Turtle Wax Taster
Any suggestions regarding how to troubleshoot a reserve lighting switch on a 1000J? My "problem" consists of a very dim low beam, the warning light indicating a lighting problem "on", and a high beam warning light that does not function. Tried a new bulb and the shop manual addresses certain scenarios, but not this one. Thanks.
Lew 82 KZ1000-J2 06 H-D FXD35 In the past...72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K |
Turtle Wax Taster
Thanks elr, but put a new 60/55 in it and still have the problem. Does "60/55" or "55/60" make any difference?
#4 (permalink) |
Riding Vintage
Check the resistance through the ground terminal and the positive terminal. Put one probe in the female spade of the headlight and the other to the corresponding battery terminal. Check resistance. Should be VERY minimal. Seems to me like a bad ground.
Riding Vintage. |
#5 (permalink) |
Turtle Wax Taster
Thanks Killbert, but being the novice I am, need a little more help. My headlight bulb has 3 male terminals. Also, would there be some way to ground the circuit so I could tell if there is a grounidng problem? Thanks again.
#6 (permalink) |
Needs A Real Job
The ground circuit wire should be BLACK with a YELLOW stripe. High beam should be a RED with BLACK stripe, and low beam RED with YELLOW stripe.
The ground circuit wire should be the same as the battery negative cable going to the engine mounting bolt electrically.
Mike Folks |
#8 (permalink) |
Turtle Wax Taster
Checked everything and I believe my reserve lighting uint is shot. When I bypass it, everything seems to work fine. The unit is located on the front of the battery box below the air cleaner. I assume I have to remove the battery box to get to it. Any other suggestions? Thanks.
#9 (permalink) |
Riding Vintage
Hmm.... It's been a while since I removed and reinstalled my battery box, but I recall having both the voltage regulator and the lighting unit on the battery cage during installation. It's pretty quick to get that sucker in and out. Let us know.
Kellyn
Riding Vintage. |
#10 (permalink) |
Turtle Wax Taster
Thanks Kellyn. Found the disassembly seciton in my repair manual and am disconnecting everything. Only thing that bothers me is I hate pulling on 27 year old wires unless I absolutely need to, but what is is!
#11 (permalink) |
Turtle Wax Taster
Update....Replaced the reserve lighting switch and no difference. Pulled the tank tonight and found the problem. Bad 9 pin connector under the tank.
| Test VN750 Reserve Lighting Unit? | Ol Poop | The Mechanics Corner | 34 | 07-23-2009 08:14 AM |
| HID lights and reserve lighting device | ww2willys | Main Lobby | 0 | 06-24-2009 01:49 PM |
| 2004 Vulcan Fuel Reserve switch | connor36 | Main Lobby | 4 | 05-01-2009 11:24 PM |
| 03 zx6r fuel reserve switch | slimfitz | The Mechanics Corner | 1 | 08-13-2008 01:59 PM |
| How to bypass Vulcan 750 Reserve Lighting Unit | dandanbikerman | Main Lobby | 1 | 05-31-2008 03:44 PM |
