Old 10-04-2009   #1 (permalink)
mikey0829
mikey0829's Avatar
Question 82 305 csr won't shift
the bike shifts to first and back to neutral just fine but not into 2nd and up, anyone have any ideas?
mikey0829 is offline   Reply With Quote
Old 10-04-2009   #2 (permalink)
StarGate
StarGate's Avatar
Is the bike running or are you trying to do this with the bike sitting still?
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 10-04-2009   #3 (permalink)
jfle98
Alot of Kaw models do this, it's a safety thing I think.
Bike must be running and mooving to shift correctly.
John
jfle98 is offline   Reply With Quote
Old 10-04-2009   #4 (permalink)
mikey0829
mikey0829's Avatar
it was running . I rode it back from the gas station about 1 &1/2 miles in first
Old 10-04-2009   #5 (permalink)
StarGate
StarGate's Avatar
OK how about some history leading up to this. Has is ever worked right since you've owned the bike, does it grind when you try to shift, has there been an recent work done to it, have you had a recent accident or dropped the bike etc etc.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 10-04-2009   #6 (permalink)
jfle98
OK then, sounds like U R ****ed !
Time to pull the motor and do some research !
Good Luck !
John
Old 10-04-2009   #7 (permalink)
robby12
did you check the gear box fluid? thats the first thing you should do or change the gear box fluid
robby12 is offline   Reply With Quote
Old 10-05-2009   #8 (permalink)
mikey0829
mikey0829's Avatar
we got it going not sure how but removed the clutch cover & clutch wiggled the shifting fork around and started working again, thanks for the help,
Mike
Old 10-05-2009   #9 (permalink)
kawpaul
itching to ride
kawpaul's Avatar
Gear box fluid?
1983 gpz 750 .....the wait is over
kawpaul is offline   Reply With Quote
Old 10-05-2009   #10 (permalink)
robby12
If the wrong weight fluid is used it can cause the clutch to slip and act like its in neutral any mess up other things
Old 10-05-2009   #11 (permalink)
StarGate
StarGate's Avatar
Originally Posted by kawpaul View Post
Gear box fluid?
Just in case you missed it the first time robby12. These bikes don't have a gear box. The transmission and clutch are encased inside the crankcase with the rest of the bottom end of the engine. And using the wrong oil in one of these will cause the clutch to slip but it's far from being like it's in neutral. At least the ones I've personally seen with the wrong oil were. If there's one that will make it appear to be neutral I've yet to see it.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
CSR 305 parts needed..Priority headlight bulb nick305 Accessory Swap Meet 1 11-02-2008 02:44 PM
81 Kz 305 CSR, new to me ck76239 Vintage Motorcyle Info 6 07-15-2008 09:29 AM
kawasaki 305 CSR jaguar Vintage Motorcyle Info 11 04-12-2008 04:23 PM
83 305 CSR carb cleaning/replacement.... 1987rx7guy The Mechanics Corner 6 04-12-2008 11:50 AM
kawasaki 305 CSR jaguar Vintage Motorcyle Info 0 12-24-2005 08:57 AM
