Any motorcycle oil is fine. Valvoline 20w50 is decent stuff for a non-synthetic.
The zinc has been removed from automotive oils.
- Rich 2006 1600 Ultra-Classic Patriot Guard Rider Please put your bike year/model in your sig line or fill in your profile before asking for help. |
#4 (permalink) |
Turtle Wax Taster
I've been running Valvoline 20W50 for quite a while and have no complaints.
Lew 82 KZ1000-J2 06 H-D FXD35 In the past...72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K |
#6 (permalink) |
GHOSTRIDER
Hi David, welcome to the forum. Ive been running Mobile-1 Racing 4T 10W-40 "motorcycle oil" for well over a year now with no negative effects. Its formulated for wet clutch primaries and extreme heat and pressures. These older bike engines need the "Zinc" formulas for protection for two reasons,1)Loose tolerances(compared to today's). 2) Zinc is the last remaining defence against metal to metal contact when thermal breakdown and high heat conditions exist. The only negative effect involved in using Mobil-1 4T motorcycle oil is its price, its $10.00 per quart!
"GHOSTRIDER" 1980 KZ1000ST-E2 Last edited by zoro : 09-29-2009 at 08:20 PM. |
#7 (permalink) | |
It (and Amsoil) hold their viscosity well enough so that change intervals can be doubled or even tripled (assuming current change intervals of 2000-3000 miles). That $10/qt now costs the same as $5/qt conventional oil... plus it saves you $6-$15 on the filter... and if you aren't changing your own, it saves you labor charges. Full synthetic can be cheaper than dino Just set aside $5/week and you'll always have enough in the piggy bank when it's time for an oil change.
#8 (permalink) |
Turtle Wax Taster
I am surprised this "which oil" thread hasn't already turned into an all out war....
Just for the record, i'm not a fan of running a full synthetic in 25+ year old wet clutch motorcycles. I had major slipping issues with an old 78 CB750, and it happend right after I swapped over to Bel Ray full syn oil... then again it might have been the clutch in the first place, but swapping back to a std oil actually got the clutch grip back....
Bikes: '07 YZ450F '01 KX500 '84 GPz1100 '82 GS1100E '06 HD Fatboy |
#10 (permalink) |
Turtle Wax Taster
$11 a gallon?
Isn't that Rotella stuff like $11 for a 55 gal drum? If I have to do an oil change after i've paid my mortgage, and i'm broke, I just go raid the wife's food pantry and use this stuff:
Bikes: '07 YZ450F '01 KX500 '84 GPz1100 '82 GS1100E '06 HD Fatboy Last edited by Polar_Bus : 09-30-2009 at 12:17 PM. |
#12 (permalink) | |
itching to ride
Cooking oil not work well unless maybe you are frying chicken. You can always over spend and buy $40 a gallon oil like the millionaires do.
1983 gpz 750 .....the wait is over |
#14 (permalink) | |
It's API-SM, and it's primary base stock is beef tallow... claims to hold up long enough to meet all auto manufacturers' maximum change interval (7,500 miles). I'd love to shoot a sample of that to Blackstone and then send another sample after 5,000 in the cage, but as with most "green" technology, it probably costs more than Amsoil.
#15 (permalink) |
Or adding back in the lubricity needed to keep your injector pump alive that the EPA took out when they changed Diesel to ultra-low-sulfur.
#16 (permalink) |
My hat is made of tinfoil
On an older bike, I really like Shell Rottella 15w40 oil.
Thats what iuse in my old timers, and my customers to.
Hug a person that needs one, not some damn tree you fool. |
#17 (permalink) | |
itching to ride
She had to take the fan apart and oiled it as best she could. I wish they still made them with the oil holes like they used to.
#18 (permalink) |
They assume you're just going to toss it and buy a new one.
A lot of fans are cheaper than a can of Tri-Flow.
#20 (permalink) |
Hey.... those 5 blade disposable razors make my head sexy smooth!
Curly hair, so even with a fresh shave from an electric I have as much stubble as if I haven't shaved for 24 hours.
| 2004 Vulcan 2000 - need all kind of help | V2Kuser | Kawasaki Cruisers | 35 | 10-13-2009 11:16 PM |
| Mobile 1 10W 40 -- Last Call | alekkas | Kawasaki Cruisers | 90 | 09-21-2009 02:17 PM |
| Oil Change Instructions | BigJohn | Off Topic | 20 | 03-24-2008 12:56 PM |
| Blinking Oil Pressure Light | MTNFSH | Kawasaki Cruisers | 23 | 12-04-2007 05:46 PM |
