LinkBack | Thread Tools |
#61 (permalink) |
GHOSTRIDER
Yes! Now your ready for plug reading 101! Click on the photo and click on it again and read and follow this procedure carefully. If you dont understand something, ask and somebody will explain. Your about to gain a higher understanding of internal cumbustion (physics of the flame) PS. I hope you dont mind pulling those carbs at least two more times before getting them right! This is the area of vintage bike ownership that will either break your resolve to FULLY understand your bike......OR,....You will hunger for a more complete understanding of the physics involved in knowing that each cylinder is burning an optimum air/fuel mixture and that ALL the systems of that bike between your legs is running and operating correctly because YOU made it so! Good Luck! And do keep us updated! Oh, The guide below is a Sudco 4th edition Mikuni carb tuning manual,(new school) for "OGs" like me!
"GHOSTRIDER" 1980 KZ1000ST-E2 |
#62 (permalink) | |
#63 (permalink) |
Finally Got Into First Gear
well, I went for a ride today, ahhhhh that 70 mph mark!!!!
#65 (permalink) |
yes, bench synch I did. I noticed now being more informed and more confortable that the last carb on the right appeared to have been dissasembled before, and that same throttle valve was way out of synch. I have the same exhaust as you (except doesn't look as pretty) I am thinking of putting the cap back in (withouth the actual baffle) depending on how it sounds I might test drive it and make final adjustments from there
#66 (permalink) |
GHOSTRIDER
Very good! The high rpm during full choke is normal! Adjust the choke to bring the rpm down once the engine fires and make adjustments untill its warm. The cap on the exhaust is a good idea, tune the carbs with the cap in. Do keep us updated, Im probably as excited as you are! Cant wait to hear about your first "V-Twin Kill"!
#67 (permalink) |
I AM PSYCHED man
#68 (permalink) |
hey zoro: r those cafe style bars you've got on ur lady or a straight bar? looks nice, I wanna change mine once I get it running right, I gotta change the oil and seals on the fork so I figure I do it all at once
#69 (permalink) |
GHOSTRIDER
Theyre called "Superbike" bars, $15.00 at Z1 Enterprises.(not including shipping) Good idea on the fork seals. Be concise on the refill amounts, its critical for front stability!
"GHOSTRIDER" 1980 KZ1000ST-E2 Last edited by zoro : 3 Weeks Ago at 12:13 AM. |
#71 (permalink) | |
GHOSTRIDER
#72 (permalink) |
well right now I only have the end cap on there, U think I should put the baffle pipe in too??? I"m not too crazy about noise, in the sense that I dont want cops ticketing me every other week, but I also wanna get that performance (and some sound, riding that thing with the baffle assembled was almost like riding a bicycle)
#73 (permalink) | ||
itching to ride
My bike has stock mufflers and has a bit of sound. Actually a nice meaty sound which was a pleasant suprise as I had been thinking about working them for a bit of noise. Grind the rivets, pull the baffles, rework them, and reinstall for a nice factory clean look. May still do depending on how loud it turns out to be.
1983 gpz 750 .....the wait is over |
#74 (permalink) |
GHOSTRIDER
Im not understanding, my baffle and end cap are one piece about 16-18 inches long (originally) wrapped in coarse fiberglass, it fits in the megaphone.
"GHOSTRIDER" 1980 KZ1000ST-E2 Last edited by zoro : 3 Weeks Ago at 02:12 PM. |
#75 (permalink) | |
GHOSTRIDER
#76 (permalink) |
The baffle and end cap on my kerker 4-1 were separate pieces. I ran it for a long time with just the end cap but it was loud. With the way that sound carries at night, in this small town (less than 3k people), if I opened the throttle up it could be heard by the cops on the other side of town.
#77 (permalink) | |
GHOSTRIDER
#78 (permalink) | |
you know, every time I get together with this thing it teaches me something. the trouble is, it seems every time I learn something it costs me money. My tach stopped working, I checked the cable thinking there was some sort of magnetic/AC voltage generating sending unit (like a speedo on a car) only to find out there was a mechanical shaft actually rotating inside that cable, going up to the head, I thought that was interesting. oh yeah, mine is broken, so I guess i gotta order a new one. Any how, I post update later... |
#79 (permalink) |
GHOSTRIDER
"Kerker" is a is a good pipe! Baffle in is a good idea. And yes these older bikes can be expensive at first. The expense tapers off though, and your practically there. I REALLY like your bike! I like the spoked wheels too!
#80 (permalink) |
OK, here's the latest: first thing first, I took my practice-test on friday and passed!! yay!!! I am now a licensed rider (which will make road testing a lot easier, before I was only allowed to ride with a licensed rider next to me) NOW< BACK TO THE BIKE: I am entering the point where trial and error will probably be the only way to get it running right, as you guys know, once I achieve the proper mixture the LAST thing I'd want to do is to make any changes o the exhaust system that would affect the mixture, so I decided the best thing to do was to decide how loud I wanted the bike to be, leaving the baffle as it was, was not an option for me, no fun. so I removed all the guts, and placed only the tailpipe back in (which acted as a megaphone) man that thing was loud!!! so I put the end cap back on without the baffle or the fiberglass, sounded more like what I wanted to hear, then tried to put only the baffle, without the fiberglass and wasn't so thrilled so I took the baffle back out, my Chromed headlight and gauge covers are here and installed, Seat is at the upholstery place till wed and the replacement battery is going back in tomorrow, I actually strapped some packing foam where the seat is supposed to be in case I get a chance to ride before wed, I'll post some pics once I get everything squared away, tach cable is on order, Oh, did I mention the cam end seals/caps are leaking oil, they are here as well, man, I know I'm almost done (or at least I think I am) but this thing has taken a lot of work...
