Old 09-24-2009   #1 (permalink)
sklenny
Default '81 650CSR in storage for 17 years
I recently got ahold of a '81 650 CSR that's been in storage since october of '92 in a pretty dry climate, it seems to be in pretty good condition. This is my first bike, but I have a mechanic and a few other motorcycle enthusiasts helping me out on the project. What do you think needs to be done? Besides degunking the carbs, maybe readjusting them and getting new tires, spark plug and battery
What's the best way for getting the rust out of the gas tank?
Thanks.
sklenny is offline   Reply With Quote
Old 09-24-2009   #2 (permalink)
Hot Cruiser
Politicians' Nightmare
Hot Cruiser's Avatar
This thread has some suggestions about removing rust from gas tanks:
http://www.kawasakimotorcycle.org/fo...nk-repair.html
And welcome to the forum!
Jim
'07 Vulcan 900 Classic LT
Jesus is Lord
Hot Cruiser is offline   Reply With Quote
Old 09-25-2009   #3 (permalink)
StarGate
StarGate's Avatar
It's been sitting for 17 years so replace the tires and inspect any rubber parts closely. Extra attention to the brake lines, vacuum lines, fuel lines, and the rubber connectors on both sides of the carbs but mainly the holders. Also be sure to flush the old brake fluid out and get some new clean fluid in there and test the brakes before you try to ride it. I used a POR-15 kit on my tank to resolve rust issues and after 3 years it's doing fine.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 09-25-2009   #4 (permalink)
OKC_Kent
Riding every day!
OKC_Kent's Avatar
Change the engine oil and filter. Lube the throttle and clutch cables.
I would throw a teaspoon of oil in the cylinders before starting it up, it's probably very dry in the top end after 19 years. I would remove the plugs and crank it over until I'm confident that oil has gotten to the top end...you might need to remove the valve cover to see if oil is getting up top to the cams.
Oklahoma City
'78 KZ 650
'83 KZ 750
Proud Marine Corp Dad
OKC_Kent is offline   Reply With Quote
If you only had 2-3 years to ride would you buy a Drifter? Molee Kawasaki Cruisers 48 10-13-2008 05:18 PM
25 Years ago...Terry Fox Marathon Of Hope trikebubble Off Topic 3 09-20-2005 04:38 PM
What years of radiators will fit a 99KX 250 Red Dog1 Kawasaki Motocross and Offroad 2 07-03-2005 10:09 PM
motor in after 15 years in storage! PICS CruisingRam Vintage Motorcyle Info 9 04-12-2005 03:51 AM
What changes have been made to the Ninja500 over the years? jdircksen Kawasaki Streetbikes/Sportbikes 6 11-09-2004 01:07 PM
