LinkBack | Thread Tools |
Dave Hayward-Valhalla,NY
I'm trying to remove the starter clutch from the crankcase
How do I disengage it so I can slip it off the secondary shaft? |
Needs A Real Job
KZrider.com - Home should be able to help.
Mike Folks |
#3 (permalink) | |
This space for rent
To answer the orignal question: There is no "disengaging" the starter clutch on the 750 four, once you have the secondary shaft loose it should slide right out. . |
#4 (permalink) |
Thanks!
I guess I have to keep tapping on the left side of the secondary shaft 'till it dislodges from the starter clutch and the large sprocket to the right. I'm concerned that I'll damage the sprocket (or interior of the crankcase) by banging it up against the right side of the crankcase I'll try placing a small piece of wood between the sprocket and the crankcase |
#6 (permalink) |
Thought I'd let you know. I gave it another shot this morning and the secondary shaft came out. The starter clutch fits onto the secondary shaft very tightly so I used a long metal bar with a blunt end. Placed it against the left side of the shaft and kept tapping away until - eventually it came out the right side of the bike
Here are some pix I put on Picasa: Picasa Web Albums - Dave - Starter Clutch One of the springs in the starter clutch seems to be shot which, hopefully is why the bike was only making a rattling sound when I pushed the start button, and not catching Thanks for the help! |
#7 (permalink) |
Here are some pix of the starter clutch
One of the springs was broken Amazing a little thing like this could wreak so much havoc! Now - to put it all back together and see if it works! Picasa Web Albums - Dave - Cluch |
#8 (permalink) |
I fixed the starter clutch and but her back in
and - - it works!! Started right up!! One hitch though Before I repaired the starter clutch it would not start at all - just the "rattling" noise when I pushed the start button I still get the rattle but infrequently My guess is - it'll get worse if I don't do something about it Sounds like I'm shaking gravel in a coffee can Something else is going on and I haven't got a clue - - - Any thoughts? |
| 87 Ninja 750 clutch question | Brackneyc | Kawasaki Streetbikes/Sportbikes | 3 | 07-14-2009 02:18 PM |
| kz 400 starter on a kz 440? | Alibi | Vintage Motorcyle Info | 8 | 09-30-2008 09:27 AM |
| Is shimming my clutch push rod an acceptable solution? | Neep | Vintage Motorcyle Info | 7 | 08-25-2008 05:20 PM |
| 1991 Ex500: Starter Clutch ???? | wenks | The Mechanics Corner | 1 | 05-03-2008 04:20 AM |
| starter clutch? | 88ex500_inbosto | The Mechanics Corner | 4 | 06-26-2006 10:15 AM |
