Old 04-23-2009   #1 (permalink)
78_KZ750_Cafe
Burt Munro Is My Hero
78_KZ750_Cafe's Avatar
Default Hey Chaps, The '78 750 Won't Reliably Start. Looking for Advice
Hey guys, it's been a long time since I've had to ask for help, but I'm at the end of my rope here.
When the bike runs, it runs strong as hell - no sputter, strong acceleration, normal idle, no excessive fuel consumption. But that's the problem, when it runs.
For the last two-ish years i've been kick starting the old girl with no trouble (because i like kicking it rather than using the starter), with a yearly tune up and points adjustments she's been ultra-reliable. But when I pulled it out of storage this year she's been a real b*tch about starting reliably. I've gapped the points dozens of times, fresh gas, gapped spark plugs, all voltages proper, charged battery, both cylinders pull 130-135 PSI on a compression test, spark plugs get wet when kicked over, plugs show spark when laid on the block... I don't know what else to check out or adjust.
It WILL start when the battery charger is hooked up to the battery and the engine gets kicked over, leading me to believe it might be a weak coil, but that's based on nothing. Anybody have ideas?
Also, i'm tired of points and condensers. Anyone know of a reliable way to convert these old birds to electronic ignition? There are some defunct suppliers out there, but the parts are worth solid gold now. Looks like a DIY unit is necessarily.
78_KZ750_Cafe is offline   Reply With Quote
Old 04-24-2009   #2 (permalink)
DrKayak
SuperMotard Retard
DrKayak's Avatar
On my 900 I replaced the coils, plugs wires and did the relay mod to power the coils directly from the battery. It starts instanlty. I have comuted on it all winter with never a starting issue. It does have electronic ignition.
On my 750 I replaced the points, coil, wires, plugs and did the relay mod before I ever tried to start it. It started on the first kick till I tore it back down to replace the head gasket and starter clutch. Time will tell if It will be as perfect as the 900.
If you are running on the OE coil I would get a new Dyna w/wires and do the relay mod. It's a $10 mod that can't hurt.
1976 KZ900
1980 LTD750G (twin)
DrKayak is offline   Reply With Quote
Old 04-24-2009   #3 (permalink)
78_KZ750_Cafe
It's definitely not a stock ignition system. I've got normal points and a condenser under the dome, but that's all that's original. I've got a hot coil from JC Whitney, fiberglass core ignition wires and NGK plugs.
Please expand upon this relay mod you speak of.
Old 04-24-2009   #4 (permalink)
DrKayak
SuperMotard Retard
DrKayak's Avatar
Here's the relay mod:
wiredgeorge motorcycle carburetors - Vintage Japanese Motorcycle Carburetor Sales, Rebuilding and Restoration - Repowering Ignition Coils To Get Full POWER!
Another possible source would be the carb getting dirty over time. I would think this would show up as needing more and more choke to start. If It's not starting at full choke this could be it.
My 900 starts needing extra choke ever now and then. I found running a tank with a strong shot of Sea Foam bring it back to normal.
1976 KZ900
1980 LTD750G (twin)
Old 04-24-2009   #5 (permalink)
herk
bustedfeet
herk's Avatar
The 80s 750-Twins have electronic ignition & share most the ignition parts w the 80s KZ440-Ltds; you'd need the timing advancer from a 750-Twin.
herk is offline   Reply With Quote
Old 04-25-2009   #6 (permalink)
StarGate
StarGate's Avatar
If it's starting ok when the batter charger is connected, I'd suspect the battery may be on it's way out or a low coil voltage due to old/dirty/corroded connectors in the ignition/coil power circuit. The coil repower mod is a nice fix, I did it to mine several years back.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 04-25-2009   #7 (permalink)
King David 72
Berryman CHEMTOOL B-12 bro. Put it in the gas, and continue to try to start your bike until it does. 2 ounces per gallon instead of 1 though. That old bike just 'aint used to this new gas. Your jets are dirty because the gas formulation that is used nowadays goes bad quickly & easily. Good luck.
King David 72 is offline   Reply With Quote
1989 750 Vulcan no start ktm922 The Mechanics Corner 5 07-12-2008 06:45 PM
2005 750 vulcan hard to start when cold Tom Austin Kawasaki Cruisers 15 11-08-2007 03:32 PM
Newbie Help 1983 GPZ 750 wont start bharris Vintage Motorcyle Info 5 02-02-2007 10:08 PM
1982 KZ 750 Spectre start problem fine then dead 1whitedoz The Mechanics Corner 2 06-24-2006 12:44 PM
Hey what does everyone think a 99 750 Shadow would sell for? cudaosix Kawasaki Cruisers 11 03-13-2006 02:36 PM
