the butt. I think the most important thing is to pad the frame. I taped a bunch of towels on the frame that way the motor wont scratch the frame.
I put my bike on the center stand, then I put the motor on a milk crate (the milk crate is about the same height as the frame) then I used two 2x4's to bridge the gap between the milk crate and the frame. Then I just pushed the motor over. It's a tight fit, but it works.
The other way that I've heard of is to put the motor in an old tire on its side then lay the frame over the motor and bolt it up. That seems easier than the way I did it but I don't know.
Just make sure you cover that frame or you'll scratch all the paint off.
Good luck!
Matt-
Old 08-21-2009   #152 (permalink)
anakinkenobe
sweet thanks
Old 08-21-2009   #153 (permalink)
zeiss150
Default What do you thing of my video?
I've gotten a few reply's, but not that many. Have you seen it? Did you like it? Did you hate it? Sound off! You won't hurt my feelings (much ) .
Here's the link again.
Thanks, Matt-
Old 08-22-2009   #154 (permalink)
CalvusAquila
Cool video man.
I enjoyed reading your posts, they are inspirational. I'll be removing the engine from mine tonight. Wish me luck.
CalvusAquila is offline   Reply With Quote
Old 08-23-2009   #155 (permalink)
anakinkenobe
I liked it as well... Ill be putting my motor in tonight....
Old 08-23-2009   #156 (permalink)
anakinkenobe
Question my motor is out of an 1980 kz750, is there anything special with this motor, i know its pretty much a bored out 650 but i asked about it having points and the guy i bought it from said it didnt have points, is that a significant difference?
Old 08-23-2009   #157 (permalink)
zeiss150
You might have a bit of a problem tying into your wiring harness, but no major problems. If it doesn't have points it might be an after market electronic ignition so it shouldn't matter. Just take off the points cover and you will be able to see if its points or electronic. There's no reason that you can't make the electronic work on your bike... it just wont be plug and play.
The only other difference would be the reed valves on the valve cover. just get rid of all the emission stuff and run a vacuum hose from one side to the other.
Other than that I think everything else is the same.
take some pictures!
Matt-
Old 09-06-2009   #158 (permalink)
zeiss150
Default Electronic up grade
I Love my Cafe'. It drives great and is a blast to ride. The only problem I'm having is with the spark. Its running on all 4 but the spark is weak on 2 of the cylinders. cylinders 1 and 2 have "sooty" plugs.
So, I did the wired george relay mod so I know I have 12 volts to the coils. I think my problem is the coils them selves. So I decided to switch from points to electronic ignition.
I bought an IC ignitor, and a timing pick up from a kz750. Now I just need to get some new coils and plug wires and I'll be ready to wire it in.
I'll up date as I get it all done.
Matt-
Old 09-06-2009   #159 (permalink)
anakinkenobe
Can you do a walkthrough and parts list of what you need to do that, i have a 750 motor i converted to my 650 ignition but would really like the use my 750's ignition....
Old 09-07-2009   #160 (permalink)
zeiss150
Default Step by step
I plan on doing a step by step with photos, so ... stay tuned!
Matt-
KZ440 LTD Cafe Racer Project PNKFLYD Vintage Motorcyle Info 4 3 Weeks Ago 01:13 AM
Z 400 Cafe racer Glen Vintage Motorcyle Info 22 12-20-2007 11:49 AM
Cafe Racer Tank Graphics gpzrider Want to show off your ride? 9 05-15-2007 11:36 AM
Cafe Racer gpzrider Vintage Motorcyle Info 7 06-01-2005 11:23 PM
LTD >> Cafe Racer project ngrandma Vintage Motorcyle Info 4 05-02-2005 12:51 PM
