Needs A Real Job
Ash over here:
KZrider.com - Home (another bunch of Kawasaki lovers)
Mike Folks |
Norfolk,England
Valve clearance [cold] Inlet & Exhaust = 0.05-0.15 mm
Oil capacity = 3.0L [3.7L with new filter] Idle speed = 950-1050 RPM Spark Plugs = NGK BR8ES gapped 0.7-0.8mm Fork Oil = 10W20, capacity = 339cc both sides, Level from top of tubes = 470+/- 2mm
'Dying a'int much of a living boy' Outlaw Josey Wales |
#4 (permalink) |
Sit speling cheker
are regularly on ebay for uinder 20 bucks. The A2 and the Spectre are almost the same bike. Engine is the same....I have both.....The only difference is the tank, sidecovers, seat, and chrome vs black finish....chris3
#5 (permalink) |
Thanks for all your help. I found a free downloadable manual at wiredgeorge motorcycle carburetors - Vintage Japanese Motorcycle Carburetor Sales, Rebuilding and Restoration - Home. It's for a kz1100 B, but everything I've found says there's only slight differences, like the tank and shocks, etc. Should be the equivalent mechanically. Thanks again.
#6 (permalink) | |
Made It To Second Gear
1982 GPz750 1982 GPz1100 1977 KZ1000A 1975 Z2A |
#10 (permalink) |
Link to eBay auction for the genuine Kawasaki shop manual...
ORIGINAL FACTORY KAWASAKI KZ1100 SHAFT 81-84 SER MANUAL:eBay Motors (item 140345469046 end time Oct-11-09 17:02:13 PDT) There are a number of them on eBay...your best bet is the third edition (part number ends in '03') as that will definitely cover your bike.
#11 (permalink) | |
Again, Thanks |
#14 (permalink) | |
obstification engineer
~kop
91 KZ1000 POLICE 84 ZN1300 Battlestar Gigantica 79 XS650 Cox Glow Fuel 75 RD 250 Grenade |
#15 (permalink) |
Needs A Real Job
Some information about the older style glass tubed fuses found on the older Kawasaki's:
Fuse And Fuse Holder Designations 1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter. 2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter. 3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work. 4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape. 5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable. 6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO. 7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses. 8. A list of where to purchase “Blade” style fuses and holders: Welcome to Waytek Wire Susquehanna MotorSports Del City - Wiring Products and Professional Electrical Supplies __________________________________________________ _______________ Alternator Testing For the Older 4’s(Z1’s,Kz 900’s, Kz1000’s,Kz1100’s and GPz1100’s). To check to see if the alternator is working you need to follow these simple steps: 1. Fully charge the battery as this will be the power source during this test. 2. Disconnect the Regulator/Rectifier at the plug that has the six wires in it. 3. Start the engine and let it warm to operating temperature. 4. If you're worried about overheating, position a large fan for cooling the engine. 5. After the engine has reached operating temperature, have a helper assist you, and using a multi-meter, read the output at the three yellow wires (or the alternator output wires)at the disconnected connector. 6. Raise the engine speed to 4000 rpm, and see what the three YELLOW wire combinations(or any alternator output wires) are(1-3,2-3 & 1-2). The output will be around 50 Volts A.C.(Alternating Current). BE CAREFUL, AS THERE IS A SHOCK HAZARD HERE!! 7. If any of the combinations are low or non-existent, the stator(wire windings) are bad and must be replaced. Some of the older Z1’s and KZ900’s were phase sensitive, so check the wire colors carefully. 8. Before ordering a new stator, check the connections from the stator as there are electrical "Bullet" connectors that may be damaged or dirty. Inspect the wiring for signs of shorting or overheating too. Z1 Enterprises, Inc. - Specializing in Vintage Japanese Motorcycle Parts sells replacement rubber grommets for the alternator output wiring, they get hard and could leak oil after a while. 9. Check the wiring coming out of the grommet as there have been situations where the wires were damaged causing a short. 10. The sprocket cover may have to be removed to access the electrical connectors coming from the alternator and possibly the left foot peg, and shifting lever will have to come off.
Mike Folks |
| KZ1100 Fuel Tank | Localmode | The Mechanics Corner | 6 | 05-11-2009 03:40 PM |
| New Dyno tune for my V2K | gdhugh | Kawasaki Cruisers | 17 | 11-24-2008 10:03 PM |
| 2003 KX125 Torque Specs? | rebelmhz | Kawasaki Motocross and Offroad | 1 | 09-28-2008 10:41 AM |
| Parts wanted, Atlanta, kz1100 cylinder sleeve and others... | Duck | Accessory Swap Meet | 0 | 10-15-2006 12:04 PM |
| I NEED FULL TORQUE SPECS ON MY 92 ZX-7R ENGINE INTERNALS | sacramentoboy916 | The Mechanics Corner | 2 | 01-10-2004 12:41 AM |
