LinkBack | Thread Tools |
I own a 1981 kz440 ltd. D1 belt drive. Here is my problem: Every time i start my bike it runs for a around 5-10 minutes and will stop running. The bike will still turn over and i have check for spark with no spark present at the time it shuts off. I have replaced the CDI, Coil, Regulator/Rectifier,pick up coil, and a numerous length of wiring to these components.
MY only Real Question Is ( and this might sound stupid.) but i took a reading of my battery volage after i had ran it and let it die and when sitting and the key off it reads a nice 12 volts and the with the key on and the bike not running this will drop down to only 8 volts. Could this mean that i have a bad battery and could that be causing my engines ignition problems. According to my book it claims that if this condition were present. I would have weak spark and that my rectifier would be working too hard. Thus presenting an overloaded condidtion and burning it out. Consequently harming the CDI because of the AC current present in the bike. IF ANYONE HAVE AN IDEA ABOUT THIS BATTERY PROBLEM, I WILL TRY TO CHARGE IT. But i am not sure how to test if it will hold the charge. PLEASE LET ME KNOW.. THANKS A TON |
#4 (permalink) |
Riding every day!
Andrew,
You should also check the stator output and make sure it is producing the right amount of voltage. You don't mention if you tested the components you replaced, just that you replaced them...did you replace them because they tested bad and needed replacing, or did you replace them because you couldn't think of anything else to do? You could have a bad connection that will not allow the battery to fully charge, and then 10 minutes later the battery gives up; it can't fire the ignition anymore, so no spark, no running engine. Start the bike and measure the voltage across the battery terminals at idle, should be in the neighborhood of 13.0v~13.5v. Then rev it to 4000-4500 rpm and measure the battery, you should see around 14.5v . What do you get?
Oklahoma City '78 KZ 650 '83 KZ 750 Proud Marine Corp Dad |
#5 (permalink) |
Needs A Real Job
I'd suggest removing the cover over where the sprocket would be on a bike with a chain and check the wiring. The "Bullet" stye connectors can get corrosion and that reduces the current/voltage going to the charging system.
Any green crud on the many and various electrical connectors greatly reduces the bikes operating systems like dim lights,turn signals operating slowly, and battery problems. Get some electrical contact cleaner(Not WD-40!!) from Radio Shack or any other electronics/electrical supply store, spray the open connections and work them in a make/disconnect action to scrub any corrosion off the pins.
Mike Folks |
#6 (permalink) |
You might also have your battery load tested. You can buy load testers pretty cheap (about $40 I think) at Harbor freight, they make one for small batteries like lawn & garden stuff. You might also be able to take it to a shop and they can test it for you. Be sure to charge it first, it has to be fully charged in order to load test.
1976 KZ900-A4: 4-1 header, lowering kit, Hydro-gel seat, no sissy bar, lots of replacement parts |
#7 (permalink) | |
#8 (permalink) | |
#10 (permalink) |
Can't find time to ride
Like the others have said, the battery has to be good or else you will be chasing your tail all over the country trying to repair this problem.
With a fault like this, you have to start with the basics first. Throwing parts at it will only empty your wallet and bike still runs the same. If your bike has running lights that come on with the key, you can do the following quick and dirty battery test: 1. Charge battery for 24hrs. with a 1 to 1.5 amp charger. 2. Let stand for 1 hour, check terminal voltage. Should be "at least" 12.4v. 3. Turn on key and monitor battery voltage. It will start to fall but should level off at 12v or above. If it continues to sag and goes below 12v, battery has one or maybe even two feet in the grave! Post back with your results. |
#11 (permalink) | |
#12 (permalink) |
Yes the CDI can do what you describe about getting hot then failing but will work again once it cools off. If you know for sure that the bike won't start/run after the failure for a certain amount of time (lets say 30 min), then you might try getting it to fail then quickly misting the cdi with water or blowing cool air over it to try and cool it quicker. If it restarts much quicker than normal doing this then you have a likely suspect. Have you verified that the coils still have the +12v at the input when the problem exist?
#14 (permalink) |
[quote=StarGate;1796958]Yes the CDI can do what you describe about getting hot then failing but will work again once it cools off. If you know for sure that the bike won't start/run after the failure for a certain amount of time (lets say 30 min), then you might try getting it to fail then quickly misting the cdi with water or blowing cool air over it to try and cool it quicker. QUOTE]
Or...you can take a hair dryer and play it over the ignitor and see if it will quit in your driveway. I thought you said that you replaced the ignitor. What was wrong with the original? |
#15 (permalink) |
GHOSTRIDER
Igniters are a series of diodes and solid state relays that take the AC impulse from the pick up coils and trigger another momentary open/close impulse to the ignition coils, thus, a high voltage spark. The diodes and relays in the igniter are suspended in an epoxy medium in the back of the igniter. Tiny and often invisible cracks can develop in that medium(for whatever reasons)and when the igniter gets hot,it expands and breaks the circuit necessary to energize and discharge the ignition coils. Now with that said,the previous posters are correct in that this,"works cold and fails hot" condition can exist in the ignition coils as well as in the igniter. Test the individual components cold and test them again hot to try and determine which is faulty. I bet its the igniter! Good Luck!
"GHOSTRIDER" 1980 KZ1000ST-E2 |
#16 (permalink) |
Needs A Real Job
Have you been to this website? THE KAWASAKI TWIN OWNERS FORUM :: View Forum - 400/440 Electrical
If your bike has the mechanical ignition advancer on the end of the crankshaft like the bigger older 4's do, you might be able to make a replacement for what you're calling a CDI, on the Kawasaki's of that vintage they had what was called a "IC Igniter" that actually gave the ignition coils their ground to fire and spark the sparkplugs. A rider over at KZrider.com - Home has made a replacement using off the shelf GM ignition modules for his KZ 550 with two of them. He has run this set up for many mikes with no problem. Since you have a twin engined bike, I'd think just one module would do the job.If you decide to make this modification, I'd suggest using some RTV compound to provide moisture and shock resistance to the resistor and diode(s). The website is: General Motors HEI Ignition Module For GPZ550
Mike Folks |
#17 (permalink) |
hey guys i should have looked at that page you requested for the Gm Ignition mod. I honestly didnt realize at the bottom of the page was the diagram for the twin models. I will give this a try right away and then if it dies i should know for sure that the coil is bad.
| Electrical Problems finally fixed | Schma | Vintage Motorcyle Info | 10 | 09-14-2009 08:51 PM |
| New Member Old KZ! | calvin17d | Vintage Motorcyle Info | 16 | 07-10-2009 04:08 PM |
| Motorcycle electrical wiring supplies and tools | MFolks | Main Lobby | 5 | 06-26-2009 03:41 PM |
| 1992 Voyager XII electrical problems | bobberwi | The Mechanics Corner | 1 | 10-24-2007 12:01 PM |
| electrical problem | $100 ninja 250 | The Mechanics Corner | 2 | 09-23-2006 07:30 PM |
