LinkBack | Thread Tools |
KZ750CO
Replacing the clutch cable on my 1981 KZ 750 LTD. Question, does the cable from the clutch lever go "inside" the fork or on the "outside" of the fork. The old one was on the outside but have not seen any pics of it installed that way. What do you say...inside or outside.
Third Gear And Gaining
I have an 80 kz1000 ltd. I just rerouted mine when I lowered/flipped my handlebars. The bars were lower so I sent it down through the headlight bracket, along the side of the wire harness cable and down through the middle of the forks. It's still a little tight, but not nearly as bad as when I started.
Not quite sure how the 81 750 looks, but that's how I did mine. Hope it helps.
1980 kz1000 LTD Maxine a.k.a. Mad Max |
Needs A Real Job
I'd say route it between the headlight housing and the left fork on the inside for a realatively straight shot down the frame going toward the clutch cable attachment area. It might be a good idea to get some 1/4" I.D. black spiral wrap to protect the cable housing in wear areas. I got mine at Radio Shack.
The spiral wrap is a fairly low temperature plastic, so avoid high heat places like around the exhaust system. As long as you've got the side cover off, clean, inspect, and re-grease the clutch actuation mechanism.
Mike Folks |
#5 (permalink) | |
KZ750CO
#6 (permalink) | |
KZ750CO
| kz 400 starter on a kz 440? | Alibi | Vintage Motorcyle Info | 8 | 09-30-2008 09:27 AM |
| 1982 KZ750M CSR clutch cable crisis | brpinney | The Mechanics Corner | 3 | 09-22-2008 01:36 PM |
| 1980 KZ440 - Clutch Cable Broke at Hand Lever | Dan Scott | Vintage Motorcyle Info | 2 | 07-06-2008 02:29 AM |
| First: How does a clutch work? Second: How do I fix it? | Neep | Vintage Motorcyle Info | 8 | 07-03-2008 10:28 PM |
| Clutch cable help | jeremy | Kawasaki Cruisers | 6 | 05-14-2008 11:01 PM |
