Old 10-03-2009   #1 (permalink)
oberkfell
Default Headlight only works on high-beam
I was having problems with my LH control pod after I replaced my handlebars.
(77 KZ1000)
Everytime I would flip from High to Low beams a fuse would pop.
In addition, the low beam would and/still does not stay on after startup & revving up the motor. But, the High Beam stays on and does not dim when revving the bike.
I replaced the LH control pod and it fixed the fuse issue, as I assume it was a pinched wire.
I cleaned all the connectors throughout the electrical system and made sure all the wires matchup. I had new plugs, points, condensor, etc. also replaced. The battery is fully charged.
I took the RH control pod off and inspected it, but did not see any damage to the wires.
Any ideas? Alternator/Stator?
oberkfell is offline   Reply With Quote
Old 10-03-2009   #2 (permalink)
zoro
GHOSTRIDER
zoro's Avatar
Send a message via Yahoo to zoro
Have you changed the headlight over to a high intensity type headlight with the small replaceable bulb? If not, dont! If your using the regular three prong high/low 7"round headlight,then one of the filaments is probably burnt,check that out. If your headlight checks out good, then you may have the two positive wires crossed or mismatched at the switch.
"GHOSTRIDER" 1980 KZ1000ST-E2
zoro is offline   Reply With Quote
Old 10-03-2009   #3 (permalink)
zoro
GHOSTRIDER
zoro's Avatar
The 77 KZ1000 has three wires at the dimmer switch. Red/Black, Blue, and Red/Yellow. The headlight connector also has three wires. Red/Black(from the switch,and is high beam) Red/Yellow(also from the switch,and is the low beam) Yellow/Black(this is the common ground and does not come from the switch) Check this out also!
Old 10-04-2009   #4 (permalink)
oberkfell
Thanks, for the tips.
I will try them tomorrow.
Old 10-04-2009   #5 (permalink)
freightshaker
Luv my big boy toys
freightshaker's Avatar
Sounds like this might just be "over thought".
Head light bulbs, like directional bulbs (1157, 3157 etc) have 2 filaments. One for low beam, the other for high. Sounds like the low beam filament might out.
Your brake light works the same way, sort of 2 bulbs in 1. If one filament breaks then that one will just be a tail not a brake or Vice-versa.
Do what now?
freightshaker is offline   Reply With Quote
Old 10-04-2009   #6 (permalink)
robby12
I had the same problem with my 76 KZ1000 i replaced everything thing but the light bulb and it was the light bulb and the filament in my old bulb did not appear to be broken
robby12 is offline   Reply With Quote
Old 10-04-2009   #7 (permalink)
freightshaker
Luv my big boy toys
The filament won't always be noticeably broken.
Could test with ohm meter or just pop in a new bulb or try your bulb in another headlight.
Do what now?
Old 10-05-2009   #8 (permalink)
oberkfell
Thanks for the help.
It was the headlamp after all.
This of course is after cleaning every damn electrical contact/lead on the bike.
Now, back to the brake problem.
Old 10-05-2009   #9 (permalink)
StarGate
StarGate's Avatar
Just consider that as preventative maintenance.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
81 750 LTD high beam issue azr Vintage Motorcyle Info 6 08-09-2009 08:17 PM
Light Bar and Headlight Bulb question PedsMan Kawasaki Cruisers 24 05-15-2009 10:44 PM
Donkey Love - it's driving me crazy rocknskot Off Topic 9953 04-24-2009 05:19 PM
My New Headlight. insolentminx Kawasaki Cruisers 21 02-23-2009 05:56 PM
new zx-10r ninja headlight problems 2f2f Main Lobby 2 09-05-2004 12:54 PM
