Old 09-25-2009   #1 (permalink)
pablos
Default 1983 Kawasaki LTD 750
I have an LTD in very good condition. I am cleaning it up and repairing/replacing what needs to be fixed. The rear brake lever slants slightly downward. Normally I would think that someone had dropped the bike and would replace the lever. But looking at the bend it looks like maybe it was manufactured that way. I have tried looking at pictures and cannot tell if this is the way its supposed to be or not.
Can someone verify if the lever should be straight or bent downward?
thanks,
pablos
pablos is offline   Reply With Quote
Old 09-25-2009   #2 (permalink)
StarGate
StarGate's Avatar
What part of it or where are you talking about a bend? Also you said "rear" but you also said "lever". The front brake uses a lever while the rear uses a pedal. So which one are you referring to and where exactly is the suspected bend?
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 09-25-2009   #3 (permalink)
pablos
My bad,.., Not the pedal but the front brake lever. It comes straight out of the bracket/pivot point then begins to curve down. Normally I would think if it was dropped it would bend in the middle of the lever, but this one bends just after coming out of the bracket or swivel. I just have never seen a bent lever.
Old 09-25-2009   #4 (permalink)
StarGate
StarGate's Avatar
My bike is an 81 LTD and also had the lever that sloped downward as it came out of the master cylinder and pivot point. I guess that was the way they were designed for bikes with the mini ape hanger style handlebars. I never really noticed mine being bent looking like that (in all the years of riding it) until the first time I removed the master cylinder from the bars.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 09-25-2009   #5 (permalink)
herk
bustedfeet
herk's Avatar
Yes, the lever is kinda angled down because of the handlebars.
My 81 650-CSR probably has the same bars & levers as your bike.
herk is offline   Reply With Quote
FS: Kawasaki Vulcan 800 Classic - $3200 obo (Chicagoland area) Beknatok Streetbikes Buy/Sell/Trade 0 06-17-2009 10:28 AM
swingarm for 85 ninja coverdog Vintage Motorcyle Info 3 05-21-2009 05:23 PM
2000 Super Sherpa KL250, CDI problem hotrodkj The Mechanics Corner 3 04-25-2009 02:41 AM
Kawasaki can make you sick. Uncle Bob Off Topic 24 01-15-2009 03:00 PM
Kawasaki 250cc Rants&Raves Specialist ZX-2R Main Lobby 41 10-12-2007 06:06 PM
