#22 (permalink) |
LOL, it's called waste spark. Meaning both wires fire, but one is firing on the exhaust stroke (waste), while the other fires on the compression stroke. If you think it needs to complete the circuit to the other wire, just try sticking your finger in that wire you have unplugged and see if it completes the circuit by surging through your body to your grounded feet.
#24 (permalink) | |
Third Gear And Gaining
If so, I have $100 that says you are wrong.
1976 KZ900-A4 |
#25 (permalink) |
Click on the following link & read the third paragraph under "Distributorless ignition systems".
Ignition System
1976 KZ900-A4 |
#26 (permalink) | |
Made It To Second Gear
#27 (permalink) |
itching to ride
I seriously doubt that should one plug fail to fire then you would be operating on one cylinder. Yet that is what you are saying. Also the spark does not travel through the cylinder head. It would ground out should that happen.
1983 gpz 750 .....the wait is over |
#28 (permalink) | |
PS - I've done this on mine.
1976 KZ900-A4 Last edited by Mike900 : 08-27-2009 at 02:36 PM. |
#29 (permalink) |
obstification engineer
gaaaaaaaaaaaaaaaaaaaaaaaacccccccccccck
let us walk out to my 80' with the dyna coils and 16v system . I'll disconnect #4 spark plug wire and stick #1 in your pocket . we will then verify that removing #4 spark plug wire does not also disable #1 . Now on the 12 V side , yes , disconnecting the 1-4 coil from the harness does disable #1 and #4 (well yeah) . Has anyone checked the valve clearances on this bike yet ? Has anyone mentioned that with just a little effort and a flashlight you can get an indication of valve condition just by removing a sparkplug and looking down the hole while slowly rotating the engine ? ~kop
91 KZ1000 POLICE 84 ZN1300 Battlestar Gigantica 79 XS650 Cox Glow Fuel 75 RD 250 Grenade |
#30 (permalink) | |
1. Yes I read your link. 2. It's an autozone automotive topic (need I say more). 3. Your link also states that "and the distributorless ignition system (introduced in the mid 80s)." and if you want to compare that to what bikes are running then you should check what the 73 KZ900 was running. 4. Nowhere in your link did I read where it said if one wire "fails/is not firing" the other side of that pair will not fire. |
#31 (permalink) |
I didn't say anything about your 80' with the dyna coils and 16v system. If it works the same as the stock system then try it yourself. I'd do it if we lived a little closer. All you really have to do is pull the wire & keep it far enough from the engine that it can't make the jump. Now start it & see how many exhaust pipes get hot.
stratgooroo - sorry this thread has gotten so far off track. I can tell you with 100% certainty that if I pull #4 wire that #1 will quit firing. I imagine you realize I'm correct since you're doing the same thing with the same results. If you have any doubt then connect a spare spark plug to the wire & rest the plug on the engine. My money says your idle will improve.
1976 KZ900-A4 |
#33 (permalink) |
I have a video for you as soon as I can figure out how to convert avi to something I can post. I'm assuming you know how an inductive timing light works and what the trigger is for the timing light to flash though. Of course if you have a different theory on what triggers the timing light then this video will not be of much use to you.
#34 (permalink) |
Mike900, you suggested I go out to my bike and try it. Well just for your viewing pleasure I have gone to the trouble to make and post this video. Now if on your planet, an inductive timing light is triggered to flash differently than it is here on Earth, this video will not be proof for you that the other cylinder is still firing. If on the other hand your timing lights work the same as ours, then this should be sufficient proof to you that even though one wire is disconnected, the other will still fire.
YouTube - Plug firing test P.S. cash, money order, or paypal will work just fine. |
#36 (permalink) |
I've been trading emails with Dynatek's tech support. I'll see if I can get permission to post the reply's tomorrow. Due to their confidential clause & needing the answer to a couple more questions I'm just going to give a real quick summary for now.
According to them the coil senses which cylinder is on the compression stroke & the spark travels down that wire, through the cylinder head & back up the other wire. So apparently the voltage is constantly switching which wire it travels down. I suspect this is just the path of least resistance due to the compressed fuel/air mixture. The switching between wires sure surprised me. StarGate - I'm not sure what to make of your results with the timing light. I'll try a few things on my bike tomorrow.
1976 KZ900-A4 |
#37 (permalink) | |
itching to ride
The one cylinder comment was meant two. Was kind of rushing without checking. I have replaced auto coils where I had a dead miss on one (1) cylinder. The other did not quit working just because its twin did. And as I posted earlier the fire cannot pass through the head like that. Try pulling one plug wire off the plug from each coil and see if all four fail to fire. Because according to your theory that would kill any fire to the plugs.
#38 (permalink) | |
itching to ride
#39 (permalink) |
I see you're having a real hard time believing this & don't know how we can help. I 1st saw it in a Chilton's manual for a 1989 GM 3800. I just found it on Autozone last night & got the reply back from Dynatek today. I'm sure there's tons of articles if you hit up Google.
1976 KZ900-A4 |
#40 (permalink) | |
First you believe a post where their research has lead them to believe the distributorless ignition didn't come out till the mid 80's, and now you are going to go with someone telling you that a primary and secondary winding, bundled in some ABS plastic, is some how "sensing" which cylinder is on the compression stroke. Then, even though it doesn't contain a switch, is able to switch which wire fires. Or maybe you're saying it has a switch that reverses polarity. I guess the second description sorta blows the first one out of the water since they maintain that it works differently than that.I was afraid that the inductive timing light might not work the same way on your planet, and I see now that it doesn't. Since we obviously live in different worlds, I will stop trying to convince you of how things work in this one and let you go about your buisness. Have a good one. |
| Pilot screws, spark plugs, one cylinder, and lack of experience.... | JojoDVM | Kawasaki Cruisers | 32 | 06-29-2009 10:33 AM |
| cylinder not firing | azrookie | Vintage Motorcyle Info | 6 | 05-05-2009 02:02 PM |
| Only one cylinder firing??? | Johnpaul1839 | The Mechanics Corner | 2 | 07-27-2008 12:16 PM |
| one cylinder not firing | jneaves | The Mechanics Corner | 13 | 08-28-2007 04:14 PM |
| Only one cylinder is firing | MotorBone | Vintage Motorcyle Info | 5 | 10-18-2005 09:24 AM |
