Old 07-01-2009   #1 (permalink)
Mekial82kzp
Mekial82kzp's Avatar
Default Speedo Questions (Calibration / Universal)
I've been woundering if it's posible to calibrate a speedo on a '82 kz1000p? Or has anyone used a universal speedo and how can it be universal when there are so many speedo drives and tire sizes? I've seen one on jcwhitney motorcycle section, here's the address...
CHROME SPEEDOMETER 2-1/4 : JC Whitney: Motorcycle Parts & Accessories
what would you sugest? experiences, etc. thank you.
Mekial82kzp is offline   Reply With Quote
Old 07-01-2009   #2 (permalink)
RichLockyer
RichLockyer's Avatar
Most speedo drive units on the wheel are geared for the wheel and tire diameter that they were originally "attached" to, so the mechanical speedos themselves are very close to being "universal".
There's no way to calibrate one without modifying the drive.
Modern "universal" units are electronic, and can operate from a magnetic actuator triggered by the transmission output shaft, the rear wheel hub, or even the front wheel hub... basically the same as a bike speedometer.
Those units are normally programmable, based either on the wheel circumference, or the number of pulses over a given distance.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
Old 07-01-2009   #3 (permalink)
suzy1052
Foil Inspector
suzy1052's Avatar
I use a 25.00 bicycle computer.
suzy1052 is offline   Reply With Quote
Old 07-03-2009   #4 (permalink)
Mekial82kzp
One thing that gives me confusion is that the speedo drive that is used on my bike and it's gears are used for multiple bikes, most of which use 19" wheels and my bike uses 18" wheels. But the speedo itself is different... Does anyone know how to calulate a ratio for the speedometer? and does anyone know about speedo drive calibration? Can I interchange gears from other bikes to calibrate? Thanks.
Old 07-03-2009   #5 (permalink)
Mekial82kzp
btw I've thought about that bicycle speedo and have seen it used on motorcycles before but I'm partial to the analog gauges. thanks.
Old 07-03-2009   #6 (permalink)
RichLockyer
It's all based on the tire diameter, not the wheel diameter.
Generally, tires mounted to 18" rims are a bit wider than those mounted to 19" rims.
The Vulcan 900 Custom runs a 21" wheel, the Classic runs a 16", but both the 130/90-16 and 80/90-21 are within 5%.
If you have changed your rim and are no longer running a tire that is the stock diameter, then there's no way to readjust that speedo, short of finding a hub drive unit that'll fit your rim, but came from a bike that uses the same size tire you are using now.
- Rich
Patriot Guard Rider
Old 07-03-2009   #7 (permalink)
Mekial82kzp
ok, could you tell me the differance between the 2240:60 Ratio and the 1:2 Ratio speedometers that I've found?
Old 07-03-2009   #8 (permalink)
RichLockyer
No clue... all of the mechanical Honda and Kawi speedos are the same.
- Rich
Patriot Guard Rider
Old 07-04-2009   #9 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
2240:60 is the somewhat universal Japanese speedo calibration. If you use the drive which came off the P-Bike, you'll be cool.
2:1 is used on HDs with the speedo drive on the rear wheel.
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Question about speedo variation VrUoLcCkAsN Kawasaki Cruisers 14 06-25-2009 12:37 AM
1996 vulcan custom speedo just quit working maddmaxx65 The Mechanics Corner 0 04-26-2009 09:57 PM
Speedo calibration agentfox1942 Kawasaki Cruisers 16 04-13-2009 09:14 PM
Speedo calibration. evmo Kawasaki Streetbikes/Sportbikes 7 04-30-2007 08:53 PM
Tach and Speedo 750 VULCAN Rubline The Mechanics Corner 5 05-22-2006 05:19 PM
