i have a 1980 kz1000. the bike has white smoke coming out of the exhaust when it is warm. it has pod filters and a kerker 4-1 header with no baffles. i dont know if it has been jetted or not. also it has the low emissions head and the valve cover is leaking exhaust around the #4 emission port. could the smoking just be that the carbs need to be jetted, or do you think it is rings/ valves. the bike has 30,000 miles on it. it runs pretty good, but it seems to stumble on hard excelleration and at high rpms. hope someone has some info for me. thanx.
hates stupidity
was it sitting for awhile? if so its probably conensation that needs to burn off and thats it. otherwise, what does the smoke smell like? are you losing oil anywhere?
alternately, take the cigarettes away from the bike.
ZedX 1k owner. henceforth The bike shall be Zed. |
Vintage bike addict
If it's smoking gray when warmed it's been jetted a bit bigger than needed. Blue smoke is oil. Gray or black is a rich condition. Others here can be more specific on what jetting to use for the setup you have. You should probably mention which carbs you have as well.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince |
| If you love children...You should be smoking! | Sierra Vulcan | Off Topic | 47 | 04-06-2009 08:42 AM |
| 1982 kz440 smoking at the exhaust under the bike | rrich49132 | Vintage Motorcyle Info | 1 | 11-02-2008 10:11 PM |
| Smoking engine | muddhollow | The Mechanics Corner | 8 | 08-05-2008 05:21 AM |
| Smoking KX250?????? | nofx_boden | Kawasaki Motocross and Offroad | 21 | 05-18-2008 04:10 PM |
| Diagnosing Major Smoking Problem '81 KM100a | aaron_gx | Kawasaki Motocross and Offroad | 2 | 06-03-2007 07:03 PM |
