Old 09-25-2009   #1 (permalink)
ChicagoLTD
Default 18" Wheels KZ550
I am bobbing my 81 KZ550 LTD, and Id like to put 18" spoke wheels on it. Any suggestions as to what other year KZs I could get them off of ? I guess the front is not as important.
I know some of the late 70s kz650s, 750s had them, just not sure if they would work out correctly.
Ive seen quite a few mid-later 70s kz400s as well, but I think they are 16". I guess id settle for that on the rear.
ChicagoLTD is offline   Reply With Quote
Old 09-26-2009   #2 (permalink)
herk
bustedfeet
herk's Avatar
The 81-83 KZ650-CSR has wire spoked wheels - 19" front & 16" rear.
These are a direct bolt-on to your bike. They're readily available on ebbaayy.
Search for KZ650 wheel or KZ650 CSR wheel.
herk is offline   Reply With Quote
Old 09-26-2009   #3 (permalink)
ChicagoLTD
thanks for the info
is there any way to tell, or anything that i should be noting to see if other years will fit? I want to keep the stock drum brake on there
Currently I dont see any for 80s kz650 today, but there are a couple from the late 70s.
Old 09-26-2009   #4 (permalink)
herk
bustedfeet
herk's Avatar
You could try cross-referencing hub parts at Kawasaki.com.
The 650-CSR wheels are by far the simplest way to go. They are plug-n-play.
Other bikes to look into: 82 KZ750-CSR-Twin, 70s KZ650s w wire wheels (B-models).
Maybe the 70s 750-Twins - don't know.
Also, search the internet for jarle Z650 - the first result is a comprehensive 650 site w lots of info & photos.
Old 09-26-2009   #5 (permalink)
herk
bustedfeet
herk's Avatar
Originally Posted by ChicagoLTD View Post
.... Currently I dont see any for 80s kz650 today, but there are a couple from the late 70s.
Other searches: KZ650H, KZ650CSR, 650CSR, CSR650, 650H, Z650
Also, if you find someone selling a CSR front, ask them if they've got the rear.
Here's a rear wheel - kawasaki KZ650H 1981 rear rim
Edit: I stumpled across this one on Tuesday. 1981 KAWASAKI CSR 650/KZ 650 REAR WHEEL & TIRE
Vn2000 Wheels matt15 Kawasaki Cruisers 9 09-18-2009 11:58 PM
Question about wheels pwdavid1 Main Lobby 2 03-12-2009 11:55 AM
Kwasaki 3010 wheels different Kawasaki ATV and Mule 13 01-28-2009 06:14 AM
Cleaning Wire Wheels Casper1951 Kawasaki Cruisers 4 05-23-2008 04:05 PM
KX 80 Wheels on a KX 100 97KX100 Kawasaki Motocross and Offroad 3 03-13-2008 05:30 AM
