Old 09-28-2009   #1 (permalink)
squawk
Finally Got Into First Gear
Default Oil Filter Question?
So I changed the oil and the filter came with 2 o-rings a small one and a large one. When I took of the old filter I saw were the larger one went but did not see a small on anywhere. What's the small o-ring for?
squawk is offline   Reply With Quote
Old 09-28-2009   #2 (permalink)
herk
bustedfeet
herk's Avatar
Oil filter bolt. Reference the diagrams at Kawasaki.com.
herk is offline   Reply With Quote
Old 09-28-2009   #3 (permalink)
squawk
I've been looking for the diagrams on Kawasaki.com and can't find any.
Old 09-29-2009   #4 (permalink)
herk
bustedfeet
herk's Avatar
Kawasaki.com -->> Owner Info -->> Parts diagrams -->> etc
I find it easiest to do the Search-by-Model-Info without entering a vin or anything.
Just click continue, pick a year only, continue, then choose a bike from the list.
Old 09-29-2009   #5 (permalink)
squawk
Maybe that's why? I'll try it or it could because I have a 1980 KZ750H and they don't have diagrams for bikes that old?
Old 09-29-2009   #6 (permalink)
herk
bustedfeet
herk's Avatar
They have diagrams for bikes from 1975- or 76-on, so yours is covered.
However, the vin search only works for the 17 digit vins.
Old 09-29-2009   #7 (permalink)
squawk
Smile
Sweet...thank you so much Herk, found them now.
Old 10-02-2009   #8 (permalink)
squawk
Oops...I think I put the little 16mm o-ring inside on the bolt underneath the filter. Seriously do not have 40.00 to change the oil again. Think it will hurt anything to leave it in there?
Old 10-02-2009   #9 (permalink)
herk
bustedfeet
herk's Avatar
The small o-ring seals the the oil filter bolt against oil filter plate.
The big o-ring seals the oil filter plate against the oil pan.
Old 10-02-2009   #10 (permalink)
NH Lar
You will not hurt a thing by leaving it there til you change the oil again. Being an old Voyager XII guy with approximately 100,000 miles of time on them, and having done many oil changes I must tell you that I changed the large o-ring every time, and the small one about every fifth change, and never had any trouble. The KZ uses the same filter.
Larry
VROC # 4737
06 VN 900 Classic LT
NH Lar is offline   Reply With Quote
Fram Oil Filter Change vmuth Kawasaki Cruisers 24 09-12-2009 12:57 AM
Oil filter removal Terryd Kawasaki Cruisers 2 07-16-2009 12:46 AM
kz650 oil filter change question kznewbie Vintage Motorcyle Info 6 03-31-2009 01:22 PM
men's rules for women - wouldn't let the wife see Freakinout Off Topic 48 02-26-2008 10:59 AM
