#21 (permalink) |
itching to ride
Would the zero guage be for setting hydraulic actutated valves?
I am thinking it still may be a valve issue since he said he tried to clean the carbon as best he could. If it was that apparent then the head should have been disassembled and clean thoroughly. I have a wire wheel on one side of my bench grinder I use for things like that but in times past I have chucked the valve in a drill and used a dull knife to scrape off the carbon. I also use a drill to touch up the valve seats by applying a little valve grinding compound on the valve face and seat and spin it in the head with the drill. I do this any time I take any valves out of a head. I had an old ford pinto that had a leaking valve that I fixed that way years ago.
1983 gpz 750 .....the wait is over |
#22 (permalink) |
You've got a 0, it's right next to the .001, you just haven't noticed it.
- Rich 2006 1600 Ultra-Classic Patriot Guard Rider Please put your bike year/model in your sig line or fill in your profile before asking for help. |
#24 (permalink) | |
My hat is made of tinfoil
I was so thin I just could not see it before, but with the magnifying glass, I can see it now.
Hug a person that needs one, not some damn tree you fool. |
#26 (permalink) |
So I called my snap on dealer, wow them zero and negative thickness feeeler gauges are pricey.
He said its because they are a specialty item, and he only sells a few sets a year.
| backfiring | eslmatt | Kawasaki Cruisers | 2 | 09-19-2009 04:15 AM |
| 08 900 custom backfiring and clicking | Clarxhouse | Kawasaki Cruisers | 7 | 07-20-2008 09:14 PM |
| 900 ECU replacement and Backfiring? | Rsmith | Kawasaki Cruisers | 9 | 11-08-2007 11:26 PM |
| ZZR backfiring on start-up | Kawaluvver | Kawasaki Streetbikes/Sportbikes | 3 | 04-06-2006 12:24 AM |
| Backfiring from right pipe | Sgt Mike | Kawasaki Cruisers | 2 | 01-30-2006 11:20 AM |
