LinkBack | Thread Tools |
This space for rent
Well, if you do it continuously you'll probably break one or more of the dogs, and may round them off before that. I imagine it's a little hard on shift forks also.
As far as I know, you can shift any manual transmission without using the clutch, some are easier than others though |
itching to ride
I only use the clutch to take off and have been riding for years with no transmission issues. Since most bikes are constant mesh it does no harm to them as long as you let off throttle before shifting. I will use the clutch to downshift, but it can be done without clutch if you blip the throttle. If you just stomp it down without blipping the throttle you could break traction. And repeated riding like this can do damage to the engagement dogs.
It was a strange idea when I first read about it in cycle magazine about 30 years ago. But after trying it I saw there was no grinding or anything so I continued doing it. If you get any grinding then you are not doing it right.
1983 gpz 750 .....the wait is over |
#4 (permalink) |
obstification engineer
How much do you like your transmission ? I'd expect loud noises and catastrophic results eventually . A compromise is to wire the horn button as a momentary contact ignition disconnect through a relay . Apply pressure under the shift lever under acceleration then push the button as you want to shift. It takes a little practice but you'll catch on .This momentarily removes load from the gearbox and allows the trans to shift . Still expect a short lifespan for the trans.
~kop
91 KZ1000 POLICE 84 ZN1300 Battlestar Gigantica 79 XS650 Cox Glow Fuel 75 RD 250 Grenade |
#5 (permalink) |
itching to ride
I have been clutchless since the 70s with no ill issues. Street bikes, dirt bikes, atvs too. Have split a few cases replacing crank bearings and never noticed any wear of the dogs or engagement slots from riding like this. So I will go by my experience plus a few others that I know. No offense but unless you have firsthand knowledge then you are just assuming.
#6 (permalink) | |
I do have first hand experience replacing the 2nd gear pair in variety of bikes including this one . Then again like you I have seen others and ridden myself without using the clutch for upshift w/o incident . My best practical advice for the street is to use the clutch . In a competition environment that all changes . 1 /100 of a second lost or gained every time you upshift is significant . I come from a multi manufacture professional mechanic background that began in the 70's and only ended with terminal burnout several years ago. If you were to cut me I'd more likely bleed Kawi green but on other days it may be Yami yella . I've attended service schools for all the big four as well as well as any other that will have me . We'll have to swap emails . I did some insane things to that 750 mill years ago you might be interested in . ~kop
#7 (permalink) | |
itching to ride
I am probably going to keep it stock at least until next spring and if things work out I may do some mods. But I would hang on to the stock items just in case I decided to get rid of it. Regarding the clutchless shifting you are correct a lot of people do it when under power, and abuse like that will take it's toll. I have seen a few bikes for sale that said needed 2nd gear and automatically I knew what kind of rider they were. But if you roll off the throttle before shifting like I stated then it will not hurt anything. I do it because it is easier and saves wear and tear on clutch and cable. I do not ride abusive but have been known to let it rip in the past to see what it would do. But at 53 those days are behind me. I was actually looking for more of a standard type bike but got such a good deal on this one I jumped on it. I like the size too. I did not want anything over 1000 cc and do not care for the custom stretched out riding style. I have a few friends who have those and I prefer my feet under me. But the gpz is like a standard with pegs more rear-set. And my last bike was an interceptor so I am used to that.
#8 (permalink) | |
Turtle Wax Taster
I have a CR125 powered shifter race kart, and shift WOT @ 12,300 rpm's clutchless. Motocross transmissions are specifically designed to be shifted hard clutchless, so the shift dogs are extra heavy duty, and can take the abuse.
Bikes: '07 YZ450F '01 KX500 '84 GPz1100 '82 GS1100E '06 HD Fatboy |
#9 (permalink) |
itching to ride
I'm gonna retract my earlier statement here if you don't mind.
While discussing this with my son earlier today he pointed out something that I had overlooked. I went over the discussion a bit and mentioned it was a ninja to which he replied that people do not get those bikes to ride easy and they are most likely going to abuse them. So no to clutchless speedshifting.
#10 (permalink) |
Finally Got Into First Gear
any manual transmission can be shifted without the clutch. I always only use the clutch to take off and stop. Shifting between the gears just requires a slight blip of the throttle and can be done at any speed, not just WOT.
Worked as a Kawasaki mechanic from 1981-1985 1984 ZX750-E1 Turbo1984 ZX1100-A2 GPz 1976 KV75 |
#11 (permalink) |
Needs A Real Job
Apply upward pressure on the shifter as you accelerate.
A slight "blip" on the throttle and the bike will pick up the next gear. Smoother than using the clutch is done correctly. I do not ever recall of anyone blowing up anything critical trying this technique.
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
#12 (permalink) |
Eddie Lawson is God!
You CAN upshift clutchless. I can also rebuild transmissions. You want to know how I learned? Rebuilding transmissions for those who upshift clutchless.
A 900 Ninja? Done 20 of those AT LEAST. Stuff's getting rare. Don't tempt fate. You'll lose. |
#15 (permalink) |
hates stupidity
I have ridden bikes where I shift clutchless, and I've seen people providing information supporting the claims that it wont harm anything IF DONE PROPERLY,
BUT and this is a big but. There is a clutch for a reason. In my mechanically inclined opinion, if you use the clutch and dont race, you're not going to hurt ANYTHING. I'd rather leave the clutchless stuff to the racers with spare parts and factory backing to rebuild after each race.
ZedX 1k owner. henceforth The bike shall be Zed. |
#17 (permalink) | |
itching to ride
I still maintain if done correctly there is no problem with potential damage. This comes from shifting clutchless for 30+ years. The quote below that I got from a different forum illustrates the point.
Clutchless Shifting - Sport Rider Magazine Online
#18 (permalink) |
This space for rent
To what degree are you willing to accept accelerated wear? And doing it the way it's described in the linked article will cause accelerated wear, at a minimum to the shift forks (preload shifter for 3-4 seconds on every shift).
It may well take 20 - 30 years for the wear to become apparent, but my youngest bike is 24 years old already, and parts are becoming hard to find. TxTurbo, take a look at the shock rubbers inside your clutch basket on your 750 Turbo, mine are destroyed from the previous owner drag racing it and not using the clutch. Sometimes life just doesn't match the magazine articles for all of us. I have old bikes, and I want to keep, and ride, them, and parts are getting scarce, so I'll use the clutch. My take for what it's worth, I don't own anyone else's bike so do as you like |
| '84 GPZ 900 Ninja FOR SALE (blown motor) only 8000 miles!! | godsend_85 | Streetbikes Buy/Sell/Trade | 14 | 10-10-2009 10:31 PM |
| 1984 Ninja 900 | ricksaia | Vintage Motorcyle Info | 7 | 05-19-2009 06:04 PM |
| 1985 Ninja 900 zx | dreday | Vintage Motorcyle Info | 1 | 04-13-2008 10:30 PM |
| 85 900 Ninja Question? | Sparx | Kawasaki Streetbikes/Sportbikes | 0 | 10-29-2007 11:39 PM |
| 1985 NInja 900 battery not charging | bernuli | The Mechanics Corner | 2 | 06-10-2007 02:24 AM |
