Old 10-03-2009   #41 (permalink)
Laar Jorgens
Can't speak for the stock turn signal from your bike but mine has only a single filament bulb in it, and 2 wires, one is ground and one is the hot lead to the bulb. It sounds like you're trying to use a multi-purpose turn signal/running light combo unit. Wrong bulb and wrong for the bike.
Laar Jorgens is offline   Reply With Quote
Old 10-03-2009   #42 (permalink)
rstnick
Can't find time to ride
rstnick's Avatar
The stock flasher relay often doesn't work with aftermarket signals.
You can get an electronic (modern) flasher relay for under $10 which may just sove your problem.
Vid
pics
http://www.kz650.info/
rstnick is offline   Reply With Quote
Old 10-03-2009   #43 (permalink)
blazer8689
blazer8689's Avatar
Hmmmmm now with that modern flasher relay can i get l.e.d's, cause it seems thats all thats out there, L.E.D's . Seems like I look for a regular bulb turnsignal companys just dont carry as much.
And where would I look to find a modern flasher relay, or if you know a good place to find regular bulb type turn signals, Thanks for your time
blazer8689 is offline   Reply With Quote
Old 10-04-2009   #44 (permalink)
StarGate
StarGate's Avatar
Most any auto parts store will have the standard bulbs and most will have the flasher. At least the ones in this area do and I'm way out in the boonies.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 10-06-2009   #45 (permalink)
blazer8689
blazer8689's Avatar
ok I found something that might work on my KZ, but i need somones advise...... will it work?
Heres the link, for custom dynamics:
Motorcycle Trick Flasher Relay
Old 10-06-2009   #46 (permalink)
blazer8689
blazer8689's Avatar
If so, is that all I will need? Can I finally get some led turnsignals??
Thanks guys!
-Eric
Old 10-06-2009   #47 (permalink)
StarGate
StarGate's Avatar
Here is one more like what you need. It's 2 pin like your bike uses so you shouldn't have to cut any wires to hardwire it.
China LED Electronic Flasher. Ningbo Manufacturer, Exporter
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 10-06-2009   #48 (permalink)
blazer8689
blazer8689's Avatar
GREAT! So I just install that and that will work for all four turn signals right?
Old 10-06-2009   #49 (permalink)
blazer8689
blazer8689's Avatar
Default Pics! UPDATE!! (thanks for all the advise and support)
just for an update got some pics, hope you like it SO FAR
BEFORE (what i started with)
AFTER (but not done)
Excuse the mess in the back lol, some more work here in there and a coat a paint she will be done...
Eric
Old 10-06-2009   #50 (permalink)
StarGate
StarGate's Avatar
Even primer is a step up over the flames IMO but I'm just not a fan of flame paint jobs. The headlight hood is something I'd expect to see on a bobber or old hog. The new bars/mirror and small blinkers give it a much sportier look. I see some new rubber too. Nice mods.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 10-06-2009   #51 (permalink)
blazer8689
blazer8689's Avatar
So i buy the flasher CF12ANL-01, install it where the old flasher went, whats the next step? do i still need to buy any resistors?, or inline load equalizers?
or can i just buy the l.e.d's turnsignals and away we go? Sorry for my ignorance but im in dire need of working turn signals. Thanks again!
--Eric
Old 10-08-2009   #52 (permalink)
StarGate
StarGate's Avatar
Based on the load rating for the flasher you should just have to install the blinkers and new flasher and your good to go.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 10-10-2009   #53 (permalink)
blazer8689
blazer8689's Avatar
Thanks Stargate! Well i orderd the flasher and i will keeping you posted on how it goes
Old 10-10-2009   #54 (permalink)
blazer8689
blazer8689's Avatar
Default Clattering??
Octane? Different oil?
Well i went riding coasting around 40-45 smooth sailing for about a half hour or so, then i decided to push it when i got around 55-60 it started clattering (like low octane in a car) well i let go of the throttle and it goes away.
Now when im back to coasting at 45-50 its running quiet again, I hit the throttle to gain speed (no power loss) and then comes the clattering. So I pull of the road and in neutral, rev the motor around 5-6rpms......purring like a tiger.
So im ???????????
Old 10-11-2009   #55 (permalink)
rstnick
rstnick's Avatar
Just run regular gas 87 octane.
Is that what you were using?
Vid
pics
Old 10-12-2009   #56 (permalink)
blazer8689
blazer8689's Avatar
yup! Chevron 87 gas, do i need a valve adjustment? Should i try another type of oil, im using regular 10w-40 motor oil.
Thanks!
--Eric
Old 10-13-2009   #57 (permalink)
StarGate
StarGate's Avatar
Try to find a station that doesn't use ethanol additives in their gas. Have you checked the timing? if the timing is good then I'd make sure the mechanical advancer is working ok, and clean/lube it if needed.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 10-17-2009   #58 (permalink)
blazer8689
blazer8689's Avatar
Default New Coils! BUT...............
Now I got the new accel coils with new plug wires on and did the wired george so 12v, and did the dyna S point conversion. Running DAMN good!
But before all that (new coils/dyna S) i remember id always check the exhaust pipe for each cylinder 1-2-3-4 and all would get hot right away, indicating that all cylinders are working. Now only 1-3 get VERY HOT and 2-4 get HOT but not "very". I got spark on all 4......
Question::
1) Do I have 2 dead Cylinders? If so would the engine be running ok or would there be a big difference in idle?
2) Do I have any crossed plug wires?
And remember I had the old setup (before upgrade), stock points,stock coils,stock wires and the exhaust pipes would get really hot,
P.S. I did pull spark plug wire #2 while it was running but didnt make much difference in idle.....
Ways to drop your motorcycle Freakinout Main Lobby 174 10-14-2009 02:58 AM
Never let a friend ride your bike aftermath4788 What I learned today 52 02-29-2008 10:01 AM
