'80 1000B LTD
A week or so ago I wrote about a kZ1000 ltd that laid out a huge grey smoke screen when I accelerated coming out of hard turns. Well, I followed the advice all ya'all gave me and didn't tear into it. That was good advice. Here's what happened.
1. The "carb guy" dumped a whole can of Sea Foam into 1/2 tank of gas. 2. The oil smelled burnt, was black/brown color, and "watery". More like brake fluid viscosity than the 10w30 the guy put in it. SO........ 1. I drained the tank and put in fresh 93oct. 2. I changed oil and filter putting in VAL 20w50 dino. Took the bike out and rode it hard on twisties and NO smoke !!!!!! The only time it puffs anything is when it cold starts, then it's more of a whispy white that quits after a second or two. Weird........ but consistent with some of the stories you all shared. Thanks !!!! Martin Last edited by mloerts : 07-04-2009 at 12:00 AM. |
10w30 is too light... especially for an air-cooled bike, unless you live in Nunavut... and even then, it really should be an MC-specific 5w30 (pretty much impossible to find in the US).
The fact that it's still smoking means that the problem isn't fixed... it's just slowed down with the heavier oil. The 10w30 that was in there, depending on how long, has probably sheared down to a 15-20wt. The smoking will worsen as the 20w50 shears down. Be sure to keep an eye on the plugs for oil fouling. How many miles are on the bike? Has it ever been stored for an extended period (especially outdoors), and if so, what procedure was used to restart it? If it was stored and moisture in the air formed rust on the sleeves, if it was just kicked over with the starter, it could have a broken ring. Proper restoration if the engine shows any resistance to turning over by hand would be to remove the plugs, soak the cylinders in PB Blaster, then GENTLY rock the pistons loose. High mileage? Could be valve guides, or the rings simply may be shot.
- Rich 2006 1600 Ultra-Classic Patriot Guard Rider Please put your bike year/model in your sig line or fill in your profile before asking for help. |
Can't find time to ride
If you perform a leak down test, it will tell you "exactly" where you stand; no more guess work. If it passes, you have a nice solid engine to drive where you like, if it is marginal, then a decision can be made on what to do in the future.
10w30 in an air cooled engine is certainly a concern, but in an engine with a built up crank... I just would not feel comfortable! |
#4 (permalink) |
hates stupidity
10W30 is definitely too light. I wont run lighter than 15W40 in my bikes. I'm just uncomfortable with any other weight of oil.
ZedX 1k owner. henceforth The bike shall be Zed. |
#5 (permalink) | |
'80 1000B LTD
Thanks for all the help !!! Martin Last edited by mloerts : 07-03-2009 at 11:59 PM. |
#6 (permalink) |
Foil Inspector
Kawasaki recommends 10W40, 10W50, 20W40 or 20W50 for these engines. Any xW30 is too light.
I originally used 20W50, found that 10W40 made shifting gears a little easier, and lately changed to 15W40 mainly to avoid the "energy conserving" additives that can cause clutch slippage.
Bill Frazier 1982 KZ440LTD Original owner |
#7 (permalink) |
Here is a pretty good description of a leak down test. It eliminates any variances connected with cranking speed, compression releases, etc. Really the best way to go; it would be money well spent in your case, I believe.
WC Engineering : Compression and Leak Down Testing |
| Confused about oil where it shouldn't be on a VN900 Classic | LVCigarz | Kawasaki Cruisers | 5 | 05-26-2008 10:26 PM |
| Beware of auto oil and additives | JK591 | Kawasaki Cruisers | 99 | 04-03-2008 01:32 AM |
| Update on Coolant in Oil Problem | Harry Balzac | Kawasaki ATV and Mule | 2 | 06-12-2007 09:04 PM |
| If you build it, they will come. (Oil leak update) | Depmodeche | Kawasaki Cruisers | 5 | 06-26-2005 07:22 PM |
| UPDATE: should i change over to synth. Oil | 71_307 | Kawasaki Streetbikes/Sportbikes | 30 | 08-28-2004 09:40 PM |
